"The BIG BOV thread" (Where all bov question threads get merged) - Page 654
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Blow Off Valve FAQ: Read if you are thinking of buying one! - NASIOC The search button will help you ...
  1. #9796
    Registered User Death To Ricers's Avatar
    Jan 2004
    Phoenix, AZ
    The search button will help you out with many of your questions.
    2006 WRX
    You could vote to fix me a sammich.
  3. #9797
    Registered User WRXDrummer's Avatar
    Dec 2007
    Cleveland, OH/State College, PA
    Well, what you stated says that you actually want to get a Bypass valve (BPV). Then, yes it will be ok. This is actually the current set-up you have
    If it is that psssh sound that you want, I would recommend keeping the stock BPV and getting a short ram intake (SPT, Cobb, K&N). That is the set-up I have on my car, and I assure you it is really loud both inside and outside the car.
    That is the set-up I would recommend. Why buy an aftermarket BPV when the stock one works just as good? I think your money could be better spent elsewhere (like a new downpipe and a stage II flash...)
  4. #9798
    May 2007
    orlando flawduh
    ^ read that link above or go here:
    http://www.clubwrx.net/forums/engine...ov-thread.html
    theres nothing wrong with your stock BPV. if youre looking for sound, get a short ram intake/drop in filter/intake silencer delete
    whats more important, the longevity of your engine/your performance.. or having a TOTALLLY RAD PSSSHHHH sound?
    desiree
  6. #9799
    Apr 2008
    Miami
    hks comes with a 100% recirculated bov
  7. #9800
    Apr 2008
    Miami
    would the car be ok if i do put on the 100% recirculating bov?
  8. #9801
    Dec 2007
    Quote Originally Posted by NsZ187 View Post
    The it is technically not a BOV, it's a BPV. There is no air being "blown off" to the atmosphere, so it is doing the same thing that the stock one is doing. This is just speculation, but I'm pretty sure that the hks one will not give you a significantly different sound from the stock one if you still have the stock airbox and silencer.
    Quote Originally Posted by wrxtreme06 View Post
    Obviously the totally awesome PSSSSSSSSHHHHHH sound!
    Would it be ok? Yes. Is it pretty much the exact same thing that you have on your car now? Yes. Would it be a big waste of money? YES! Buy a short-ram intake instead, you'll here the spool up of the turbo too.
  9. #9802
    Apr 2008
    Miami
    ok i see what your saying. now i have heard some clips of the hks bpv and it has a high pitched sound. Will i hear that if i put it on my car?
  10. #9803
    Dec 2007
    Without the short ram, I speculate that it will sound almost the exact same as your current set up is.
    Here is my recommendation. Try the silencer delete (take out the intake silencer in your passenger side front fender). If that isn't loud enough for you, get a reputable short ram intake.
    Your money can be better spent on other things besides the hks.
  11. #9804
    Apr 2008
    Miami
    If i get a short ram intake would i have to retune the car? Or is there a short ram that i can install with out having the car retuned?
  12. #9805
    May 2007
    orlando flawduh
    you dont have to tune your car for an intake, unless you want to actually get power gains.
    desiree
  13. #9806
    Dec 2007
    As long as you get one with the same inner diameter as the current stock one, you'll be fine. I would go with either SPT, Cobb, or K&N (I have the K&N). They all work great and have zero problems.
    It only took what 4 posts or so to convince you that a BOV is not what you want/need.
  14. #9807
    Dec 2007
    shoot you beat me to it!
  15. #9808
    Apr 2008
    Miami
    so i can just buy a short ram and slapp it on there and it will be okay? it wont run lean?
  16. #9809
    Dec 2007
    It will be okay if you use one of the 3 I mentioned earlier.
    I'm not sure if slapping will work, it might require some nuts and bolts...
  17. #9810
    Apr 2008
    Miami
    in regards to removing the silencer. do i need to purchase a fender plug?
