This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Rogan tuning isnt the issue.. the issue is the maf has already read the air, and is ...
  1. #9301
    Registered User Pat'swrx's Avatar
    Sep 2007
    Fort Collins CO
    tuning isnt the issue.. the issue is the maf has already read the air, and is now fuelling for that air, but you let it out via bov, so now its rich..
    but see what I'm saying is that if you dyno tune it can't they calculate the air to fuel ratio so then it won't make the engine run rich?
  2. #9302
    The Kind Administrator. Watch out for the others Trainrex's Avatar
    May 2003
    Quote Originally Posted by Pat'swrx View Post
    No. The rich condition doesn't happen under throttle.
    The only way to make it work 100% is converting to MAP.
  3. #9303
    Registered User wunderboy987's Avatar
    Nov 2007
    nj
    that sounds pretty easy. were can i get a stock bpv other than a dealer? thanks for the help guys
    Hawk-Eye Alliance #898Military Milita #898
    AP stage 2 93 oct. maddad DP. SPT short ram intake,SPT intake heat shield,HKS carbon fiber catback,boost,MAF,volt gauges,STI springs, pioneer flip screen headunit, polk audio speakers, vortex generator,STI wing,rally armor UR flaps
  4. #9304
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Quote Originally Posted by wunderboy987 View Post
    Ebay, here, NASIOC, I-club, Iwsti, Craigslist, Dealer.
    It is easy, 2 bolts, 1 Clamp and a gasket or o-ring depending on which IC you have.
    2 Bolts require 12mm socket IIRC, clamp is "Jesus style" so although a proper tool is sold to take them on and off, the good old plier method works. If you have no clamp a simple screw tighten hose will do.
  5. #9305
    May 2007
    behind the wheel
    If it were that easy, all the kids would be doing it
    Rogan o_0
    '01 Dodge 2500 CTD 6-holed hand-shaker - 3850# dual disk
    '97 Dodge 3500 CTD DUALLY built Auto - 40psi boosties
  6. #9306
    Nov 2007
    nj
    i have the stock 07 IC
  7. #9307
    Nov 2007
    nj
    want to sell my turbo sx RFL blow off valve. its the loudest BOV they make, it has 5k or less miles on it. the reason im selling it is because my car is runing rich. im also looking for a 07 stock BPV or will do an even trade for my turbo sx for a stock BPV. thanks, if u have any questions shoot me a PM
  8. #9308
    May 2007
    behind the wheel
    want to sell my turbo sx RFL blow off valve. it used to be the loudest BOV they made, it has 5k or less miles on it. the reason im selling it is because my car is runing rich. im also looking for a 07 stock BPV or will do an even trade for my turbo sx for a stock BPV. thanks, if u have any questions shoot me a PM
    fixed it. lol
    Ive got a 2002 bpv in the garage. are they different? I didn't think they were...
    I don't want an RFL, though..
    Rogan o_0
  9. #9309
    Jun 2006
    Nor Cal
    O-ring
  10. #9310
    Dec 2007
    wait what can u do with a bov to make ur car not run rich?
  11. #9311
    Registered User danscoobywagon's Avatar
    Nov 2005
    NJ
    needs to recirculate
  12. #9312
    Nov 2007
    nj
    does anyone know if a stock 2005 wrx has the same stock BPV as a 2007 wrx tr?
  13. #9313
    Nov 2007
    nj
    quick bov question
    does anyone know if a 2005 wrx stock bypass valve will fit on a 2007 wrx tr? thanks
  14. #9314
    Registered User BillFromTR's Avatar
    Mar 2005
    toms river, NJ
    It should.
    05 STi for sale, 400hp, 50k miles, only 17k
  15. #9315
    Registered User bcyb1029's Avatar
    Feb 2006
    Chicago
    It will.
    Tuned by Jorge at P&L, 240.83whp 239.60wtq at 14.8psi on 2.0L with stock td04 (But doesn't run)
