"The BIG BOV thread" (Where all bov question threads get merged) - Page 57
Page 57 of 798 FirstFirst ... 7474849505152535455565758596061626364656667107157557 ... LastLast
Results 841 to 855 of 11958
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; it all depends on what type of sound u like..... i have a GFB BOV and it gives off a ...
  1. #841
    Aug 2002
    California West Cost
    i have a GFB BOV and it gives off a nice crispt sound...
    but it is not as loud as the Blitz or HKS
  3. #842
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    many complain that after a few months of hearing it, it gets so annoying they have to take it off, and they feel like they wasted money.
    for the kind of cash you'd spend on a BOV, you could get something that would make a NOTICABLE performance improvemnt. the BOV will do nothing for the car.
    if you still decide you want one, make sure you get one that at least is 50/50 vent. the stock BPV is 100% recirc. 100% vent will make your car run horrible.
    dR
  4. #843
    Registered User jutus's Avatar
    Winnipeg, Manitoba, Canada
    There seem to be conflicting reports on this. (See God's post)
  5. #844
    Aug 2001
    The Hub
    i personally would not want to be running rich b/w shifts, and having the ECU pull fuel to compensate.
    many others comment on a turbo "flutter" i don't have one, so run some searches, and get the general consensus. i'm just passing on what i hear.
    dR
  6. #845
    Oct 2002
    St. Paul, MN
    car idiels funny after installing blitz dd bov
    the car idles funny. it kinda shakes the car and makes a ticking noise. seems like its coming from the belts. but when i step on the gas slightly, the rpm goes up then down to almost 100 then goes back up and sits around 500.
    go to this link for pictures.
    http://forums.i-club.com/forums/show...hreadid=270387
  7. #846
    I have the exact same problem with my Greddy Type S BoV. People have been telling me its a leak. I haven't fixed it yet - I'm probably gonna just get a new one or something since I bought mine used.
  8. #847
    God
    God is offline
    Registered User God's Avatar
    Aug 2001
    Detroit, MI
    Try feeling around the BOV and see if there are any leaks at idle. Adjust the spring so that you don't leak. Then pull on the throttle cable and see if you get any leaks at steady higher RPM. If good then you're all set. On the Blitz you just loosen the 12 mm nut on top and use a 4 mm allen wrench to adjust, the retighten the 12mm nut.
    Daniel Ponze, Lead Tuner Tuning Factory, Inc.
    PH: (248) 477-0700___FX: (248) 477-0701
  9. #848
    Moderating U! KurleeDaddeeWRX's Avatar
    Mar 2002
    San Jose, CA
    I had the exact same problem with my GFB BOV, but there is no way to adjust the GFB. I also sprayed carb cleaner around the outer circumference of the BOV to see if there was a leak. If there was, the RPM's would have jumped slightly. But there was NO leak. So I got rid of it and run the stock BOV. I will never run a aftermarket BOV on my car again. No performance = No gain.
    Kurlee Daddee
    (THE ORIGINAL)
  10. #849
    Mar 2002
    From what I heard, the blitz leaks at idle..i could be totally wrong though.
    I have HKS SSQBOV. It is impossible to leak due to it's design. And it sounds great.
  11. #850
    God
    God is offline
    Aug 2001
    Detroit, MI
    You have to adjust the Blitz. The spring is set kind of loose out of the box. It works perfectly once adjusted.
  12. #851
    Oct 2002
    St. Paul, MN
    thanks guys.
    the blitz sounds funny in a way. i had the hks ssq and that sounded better.
  13. #852
    Registered User ***biGRed***'s Avatar
    Oct 2002
    are these easy to install? do they come with instructions? i heard that they're in japanese?
  14. #853
    Mar 2002
    I have HKS...and I love it.
    I heard that GFB is great, too.
    If you want a high pitch sound, then I think HKS is better.
    -soul
  15. #854
    Registered User WRXin''s Avatar
    Jun 2002
    Houston, TX
    I just installed my HKS SSQV BOV, and may I just say OH MY GOD!!! I love it. It sounds sooooo cool The install was quite easy. The only marginally difficult part was getting the plug in the air inlet hose, and putting the clamp around it. Even that wasn't too terribly difficult. The problem with running rich is hardly noticable. The only reason I felt it is because I was looking for it. Overall, this is a cool mod, and I recommend it to everyone...even to all you BOV haters
    Fahd
    Floats like a butterfly and stings like when I pee!
  16. #855
    Jun 2002
    Houston, TX
    Here are some clips if you want to hear what the HKS BOV sounds like. Here's the link to it: http://users2.ev1.net/~qwerty96/tsp/members/Fahd Go to the bottom of the page, right click on one of the videos, and save target as. Not all of the are working. Some are yet to be downloaded. Enjoy
    Fahd
