This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by illmind whats the deal with duel port bov (Turbosmart) if you run it 50 50 is it ...
  1. #8251
    Oct 2005
    Ocean Grove, NJ
    Quote Originally Posted by illmind View Post
    whats the deal with duel port bov (Turbosmart) if you run it 50 50 is it safe for a stock turbo or does it stil f*** with the a/f ratio?
    yes - it's a matter of BOV+MAF being a bad idea.
    please read this
  2. #8252
    Registered User lilkrazekid's Avatar
    Dec 2006
    phoenix
    blow off valve
    i know how to mount a bov on a top mount intercooler, but if i were to switch to a front mount will i be able to still use the same bov that i had or would i have buy a different one cause it looks like it may mount differently. any help on this would be awesome
  3. #8253
    Registered User project_skyline's Avatar
    Mar 2006
    Silt, Colorado
    Quote Originally Posted by lilkrazekid View Post
    Alright first off BOV on wrx/sti isn't what you want to do. You either have to use a BPV or at least 50% recirculation setup otherwise your car won't run properly since it uses a MAF sensor which measures air in the intake and then applies the proper fuel and the BPV is meant to recirculate the air back into the intake pipe after the MAF sensor so that no air is lost and your fuel mixture isn't altered.
    And second to answer your question it all just depends on the BOV, if you switch to a front mount you have to have a flange welded onto the charge pipe and your BOV needs to be able to mount onto it. It all comes down to how the BOV mounts.
    HOpe that helps.
  4. #8254
    Oct 2005
    Ocean Grove, NJ
    please read this
    Cliffs notes - nothing short of recirculating 100% of the air to the intake tract is going to result in a safe condition when are car is tuned for and controlled via MAF.
    If you want to run a BOV, convert to MAP. Yes, you can put it on the car, plenty of people do it - but you are creating an intensely rich condition every time it VTA's.
    (I did a little more research)
    From GoFastBit's BOV FAQ page :
    In a car with a MAF sensor, when a BOV vents, air is escaping from a closed system. This air has already passed through the MAF sensor and has been measured, and the computer doesn't know that this air never made it to the engine. This will cause a brief rich mixture as the computer will still deliver the correct amount fuel dosage based on the amount of vented air.
  5. #8255
    Oct 2002
    The Old Folks Home
    Here's another one for Andrew to add to the "Big BOV Thread".
    --Ray
    Proud owner of a N.E.R.D.
  6. #8256
    Administrator TheJ's Avatar
    Dirty South
    Smile
    +1
    This is the big BOV thread. If you didn't find this thread, you didn't search.
    -The J
    New Members, CLICK & BOOKMARK these links:
  7. #8257
    Registered User bcyb1029's Avatar
    Feb 2006
    Chicago
    don't get a BOV until you are pretty well moded.
    Tuned by Jorge at P&L, 240.83whp 239.60wtq at 14.8psi on 2.0L with stock td04 (But doesn't run)
  8. #8258
    Oct 2005
    Ocean Grove, NJ
    Quote Originally Posted by bcyb1029 View Post
    defined as - convert to MAP (manifold absolute pressure)
  9. #8259
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Buy one of these to fit whatever BOV you wish.
    http://cgi.ebay.com/ebaymotors/02-04...90758947QQrdZ1
  10. #8260
    Oct 2005
    Ocean Grove, NJ
    Quote Originally Posted by 06wrx4me View Post
    and then what should they do about the stocker?
    You're joking right
  11. #8261
    Registered User PJO42387's Avatar
    May 2006
    DF-DUB
    I love hippies
    CGM
  12. #8262
    Nov 2005
    Central Florida
    the stock 1 fits the aps 525 fmic
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
  13. #8263
    Registered User WRXforME's Avatar
    Sep 2006
    Wiscompton
    PoOOoOOOOoooOoOoSh!!!!!!!!!!!!!!!!!!!!!!!!!
    AP Stage 2- 2006 WRX TR (WRB)
    Other cars:
    1996 Honda Accord
    1965 Buick Skylark GS
  14. #8264
    Registered User powder's Avatar
    Aug 2006
    WA State
    Quote Originally Posted by PJO42387 View Post
    I love hippies
    duuuuude...
    Blobeye Syndicate #2004
    Military Militia #30-06
    2004 WRX - JBP:Stage 2:13.93 @ 96
    Wingless alas. Too bad it took a 50 ton truck to make it happen.
  15. #8265
    Registered User Chapel's Avatar
    Dec 2006
    Beverly MA
    as much as I want to make the noise... I don't want to get the driveability problems.
