"The BIG BOV thread" (Where all bov question threads get merged) - Page 510
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by rr1911 sounds about right +1...
  1. #7636
    Registered User Jje121's Avatar
    Jan 2005
    Fitchburg, ma
    Quote Originally Posted by rr1911 View Post
    sounds about right
    +1
    New England F4
    Bugeye Mafia
    2004 GMC Sierra 1500
    03 Subaru WRX (SOLD)
    01 CBR 929 (SOLD)
    Quote Originally Posted by blarg
    nothing funny about stubble on the man-marbles.
  3. #7637
    Registered User afbluesv1k's Avatar
    Apr 2006
    Buffalo, NY
    sounds good but only one thing to add to make it easier for you. If you take a look at the recircualtion hose, the black rubber one with the metal spring clamp. That metal clamp has a pair of teeth on it so you can lock it open. So you can slide the recirculation elbow into it, then bolt the BPV in place, then release the lock on the clamp so the hose aligned right.
    The only other thing you may need to do is if your BOV is big like my Worx one was, the metal vent line that runs along the front of the intercooler may need to be moved. Its just 2 or 3 10mm bolts to take off and it will let you move it around if its in the way.
  4. #7638
    Registered User WMAWRX's Avatar
    May 2005
    Greenwich, CT
    If you're going the TMIC route, I'd stick w/the stocker. I actually have the re-circulating TXS H34 myself and it works great with my setup, but I would have just stayed stock if I hadn't switched to an FMIC.
    That said, if you want a little bit more sound, you can use the TXS valve and won't give you any trouble.
    New England F4
    FOR SALE!!!
    VF22/FMIC/UTEC/Pinks/ACT/STi RA's/Apex'i N1 Type-V's - Tuned at XXTuning, 270 WHP/ 270 TQ @ 18.5psi. 12.697@ 108.95
  6. #7639
    Registered User BlueStallion's Avatar
    May 2006
    Rochester, MN
    How to run BOV?
    Yes, I am still kind of a ricer and want to get a bov but dont want to hurt my car. I was wondering how do I make this happen. Does Cobb have a tune that includes a bov or any other device that will change the tune from half in half to an all atmospheric bov?
  7. #7640
    Registered User cavallino333's Avatar
    Feb 2005
    Campbell CA
    don't buy one problem solved theres no tune or anything that will prevent it.
    FORZA FERRARI
    BLOBEYE SYNDICATE (retired) #13
    Quote Originally Posted by Integra96 View Post
    One day I hope to buy a car that is lubricated exclusively by pure manatee oil.
  8. #7641
    Boba Fett BrianH's Avatar
    Oct 2003
    Way up high.
    buy it and keep it under your drivers seat.
  9. #7642
    Feb 2005
    Campbell CA
    Quote Originally Posted by BrianH View Post
    omgz then da seats will be mad psssht'in dawg.
    FORZA FERRARI
  10. #7643
    Registered User cheeseybacon's Avatar
    Jul 2004
    Chambersburg, PA
    The simple answer is no, you can't run a BOV and still make it 100% safe, no matter how you tune it.
    The fact that you're venting air out of the intake tract and straight into the atmosphere, air that your ECU anticipated being there, means you're always going to run rich. If you MUST have some scream "oooh look at me everyone, I have a turbo!" whenever you shift, consider a Cobb SF or SPT intake instead. Neither will do much in the power department, but they will make your stock bypass valve louder which should satisfy your ricer tendencies without messing with your A/F ratios.
    ΜOΛΩΝ ΛΑΒΕ
  11. #7644
    Oct 2005
    Ocean Grove, NJ
    It's (not) simple - just convert your car from MAF to MAP - then create a custom tune.
    Cobb AP + Protune/Streettuner
    or UTEC or Enginuity - probably more ways to do it also.
    Of course the only way you're going to get someone to help you with this - is probably paying them by the hour. It's a bad idea really - if you want the BOV sound that bad, just buy the electronic BOV noisemaker off e-bay - just as rice and it won't damage anything - well, other than your image
  12. #7645
    May 2006
    Rochester, MN
    ok i understand thanks for the help guys
  13. #7646
    Nov 2006
    Newb question
    Hello, im new here, ive been reading around the forums a bit and noticed alot of people say BOVs are bad. i plan on getting a wrx this summer. my understanding is that BOVs r required by turbos to release pressure so the wrx must have a BOV i want to know if the BOV makes a noticable sound and if not, how hard would it be to switch it out for one that is a little louder. i must have that "pshht" sound when i shift!
    sorry if any of this dosent make sence, but i figured now is as good a time as any to start learning about these things
  14. #7647
    Mar 2002
    Calmer than you are
    no.
    if you really DID do some reading you already know you CAN'T get the sound you're looking for without installing something that will mess up your car. Subaru's already HAVE a valve, it just doesn't make any noise.
    looks like you didn't like the answer you came up with by searching so you're asking again hoping to get a different answer. you won't. BOV's suck.
    you should have bought a old DSM or a turbo'd Civic.
    a n00b asks this question on this forum at least 3 times a day, and the answer is always the same.
    just say "no" to BOV's.
    go f*** yourself
  15. #7648
    Apr 2006
    Bay Area Ca.
    Bov...
    someone please correct me if i'm giving info out incorrectly. From what I've come to understand about blow off values is... they aren't bad for your car but they don't improve performance and that lovely darth vader sound is annoying (to some/not all); and hence most people find them pointless and talk negatively about them. I happen to agree with the masses on this one. I rather get better speakers in my car than have 9ussies anakin turn darth vader on me every time I shift.
  16. #7649
    Mar 2002
    Calmer than you are
    Quote Originally Posted by gabe.zavala View Post
    I guess YOU need to do a search too.
    BOV's mess with your a/f ratio.
    and yes, its also pointless and annoying.
    "Hey...LOOK AT ME!!! I have teh trubo! I am teh fast4R"
    meh.
    go f*** yourself
  17. #7650
    Feb 2005
    Campbell CA
    +1 blargs right.
    BOV's = NO
    FORZA FERRARI
