"The BIG BOV thread" (Where all bov question threads get merged) - Page 507
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Now Im confused as all #$#$! I have no idea, because there are no solid replies to yes or no ...
  1. #7591
    Registered User BoostedXTC's Avatar
    Aug 2006
    Colorado
    Now Im confused as all #$#$! I have no idea, because there are no solid replies to yes or no when a bov should be used. Maybe that is because most Bov threads include a question about the first mod. I have read over and over about bov not a good first mod, Ok, Im fine with that, don't want one any ways.
    But, what about after you upgrade the entire fuel system,get a bigger turbo (looking at 18G), get a FMIC, some engine management, and a dyno tune all at once. Is that an ok time for a BOV? Or is it after the boost gets turned up.
    I have searched this, and everytime the question of an upgrade consisting of a bigger turbo/IC/Fuel system/dyno tune/EM, the replies are 50/50. I can't figure out what is the right solution.
    Sorry not meant to Hi-jack, but maybe some good replies to this will help out future new suby owners with a question.
  3. #7592
    Registered User wakeskate23488's Avatar
    Mar 2006
    Ocean County, NJ
    ha nice man, i dont know what it is with people, i tell guys all the time not to run these and they think im lying, idk but im sure you will have no problem selling them.
  4. #7593
    Registered User cheeseybacon's Avatar
    Jul 2004
    Chambersburg, PA
    Quote Originally Posted by BoostedXTC
    The simple answer is, if you upgrade your turbo and begin running a higher boost level than what your stock recirculating valve can handle, you simply get a stronger aftermarket recirculating valve that can handle the increased boost pressure. There are stronger recirculating valves out there ya know, so just because all aftermarket BOVs can handle a good amount of boost doesn't mean that they are your only choice once you've exceeded the capability of your stock bypass valve. The only reason why these BOVs can be set to handle a large amount of pressure is because they're typically built to be more universal in their application, rather than for specific vehicle or motor.
    With that in mind, just because you get an 18G, intercooler, fuel system, dyno tune/engine management doesn't mean that it is now OK to get a BOV. The basic operation of the system isn't really changing when you do such upgrades, you're just operating on a larger scale (bigger injectors and more fuel, bigger turbo and more air) than before, nothing more.
    To sum it up, more boost does not justify the purchase of a BOV. More boost justifies the purchase of a better recirculation valve.
    ΜOΛΩΝ ΛΑΒΕ
  5. #7594
    Oct 2005
    Ocean Grove, NJ
    i believe Prodrive makes a replacement boost control unit, so does perrin - does anyone know if either of these units are plug-and-play
  6. #7595
    Jul 2004
    Chambersburg, PA
    Quote Originally Posted by Micah
    Erm, wrong thread maybe? Boost control units and BOVs perform completely different jobs.
    ΜOΛΩΝ ΛΑΒΕ
  7. #7596
    Oct 2005
    Ocean Grove, NJ
    Quote Originally Posted by cheeseybacon
    Brainfart - my bad. stock recirc is considered good up to 25psi I think from what I've read on the forum. - I guess the question I was trying to ask is :
    Are there any aftermarket replacements for the stock BPV which we can put a link to in this thread so that people can be referred here the next time the question arises?
    (and the award nominees for run on sentances are.........)
  8. #7597
    ClubWRX.net Vendor JSCspeed's Avatar
    Jul 2003
    Montgomeryville, PA
    Perrin has recirculating BOV
    Turbo XS also has an upgraded recirculating BOV the WS-RBV. We just got them in and they are very nice.
  9. #7598
    Oct 2005
    Ocean Grove, NJ
    Quote Originally Posted by JSCspeed
    Now in order for these to function correctly and not cause the car to lean out - 100% would need to be recirculated correct?
  10. #7599
    Jul 2003
    Montgomeryville, PA
    Yup. Both of those are recirculating. But, like Cheesy said, why bother till you actually need to?
  11. #7600
    Registered User rex.effect's Avatar
    Oct 2005
    Baltimore, MD
    i have the turbosmart dual port 50/50 and i could not be happier. yes, it it true that is dropped my mpg by 1 or 2 and it had 0 performance gains, but i enjoy the swoosh it makes and that was why i bought it. not to put in others faces, but for ME to enjoy when i and whipping through turns. it adds to the sensation of speed and power at a time when i am not vary fast at all. truth be told, once i get faster, then it is going to come off the car. i will have more than enough sensory input to know i am haulin' azz.
    -Taz
    Blobeye Syndicate #77
    "Understeer is when you´re scared...
    Oversteer is when your passengers are scared"
  12. #7601
    Banned engz's Avatar
    Feb 2006
    New York
    let me know about the deal. free bump
  13. #7602
    Registered User le wagon's Avatar
    Jul 2005
    SoCal
    Quote Originally Posted by engz
    i have one im willing to sell you
    EVO III 16g'd wagon
    stock tranny goin strong
    .. already ready for a bigger turbo
    Quote Originally Posted by chanwahyaoh
    Sometimes after I go poo, I just blank out and mindlessly continue my upward wipe all the way up the small of my back and end up smearing brown all over myself. Just kidding. That sucks about your laundry though...
  14. #7603
    Registered User scooby2.0t's Avatar
    Apr 2006
    salisbury,MD
    wow so this thread should be moved to nasioc since everybody flamed him so bad. and no offense i love this forum and i love everybody here but its deff the most unfriendly forum when it comes to noobs (well besides nasioc that is)
    2002 WRB WRX- XPT Stage 2 Awaiting 25% more displacement!!
    got grip?
  15. #7604
    Registered User bdpAKAknox's Avatar
    Apr 2006
    So Cal
    Arrg, teh interweb be a harsh mistress.
    But, sometimes tough love is the best way to learn.
  16. #7605
    Aug 2006
    Lake Zurich, IL
    Quote Originally Posted by Poekin
    did anyone else read the title and say to themselves "O man this poor kid"
    Yes, and I was gonna say search engine is nice to use.
