"The BIG BOV thread" (Where all bov question threads get merged) - Page 501
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by scooby2.0t honestly we all know that a bov makes you run rich inbetween shifts but now tell ...
  1. #7501
    Registered User cheeseybacon's Avatar
    Jul 2004
    Chambersburg, PA
    Quote Originally Posted by scooby2.0t
    honestly we all know that a bov makes you run rich inbetween shifts but now tell me why thats bad besides the fact that your burning a lil fuel bc i know no one has burt out any o2 sensors or anything like that and have heard of very very few problems mechanically besides ppl who buy junk and expect it to work.
    Running rich typically doesn't cause immediate danger like running lean can. The effects of running rich usualy cause problems that show up over the long term. Your spark plugs will foul up much quicker, and running rich can wash out your cylinders which is definately not good. I've been told it can prematurelly foul up your valves too.
  3. #7502
    Moderator Donkey's Avatar
    Da boonies,Va
    It can also cause problems with catalytic convertors for those that are running them,when the unburned fuel ignites inside them.Also as well when the air is recirculated it keeps the turbo spining by a pinwheel effect and also keeps the chargepipes and intercooler pressurized.http://www.spdusa.com/blow-off_valves.htm same stuff can be found in a book called "Maximum Boost" by Corky Bell.
    2002 FORESTER S
    1998 FORESTER S
  4. #7503
    Moderator MidKnight's Avatar
    Oct 2002
    Bergen, NJ
    The running rich caused by a BOV isn't gonna hurt anything. It won't damage your cat, it isn't gonna kill your plugs, etc. However, it does happen. I had a forge BOV on my car for a long time and I absolutely noticed it. Wanna experience it yourself?
    Find a nice sweeping offramp and get down it hard. As you're mid corner, lift your foot off the gas to make the BOV open, and then hit the gas again really quickly (you're simulating making an adjustment midcorner with the throttle, but I'm not telling you to go fast enough that you have to). If you're at any decent boost pressure when you lift, you will feel the car hesitate everytime you do this... If you don't feel it, your bov isn't working correctly.
    I have a datalog somewhere that shows very clearly the richness when you get off the gas. It's inevitable based on how the car meters air... You can deny all you want and say what ever makes you feel best, but at the end of the day it is what it is...
    '03 WRX
    '01 2.5RS
    MODS | PICS | Dyno
    "Stuff sold by the gram is always going to be more exciting than stuff sold by the pound." - Jeremy Clarkson
  6. #7504
    Feb 2005
    Michigan
    Running Over 20psi soon, what BOV should I get?
    Trust me I hate BOV's and they make the car run like doo doo. I'm installing my FP18g with Helix 820cc's and a Walbro 255, and last of all my Helix TMIC, within the next week or so. I'm getting it tuned with utec around 20-22psi, and I know the stock one doesn't like anything over 20psi at all, and 20 is pushing it at that. Should I stay with a recirculating valve or would atmospheric be ok with this setup?. I was either thinking a Forge Recirc, Perrin Recirc, or maybe a GFB Hybrid 50/50 to be even louder and more obnoxious. What would be the best/safest/smartest?
  7. #7505
    Nov 2005
    Central Florida
    i like the perrin recirculating valve
  8. #7506
    Feb 2004
    Evansville, IN
    I run the APS Dual Port. Its nice.
    or you can search NASIOC for stock BPV mod. It uses a directional control valve to lock the BPV shut during high boost runs. I believe I will do this with the new setup.
    1988 Celica Alltrac
    Hallman Pro, 15x7.5 +20mm Rota Slipstreams
    2005 LGT 315whp/340wtq@21psi - Sold
    VF52, Crucial P&P&C Manifolds, UP, DP, RP, Magnaflow CBE, Hallman PRO, ROMRaider
    2003 WRX 371whp/355wtq@24psi - Sold
    TD05H-20G-38mm Tial, Meth Injection, Hyperflow TMIC, ROMRaider
    Dyno Chart METH vs 93 oct
  9. #7507
    Registered User RWU00313's Avatar
    Nov 2004
    my stock valve holds 22 lbs just fine.
  10. #7508
    Registered User Cuztom15's Avatar
    Apr 2004
    River City, NJ
    Quote Originally Posted by RWU00313
    +1 boost leak tested approved
    Blobeye Syndicate #17
  11. #7509
    Registered User DeBlas66's Avatar
    Apr 2006
    Westchester, NY
    +2 for stock
    Car-less
  12. #7510
    Registered User PolarisSnT's Avatar
    Aug 2002
    Staten Island, NY
    +3
    21lbs on the stocker but I couldnt run any higher. Find out what boost you are going to run and that will determine if you need to switch. Then again the stock BPV can crack open at 19psi and others can hold till 23psi so Id say get a BPV just to be safe.
    I like Forge.
    Dan- 2004 PSM 5spd
    "Days get shorter, nights get longer, snow gets deeper, life gets better."
  13. #7511
    Feb 2004
    Evansville, IN
    Quote Originally Posted by PolarisSnT
    mine did as well...
    1988 Celica Alltrac
  14. #7512
    Registered User bulletSTI's Avatar
    Aug 2005
    Connecticut
    APS Dual Port or Turbosmart BOV, the later actually makes it very easy to adjust how much gets vented back to the intake. All you have to do is twist the cap on it as opposed to APS, where you have to take the top part off.
    Stock bypass valve is also fine, although, personally I prefer aftermarket parts just because I hate stock.
  15. #7513
    Feb 2004
    Evansville, IN
    the APS does not have to be taken apart to be adjusted, it takes only a hex wrench that is supplied. You should only have to adjust it once, during initial installation & thats it. The % of vent is not adjustable.
    1988 Celica Alltrac
  16. #7514
    Feb 2005
    Michigan
    yea i was thinking Forge recirc, or the Perrin Recirc.
  17. #7515
    Registered User Michaelsrex's Avatar
    Oct 2004
    Central PA " Williamsport "
    a really cool one that makes a psssh Noise
    Fp18g, Txs RFL
    650cc PE Injectors, Walb 255 Fp3" TBE, Perrin Inlet Hose, UteC, HeliX uppipe,Stock Tmic
    STock Clutch , Stock 5 Speedn
    STI ShortBloCK 265whp 300tq @17psi Still DETUNED
    13.1 @104 Slipping Clutch
