"The BIG BOV thread" (Where all bov question threads get merged) - Page 450
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I reallly have to hand it to this guy, he took the best of flaming and just kept going. That ...
  1. #6736
    Registered User Houstonwrx's Avatar
    Jul 2005
    Houston,TX
    I reallly have to hand it to this guy, he took the best of flaming and just kept going. That I respect. Most people even when asking for advice, me included, can't take the negative stuff, and you did like no other. Hope you get your car fixed dude....
  3. #6737
    Registered User killthelights14's Avatar
    Mar 2005
    pittsburgh
    cmon man why are you hurting your car. just get it fixed and get some propper mods and it will make you happier, trust me the smile is alot bigger with the right mods
    02 wrb wrx stock turbo fmic 26 psi (it can be done)
  4. #6738
    Mar 2002
    Calmer than you are
    hey, its one thing to give him crap...but its a competely DIFFERENT thing to not even read the whole thread and respond as if the problem hasn't already been fixed...
    and I can't help it if I have incontinent injectors...
    go f*** yourself
  6. #6739
    Mar 2005
    pittsburgh
    Quote Originally Posted by blarg
    i dono why but i cant stop laughing at that ahahahahahahha
  7. #6740
    Registered User KoreanBeefcake's Avatar
    Jul 2003
    Huntsville, Alabama (formerly WA)
    good job at fixing your problems. now go drive the car like it was meant to be driven.
  8. #6741
    Oct 2003
    Vail, CO
    I want to go back to stock as well. So, If I pick up a used or new bypass valve that will replace my hks bov? Can I buy these at a dealer?
    Actually, are these all the parts that I need?
    Stock BOV, Flange, and L hose.
  9. #6742
    Jan 2006
    did mine at the track withe ratchet and pliers in 5min
    dat thang got VTEC!!!
  10. #6743
    Oct 2003
    Vail, CO
    so, those are the parts you used?
  11. #6744
    Mar 2002
    Calmer than you are
    its VERY easy.
    make sure that:
    1) you have the BOV gasket
    2) you reconnect the recirc hose (some BOV's plug it and just leave it hanging...remove the plug and connect to the stock valve
    3) make sure the signal line doesn't get kinked. most of the aftermarket valves require you to move the signal line a bit from the stock location...just keep it out of the way when you reconnect the stock one.
    4) replace the squeese clamp on the return hose with a screw-on hose clamp...makes life MUCH easier....its just a tight fit and more than one ClubWRX member has come close to losing an eye trying to get that spring-clamp back on.
    go f*** yourself
  12. #6745
    Oct 2003
    Vail, CO
    Thanks for the help. I was clueless bc I bought the car with a bov on it...
  13. #6746
    Registered User Scotty09's Avatar
    May 2003
    Aurora, IL
    BOV question <help>
    I sold a HKS SSQV blow off valve on ebay, in perfect working order, the person that purchased it, installed it, and says it doesn't make any noise? Anyone have any clue what could be wrong with it???
    He says he adjusted the knob on the back, and it didn't help..
    Help me out ya'all
    thanks
    Scotty P
  14. #6747
    May 2003
    Aurora, IL
    No clues????
    Scotty P
  15. #6748
    Mar 2002
    Calmer than you are
    he may have kinked the signal line...tell him to check to make sure its not pinched/stretched.
    you have to cut some of the cable ties that hold the line down to get it to fit right.
    go f*** yourself
  16. #6749
    Registered User criticalm@ss's Avatar
    Apr 2006
    bov??
    So to my understanding a bov is bad cuza the rich period info, no bov is needed unless
    a 20 psi or more is runing?
    Is it possible to get the sound without comprimising performance or faulty info to the cars computer?
    Thanks in advance
    turbonoob
  17. #6750
    Mar 2002
    Calmer than you are
    www.sunamiturbo.com
    oh yeah, you can also just roll down your window and go "PSHHHHHHHHHH!!!!!!"
    go f*** yourself
