"The BIG BOV thread" (Where all bov question threads get merged) - Page 43
Page 43 of 798 FirstFirst ... 33343536373839404142434445464748495051525393143543 ... LastLast
Results 631 to 645 of 11961
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I'm a little farther, about 25 miles. Traffic was pretty poor. Just as a note: I dislike driving with the ...
  1. #631
    Registered User gryphon's Avatar
    DFW, Texas
    Just as a note: I dislike driving with the A/C on in rush hour traffic. It jerks more.
    This was even more jerky PLUS it had hesitation with low throttle.
    2002 Subaru Impreza WRX
    Midnight Black Pearl
  3. #632
    Registered User KanosWRX's Avatar
    Dec 2001
    Northern VA
    It really sounds like my problem, so I guess I would be alright driving it home, just have to live with it stuttering all the time. I hate idle, thats when you think it is about to stall, and when you put on some gas you get stutter still, no matter what rpm you are at.
    My Mods
    "The most important mod is the one behind the steering wheel" - Koyokid RIP
  4. #633
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    why did you replace the BOV? you're mods don't really need a new BOV to support anything they are putting out.
    dR
  6. #634
    Dec 2001
    Northern VA
    Like most others I wanted the sound, but now I am thinking twice about doing it.
    My Mods
  7. #635
    Apr 2002
    Delray Beach, Fl. USA
    sounds like a vacuum leak. when you installed the BOV did you clean off the IC mounting flange nice and clean and use the supplied gasket to install? may just need a little tightening. also check your vac lines to make sure one didnt pop off and also check bottom connection on BOV to make sure it didnt come loose.
    It has to be something very basic.
    IHI VF-34, ECUTEK Tuned
    290whp@6300rpms@15.8psi
    247tq@5200rpms@16.9psi
    ( Dynapack Hydraulic dyno )
  8. #636
    Reston, VA
    My 2 cents from a novice. First any other recent mods? If not likely an install error. If not install, try resetting the ECU. I'm wondering if some kind of quirky MAP/fuel map thing got inadvertently quirky if BOV spring malfunctioned. Lastly, check if there is any major scoring or pitting in the slide mechanism. My Turbo XS malfunctioned because the piston/slide was pitted by a peice of gravel!
  9. #637
    Dec 2001
    Northern VA
    I left the stock black stuff on the BOV flange on the IC, I didn't know if I should have taken it off, looked like I would need to scrape it off. The only hose I can't see is the one right under the intercooler, but I did not take that one off. Although I unmounted the IC so I could work a little easier, maybe it got unhooked, but I doubt it. Did anyone else take off that black stuff on the flange for their BOV's?
    Also when you say check the bottom connection on the BOV is that the piece that I took off the stock BOV and screwed onto the APS one?
    My Mods
  10. #638
    Dec 2001
    Northern VA
    Well I think I may have found the problem, but I need to find some tools around the office to try and fix it and see if it works. It looks like one of my samco hoses that comes from the BOV is not flush with the air intake anymore. Some how it must have be pulled a couple CM away from being flush when I was installing the BOV. I listened to that area with the car idle and I could hear a slight hissing noise like a small amount of air was leaking. I assume once I make this connection flush with the airbox it will fix my problem.
    I am also guessing that the reason I did not have this problem until this morning is because it slowly got further away from being flush and when I hit 5k rpm this morning it caused it to move enough were it let a small amount of air escape.
    I am suprised how such a small thing can cause such problems, I have so much to learn.
    My Mods
  11. #639
    Registered User PlatinumWRX's Avatar
    Jul 2001
    PA
    I used the stock gasket, which was left on the IC as well. I have never had a problem with leaking. Just check everything, this definitely sounds like a leak to me.
    -Jim
  12. #640
    Apr 2002
    yeah, I made sure to clean off the black stuff to have a clean mounting surface. Yes to piece off stock BOV. I am betting that one of you IC hoses came loose on one end or another, they are a b*tch to get back on and tightened down. If you boost/vac gauge is showing less vacuum at idle then it was before install you must have a vac leak somewhere=loose hose connection or popped off hose.
  13. #641
    Mar 2002
    Calmer than you are
    if you want a noisemaker you need a 100% atm. in 50/50 valves under most driving conditions, the air gets sucked back into the intake (they're not really 50/50...the just blow off the air the motor doesn't really NEED). At WOT its definately louder...but most of the time its a fairly quiet sound.
    try disconnecting your stock valve and plugging up the return hose first if you don't mind the hit in drivability and performance before you go out and buy one...an aftermarket valve will be louder (or at least sound different) but the loss in drivability will be exactly the same. You'll notice the motor not running as smoothly and hesitation durring shifts....I also thought that the sound was TOO loud and TOO LONG when I set up my GFB 100% just to see.
    go f*** yourself
  14. #642
    Dec 2001
    Northern VA
    well the part that I thought wasn't flush was actually as far as it would go, it actually just had a little 3 cm lip before the air intake hose. But I took off the IC and checked the other hoses and everything seemed fine. I just hope it works now, even though I still don't know where the exact problem was/is.
    My Mods
  15. #643
    Dec 2001
    Northern VA
    I just took it out for a test drive, taking it only up to 3k rpm and the problem seems to be gone. Hopefully its gone for good, but I will keep it under 3k on the way home and then test it more around my house.
    My Mods
  16. #644
    Jun 2002
    sumter, sc
    thank you
    everythin seems fine , whin i wot in first it hits 9 or 10 psi. thank you very much for the help.
  17. #645
    Registered User blackshadow's Avatar
    Apr 2002
    Milan, Italy & Arnhem, Netherlands
    Thanks for your advice. Since all of you have definently convinced me it's not worth trying i just might buy one since it's not too expensive. anyway thanks for the advice.
    autobahn storming scooby
