This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; some people have bad luck with BOV's, having problems as huge as engine failure, or at the very least, running ...
  1. #5986
    Oct 2003
    some people have bad luck with BOV's, having problems as huge as engine failure, or at the very least, running extremely rich.
    BOV's are good for professional racers who run 30psi of boost.
    rice = something that makes your car seem or look fast when it adds no performance whatsoever. BOV's are right down there with ridiculous body kits, 34 stickers on the driver's door, horribly painted interiors, and spinners. most people outgrow them by the time they hit puberty.
    embattled, we prevail...only victory exhaled.
  2. #5987
    Registered User cavallino333's Avatar
    Feb 2005
    Campbell CA
    Quote Originally Posted by AngelBoy
    FORZA FERRARI
    BLOBEYE SYNDICATE (retired) #13
    Quote Originally Posted by Integra96 View Post
    One day I hope to buy a car that is lubricated exclusively by pure manatee oil.
  3. #5988
    Boba Fett BrianH's Avatar
    Oct 2003
    Kicking Babies
    click sig
  4. #5989
    Registered User Botat1725's Avatar
    Oct 2005
    Easton PA
    Diverter Valve or BOV?
    Does a diverter valve still have good sound between shifts? I hear lots of bad things about the bov's, like running rich between shifts. I just wanted to know if the diverter valve was worth getting or if it doesnt sound any diffrent from the stock bypass.
  5. #5990
    Jun 2004
    Chicago, IL
    Your stock valve is a diverter valve. It works fine for boost pressures under 21 or so psi. No need to change it out until that modification level. They are, typically, quiet until you get an aftermarket intake. They make a subtle "whoosh" sound when you do have one.
    Contrary to public opinion. I've been running a Forge BOV for over 30,000 miles from stock to stage 4. I have not had any issues with it. At least none that I am aware of.
  6. #5991
    Registered User speed13a's Avatar
    Oct 2005
    every where
    blow off valve and NOS
    Just wondering which blow off valve is best for my WRX. i was looking into the Worx blow off valvle. (looking for something that recurculates).
    also would it be safe for me to add a Wet NOS kit with a 75 shot on stock internals. i have 860cc injector and walbro 255 lph fuel pump.
  7. #5992
    Registered User cheeseybacon's Avatar
    Jul 2004
    Chambersburg, PA
    A different recirculating valve is pretty much pointless unless the stock valve isn't holding the boost you're running. Other than that there really isn't any point since recirculating valves are silent just like the stocker.
    As far as your fuel pump and injectors go, they are definately part of the equation for a nitrous setup, but you definately need some engine management to make it all work properly. Personally, I wouldn't try it at all. It's very easy to run ultra mega lean with nitrous on a naturally aspirated motor as it is. Throwing nitrous into a forced induction situation just makes it that much harder to maintain a decent A/F ratio. The money spent on a nitrous system could be much better spent towards the cost of a turbo upgrade.
    ΜOΛΩΝ ΛΑΒΕ
  8. #5993
    Oct 2005
    every where
    im not trying to stay silent. i know that an aftermarket blow off valve that recuculates makes noise. i have 3 friends with EVO 8's and they all have BOV's that recerculate. they say that when they had BOV's that just blew into the atmasphere there idle droped ofter they would blow off and stop then it would come back to normal around 500 RPM
  9. #5994
    Registered User DjMarkOne's Avatar
    Aug 2003
    LAS VEGAS, NV
    oem is your best bet. but from what dave @ kingpin says, around 17-19 psi the oem bov will leak.
  10. #5995
    Registered User overboost's Avatar
    May 2004
    NY
    ok so here is what i got.i dont have any instractions and because i ve been searchin all over the forum and i cant figure out what goes where .please if someone knows help .thanks
    you can't arrest me am'a rock n roll star!!!
    RALLY ACROPOLIS-GREECE
  11. #5996
    sid
    sid is offline
    Registered User sid's Avatar
    Texas
    -the solid metal plug goes to the recirculation hose.
    -the vacuum hose that's plugged into the stock bov goes to one end of the plastic filter, use one of the rubber hoses and plug into the other end of the plastic filter, the other end of that rubber hose goes to your after market bov.(you could probably shorten that rubber hose to make it fit better)
    -those two metal sleeves, you shouldn't need them
  12. #5997
    Registered User wrxtuner2006's Avatar
    Oct 2005
    Pennsylvania
    You don't have to be an ASE certified mechanic to figure it out.
    First unbolt your stock BOV (i hope you know what that is).
    disconnect it from the hose then The cyclindrical soild thing goes into your return pipe to your turbo charger. (aka the red thing below the bov in the pic) this goes into the hose
    You should only need one of the hoses if your bov is like mine and that it going to connect to the nipple on the bov and on the place where the stock bov connects to the pressure measurement gauge via a 90 degree angele hose on the stock BOV.
    On second thought just search the net and find out how because i doubt you are understanding what i am telling you. sorry i couldn't help more
  13. #5998
    May 2004
    NY
    Quote Originally Posted by wrxtuner2006
    i appreciate your help...but take it easy genius
  14. #5999
    Registered User wrxpaul's Avatar
    Jan 2003
    Apple Valley, California (the boonies)
    The money can be spent better else wehre but my inner ricer came out and i got the hks haha i havent noticed any problems with it just a few pops in the exhaust but they sound cool so i try not to worry about them..i couldve spent the 200bucks on something else but ehh
    07 S2000..vortech..kw..comptech..volk
    previous
    05 Evo traded
    05 S2000 rip
    05 STi traded
  15. #6000
    Registered User killthelights14's Avatar
    Mar 2005
    pittsburgh
    here ill post a video of me driving without silencer. you can hear the turbo spool up loudly, and when i get off the gas fast you can hear it go...."pshh" lol. youll like it. hopefully nothing is wrong with my car.... lol.
    but ill post the video later on today
    02 wrb wrx stock turbo fmic 26 psi (it can be done)
