"The BIG BOV thread" (Where all bov question threads get merged) - Page 40
Page 40 of 798 FirstFirst ... 30313233343536373839404142434445464748495090140540 ... LastLast
Results 586 to 600 of 11961
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Subaru says its designed for up to 23 psi....that probably means that 23 psi is about 80% of capacity. GFB's ...
  1. #586
    Mar 2002
    Calmer than you are
    GFB's BOV is rated for 100 PSI
    ...and if you figure out how to run 100 PSI on a Subaru motor....ANY Subaru motor I'll buy you a Krispy Kreme donut.
    go f*** yourself
  3. #587
    Moderating YOU
    before you had your Subaru!
    Verdugo's Avatar
    Jan 2002
    Sea-Town, WA
    Originally posted by twinz
    I agree with Jim, I have had no drivability issues at all using the APS dual vent BOV. it works very very well. I have it set so it only blows off to atmosphere under hard full throttle/full boost shifts..otherwise it just recirculates like the stock BOV. It definitely does help keep the turbo spooled up between shifts, keeps the engine right in the power range.
    How exactly do you set it to do that, anyway? You two are the only two I know who talk about the APC BOV...
    Armin - ClubWRX Admin/Moderator since 2002
    Vice President and Editorial Manager, NWMotiv.com
    Photography Portfolios: ArminAusejo.com | ArminWeddings.com
    President, Project One Car Club
    02 WRX "EVA-00" | 15 Audi S3 "Ella" | 2010 A4 (traded in) | 02 M3 "M-Thrizzle" (traded in) | 08 STI "Blaze" (sold)
    djrez4 is a genius | ScoobyDMC #010
  4. #588
    Mar 2002
    Calmer than you are
    the body of the valve turns which pre-tensions the spring that holds the valve closed...so you can vary the pressure at which the valve opens...I don't know what happens if you set it too stiff and the valve can't open...you might get some compressor surge (really really bad).
    go f*** yourself
  6. #589
    Registered User Quantum-Racing.com's Avatar
    Jan 2002
    Columbus, OH
    It still sounds like a push type. I have an HKS and I've had GReddy in the past, not to speak of other people's cars I've dealt with. I would first check to make sure none of your boost gauge lines are opening when you hit x boost. It very well could be the BOV. I don't believe 20 psi for the stocker.
    www.Quantum-Racing.com
    Home of the Dynapack AWD Dyno
    Sales Email, Tech Email
    937.642.5400
  7. #590
    Registered User WRXin''s Avatar
    Jun 2002
    Houston, TX
    Blarg--
    What brand of 50/50 BOV would you suggest. I really like the sound of the HKS SSQV BOV, but that's 100% atmosphere. Anything 50/50 out there sound like it?
    Fahd
    Floats like a butterfly and stings like when I pee!
  8. #591
    Jun 2002
    sumter, sc
    Boost Gauge Prob, I Think!
    anyway, i know this isse has been brought up many times before but i need some peace of mind and clarification. i finally installed my boost gauge and bov today. and my readings seem kind of strange. i have a phantom mechanical boost gauge (PSI). when my car is off its at 0. at idle it reads 16 in vacuum area. in first when i accelerate it makes it to 5 psi. second makes it to 8-10 psi. 3rd makes 14psi. 4th makes 10psi and 5th ?????. anyway when i am crusing not accelerating the car is in the vacuum area around 15. is this normal? should i contact someone about returning my gauge. waht are othere peoples readings? please answer me and all help is appreciated. thanks
  9. #592
    Registered User pace's Avatar
    Sep 2001
    Brook Forest, Colorado
    The Go Fast Bits BOV is 50/50 and I believe that APS have a dual vent BOV also (ask Platinum about it).
    -Pace
  10. #593
    Sep 2001
    Re: Boost Gauge Prob, I Think!
    Sounds a little odd. You should be reaching at least 10psi in first gear, and you should be achieving the highest boost in 5th gear. Where did you tap for the boost signal??
    -Pace
  11. #594
    Sep 2001
    Could you clarify that last statement?
    -Pace
  12. #595
    Registered User djrez4's Avatar
    Colorado
    now here's a question.....if all of my boost taps are right there at the blow off (so i can't just diconnect the hose), can i somehow run the hoses so i get 50/50?
    Deliberating enclaves of like-minded people are often a breeding ground for extreme movements - Cass Sunstein
  13. #596
    Aug 2002
    San Mateo, CA (San Francisco)
    BOV... worth it?
    Is it worth it to get an aftermarket bov? I heard that it reduces milage by 10-30 miles
    /z
  14. #597
    Registered User michaelwrx's Avatar
    Feb 2002
    Melbourne Australia
    Re: BOV... worth it?
    /z
    Crap and more crap....you only get a BOV for the noise (albeit unless you run HIGHT boost - I mean major mods)
    Just a waste of $
    01 WRX World Rally Blue
  15. #598
    Registered User Flyboy's Avatar
    Mar 2002
    9200' Golden, CO
    Save your money for something worthwhile.
    2011 SWP Premium Hatchback
    Flapatax Mud Flaps
    Kartboy STS with front and rear bushings
    Cobb AP Stage 1 (for now)
  16. #599
    God
    God is offline
    Registered User God's Avatar
    Aug 2001
    Detroit, MI
    It's fun and I like mine but if you're on a budget don't change it yet unless the sound is worth it to you. No need and doesn't give you any HP.
    Daniel Ponze, Lead Tuner Tuning Factory, Inc.
    PH: (248) 477-0700___FX: (248) 477-0701
  17. #600
    Moderating U! KurleeDaddeeWRX's Avatar
    Mar 2002
    San Jose, CA
    BOV does nothing for performance for your car. It is just a noise maker. Makes your car sound like a diesel truck with the "psssshhhhttttt." There are very many people that by a BOV and sell it the next month. I had one for a couple of weeks and sold it. Plus if your running your BOV at 100% atmosphere, your car will run very rich, and you will get awful gas mileage. Just my$.02. There are better and cheaper things to buy for your car that improves horsepower. Get a MBC and a boost gauge for the same price of a BOV.
    Kurlee Daddee
    (THE ORIGINAL)
