Page 4 of 777 FirstFirst 123456789101112131454104504 ... LastLast
Results 46 to 60 of 11651
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; You will barely be able to see the injectors once installed. They are tucked away. I'l take pics of the ...
  1. #46
    God
    God is offline
    Registered User God's Avatar
    Aug 2001
    Detroit, MI
    You will barely be able to see the injectors once installed. They are tucked away. I'l take pics of the intercooler though.
    Daniel Ponze, Lead Tuner Tuning Factory, Inc.
    PH: (248) 477-0700___FX: (248) 477-0701
  2. #47
    Registered User black99gt's Avatar
    Nov 2001
    Columbus and Cleveland Ohio
    cool, can you take pics of the inj. before the install tho.. a few of them So i have some goals to shoot for you know
  3. #48
    God
    God is offline
    Aug 2001
    Detroit, MI
    The engine? It actually doesn't look that interesting folks. I just don't have an airbox or heat shields on the turbo. Otherwise looks stock. The dealership guy didn't even know I had a different turbo. Super cool guy too. He wants me to get him a BPU package for his sister's car.
  4. #49
    Registered User Si2WRX's Avatar
    Aug 2001
    Atlanta, GA
    What's a BPU?
    Erik
    '02 Subaru WRX
    12.73@108.32
    287whp/277wtq
  5. #50
    God
    God is offline
    Aug 2001
    Detroit, MI
    Basic Performance Upgrade
  6. #51
    Apr 2001
    Colorado Springs, CO.
    Forge BOV noise???
    I recently installed a Forge atmospheric BOV. When I'm driving the car and let off the throttle I hear a stuttering, multiple "psst, psst, psst, psst" instead of one quick "psst". I assume this means I have the wrong spring in the valve. Does this mean the spring is too strong or too weak? I was told the valve had the blue spring. Has anyone experienced this noise and if so, what spring/spacer combo have you had to use to fix this?
    thanks,
    Punk
  7. #52
    Jan 2002
    In the slow lane
    When I first got mine, it would only release a full blow off at about 5-6k rpm. At anything lower, it was just a sputter. You need to get your hands on a weaker spring for the BOV. Contact the retailer you purchased it from, and they will send you the spring. I assume you got the bov from Atmosphere???
    02 WRX WRBP sedan..
    Upgrades??? stock...
  8. #53
    Apr 2001
    Thanks Jigga - Forge is sending me the springs.
    Punk
  9. #54
    Jan 2002
    Binghamton NY
    i have been looking at this bov...have you been happy with it. did you get the external venting...i am not sure which to get and whic one is better
  10. #55
    Registered User JDMario's Avatar
    Sep 2001
    San Fernando Valley / San Luis Obispo
    my blitz has been doing that often ever since i put in synthetic. it usually doesit going up little inlclines like freeway onramps
    free food is the best food
  11. #56
    Nov 2001
    Laurel, MD USA
    My Forge BOV does the same thing. It stutters if it vents at less than half of full boost. After installing an MBC it stutters less since I reach full boost sooner.
    Dale
  12. #57
    Registered User BigRich's Avatar
    Aug 2001
    Lexington Park, Maryland
    I have on of those GFB BOV's set at 100% vent. This same problem has been with me since day one of the install. So the spring is to strong? That is the problem? Is the BOV itself making the noise or is it something else? I swear the noise is coming from the passenger side.
    -- Rich
  13. #58
    Jan 2002
    King of Prussia, Pa
    Turbo XS BOV? What are your thoughts.
    I had one on my car for a while and I liked the noise it made and all. But I did not like the lag that it gave me inbetween shifts. It seemed like I had to really make sure I gave it a good amount of gas before I let the clutch back out. Also the car runs rich, so much so that you can see the tail pipes getting dirty from the unburned fuel.
    My question: Does this only occur with the Turbo XS BOV or will this happen with any 100% Atmospheric BOV? Is there another BOV out there that is better?
  14. #59
    Registered User BamBooI's Avatar
    Oct 2001
    Milky Way Galaxy
    tail pipes get dirty? Do you mean the inside?
  15. #60
    God
    God is offline
    Aug 2001
    Detroit, MI
    As for the excess fuel, that is normal. The stock ECU dumps way too much fuel in which is why the Unichip takes out fuel if you have the stock turbo.
