"The BIG BOV thread" (Where all bov question threads get merged) - Page 391
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; hey, same noise, without the disadvantages! and you can put it on your OTHER car, your bike...heck you could just ...
  1. #5851
    Mar 2002
    Calmer than you are
    hey, same noise, without the disadvantages! and you can put it on your OTHER car, your bike...heck you could just carry it walking down the street and people will think YOU have a BOV.
    go f*** yourself
  3. #5852
    Registered User lordcon's Avatar
    Sep 2005
    Abingdon MD
    Quote Originally Posted by blarg
    i may just get a short ram intake, i suppose that will make it louder.
  4. #5853
    Registered User cheeseybacon's Avatar
    Jul 2004
    Chambersburg, PA
    Quote Originally Posted by lordcon
    Do a search for intakes. They have their fair share of problems as well.
    ΜOΛΩΝ ΛΑΒΕ
  6. #5854
    Sep 2005
    Abingdon MD
    Quote Originally Posted by cheeseybacon
    well i read that cai have problems, but stuff like the k&n typhoon short ram which have their own heat shields look harmless....
  7. #5855
    Registered User CyberneticEmcee's Avatar
    Sep 2005
    LoL
    If you have an exhaust you won't be able to hear the intake. LoL. I like the tread about the making the noise with the mouth though. LoL. Now that's original. LoL
  8. #5856
    Sep 2005
    Salt Lake
    Blow Off valves
    Im getting an STI very shortly and I want to buy blow off valves first thing, just wondering if anyone else has done this and would recomment a brand.
  9. #5857
    Jan 2005
    OC
    uhm, im just a wrx owner, but i'd recommend getting something else then a bov. maybe, tbe? just my 2 cents.
  10. #5858
    Oct 2004
    Kent, WA
    keep the stocker on.
    use the money on sumthing better than bov.
    03' C i
  11. #5859
    Oct 2004
    Kent, WA
    i'm loving mine..
    it used to be wrapped in STi wrinkled red,
    but i scraped'em all off.. since my car wasn't so "STi'-ish. xD
    Time to get some new stuff for my car..
    03' C i
  12. #5860
    Sep 2005
    Australia
    Talking
    I assume that the USDM has the same ECUs setup as the AUS spec models, If so you have to use either a full plumback BOV or DUAL port to route the air back to your turbo inlet.
    Stock is only good for 15Psi over that and then it acts as a pop off valve, you can still produce more than 15psi eg 17+ but your turbo will work harder to do it....
    Running too rich is not good for your car either, In most cases in AUS spec you must do an ECU upgrade to see any major benefits from exhaust ,Filter and other accessories.
    I would bet your cars are the same...
    Are you guys seeing the same thing when you Dyno your cars after these types of Mods?
    Running RICH.
    What RON fuel do you guys run on?
    Gday from OZ.
  13. #5861
    Sep 2005
    Australia
    VF34 should also run about 400hp at the crank, its Not hard to get 300hp from a TD04.
  14. #5862
    Registered User bobbo's Avatar
    Sep 2005
    Boston
    Blow-off hose
    i got an hks blow off valve and when i took my stock one off theres a large hose that leads to my intake and clamped on to my stock blow-off. my new one doesnt have the hole for that hose.. it just attaches to my intercooler.. what should i do with that hose? is it ok to not use it?
    12.1 @ 117
  15. #5863
    Registered User crazycam31's Avatar
    Jul 2003
    Colorado
    Plug it. Thats the difference between stock and an atmospheric BOV. It will make you run rich during shifts. You make the judgement call if you want to run the BOV....
  16. #5864
    Sep 2005
    Boston
    what will running rich during shifting do? i plugged the hose and the BOV is working.. it may be just me but when i shift it feels like my rpms go down faster.. and when i give it gas an let off fast i hear the BOV and then a single POP from my exhaust..
    12.1 @ 117
  17. #5865
    Registered User bmxdave's Avatar
    Jun 2004
    Now Fayettenam, NC
    It doesnt really hurt anything but it will probably foul your spark plugs a bit earlier than normal. The recirculation of the stock bypass valve is rumored to keep the tubo spooled in between shifts, therefore more air -- more fuel causing the richness inbetween shifts. That extra little bit of fuel is being expelled into your exhaust and is likely ignited inside causing a "pop" and more than likely a visible flame from your exhaust tip.
    Mods - Perrin Uppipe, Crucial Racing Downpipe, SPT/Bosal Catback, Samco IC Hoses, Cobb Stage 2, K&N Panel, GPMoto Intake Elbow.
    www.negativesource.com
