"The BIG BOV thread" (Where all bov question threads get merged) - Page 369
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Ok i can not hear the bov that good and i want to see how rough it runs with the ...
  1. #5521
    Registered User Turbo_neon's Avatar
    Aug 2004
    Question Greddy Type S bov ques. . .
    Ok i can not hear the bov that good and i want to see how rough it runs with the recirculation hose off. The reason i am starting this thread is because i am not sure if i have to tie off the hose that i pull off or what? It seems to me that i would have an intake leak if i left it open but i have no clue maybe you guys know more than me.
    Thanks,
    Jake
  3. #5522
    Jul 2004
    Boulder, Co
    I don't recirc on my legacy, it just bogs a little after a hard shift at wot. Bottom little hose goes to the intake side of the turbo, top little hose goes to the manifold, then you have to adjust the top screw. You will need to plug the hole in the intake where you are recircing to tho otherwise the car is really gonna run like crap.
  4. #5523
    Aug 2004
    thats what my main question is, what do i use to plug it?
  6. #5524
    Registered User bklSTi's Avatar
    Dec 2004
    littleton, colorado
    You could prolly find something homedepot..
    My friend found a plug there....just a thought..
    good luck!.
    04 Pearl Black STi-
    GT35R...
    *88 Mustang Foxbody-
    Not Stock!!=475RWHP
    Get some kneepads and open your mouth
  7. #5525
    Jul 2004
    Boulder, Co
    Yeh, i have a rubber plug on mine. Got it from the hardware store in the plumbing section. Its a rubber cap with a clamp around it. Don't use duct tape lol
  8. #5526
    Jul 2005
    Now........ I've received this BOV in the mail and installed it. I noticed that there was no gasket with it. There wasn't one in the stock one either when I removed it. Is it me or metal on metal leak?? Do I need to make a gasket for it? The only reason I noticed was because at full throttle, the boost dropped in the gauge. Is this normal?? Does the actual valve part of it leak or could it be the fact there is no gasket between the two surfaces? I tightened both bolts snug with caution. I didn't come with a cap for that hose that goes back into the turbo. I took care of that hose with a rubber plug and installed the BOV . It also sputters in low boost. Is that common?? Is that where these washers come in handy?? I only paid $60 bucks for it. The stock BPV is in mint condition and I can put it back if thr new BOV does't cut it. Thanks guys for your thoughts.
  9. #5527
    Registered User WRXskier's Avatar
    Apr 2004
    Allentown Pennsylvania
    I think if it was a leak from a lack of gasket, it would make noise (maybe a screaching noise).
    -02 WRX w/built 2.5
    -Stage 4+FMIC
    -STI RA gearset
  10. #5528
    May 2005
    North Cali
    Tial BOV sounds good
  11. #5529
    Registered User InfamousDX's Avatar
    Jan 2003
    Bergen, NJ
    Quote Originally Posted by Mars
    Did you check the stock BPV for the gasket? Usually when you remove it the gasket sticks to the stock BPV, not the IC. Just a thought...
  12. #5530
    Jul 2005
    Im tired of the same BOV Question, heres another one =)
    I just bought a WRX yesterday, has a whooping 228 miles on it. I am starting to think of mods, but mainly all bolt ones. Quick BOV Question. I searched alot of bov threads and all of them are complete junk. I really dont want to hear what you "think" i want to hear what you "know" Please no "Ive read... My friend says... This website says..."
    I am planning on getting a BOV that will be Vented Back into the intake. The TurboXS type H is one of them i believe. Now, i want to make 100% sure that this will act exactly the the stock one other then giving my car a cold (ahhhhhhhpsst)
    Also, if anyone has any other recommandations on BOV please do tell.
  13. #5531
    Aug 2004
    one other thing is it really bad when you shift at wot with no recirc.? Is is very tolerable, tolerable or annoying?
    thanks again
  14. #5532
    Jul 2004
    Boulder, Co
    No, its not that bad when you shift. I tend to get a good sized flame coming out the exhaust but you shouldnt have any problems. Best thing to do is to try it and find out. Rubber plug from the hardware store will probably run you about 2 or 3 dollars, not a big loss if you do decide to go back to recirculating.
  15. #5533
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    OK..I know you'be been here way to long not to be able to use the search function. Stop being lazy.......
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
  16. #5534
    Registered User WRXout's Avatar
    Dec 2003
    Houston
    Quote Originally Posted by YBNormal07
    yes suir, i bought the hks P
    Fadi....
    • 04' WRX, Stage 4 with fmic R.I.P
    • 05' WRX STI, 325whp 346wtq @17psi
    MODS
    Quote Originally Posted by Trailboss
    Enough of the bloody titties show.
  17. #5535
    Pittsburgh, PA
    Ok, i just did a search and found out everything i needed to know about this in detail especially from godspeed and midknight's postings about them. BOV's, if that is your only mod...is worthless...if you want to drop 200 some on a nice dual vent hybrid bov for the sound then go right ahead....performence wise its going to make your car run rich in between shifts because your spitting air back into the intake...but people put stickers on their car all the time and I hear that adds 15hp so it might give you some gains . My recommendation is to wait until you get a cobb accesport and the full exhaust and tune it that way first and then ask the professional if he recommends on getting one because the stock one you have is perfect...especially if you arent yanking out the turbo and putting a bigger one in anyway.
