"The BIG BOV thread" (Where all bov question threads get merged) - Page 365
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; i have never done it ( not yet). this guy is a reputable member of clubWRX who moved on to ...
  1. #5461
    Registered User IronMedic's Avatar
    Jan 2005
    Puyallup WA
    i have never done it ( not yet). this guy is a reputable member of clubWRX who moved on to other cars. i prefer to keep his name quiet so he doesnt get any flames. he told me he used 2 washers on his BOV spring. he also told me that most people use 3-4 but 2 worked fine for him. a guy at a local performance shop does the same thing but uses 10? LOL! he says it works great for him so whatever works on his race car (its a track car only).
    2005 Nissan 350z roadster
    Originally Posted by BrianH
    I can hit 10K more posts before a neon R/T will hit 60mph.
  3. #5462
    Jul 2005
    Quote Originally Posted by Blue EJ20 WRX
    With stock BPV: Air gets metered by MAF, certain amount of fuel is added, BPV recircualtes air into intake, everything is fine.
    With an atmospheric blow off valve: Everything happens the same, except the air gets vented into the atmosphere, and there is too much fuel and not enough air. This means you run rich into shifts and when the throttle is quickly let off under boost. I hear it also takes longer to build boost after you shift since the air doesn't keep the turbo spooling. I'm not sure about that, and some people disagree with it.
    Close but not all the way there. A BOV is used to decrease turbo lag. As you said the stock BOV recircualtes the air from the turbo into the intake system. Many people also say that some of the built up pressure gets thrown back to the turbo when you shift or let off the gas causing the turbo to stop spinning which means when you get on the gas again you have no boost coming from the turbo and in turn run into turbo lag. With an aftermarket BOV all the built up pressure is released when you let off the gas and it alows the turbo to keep spinning which leads to much less trubo lag...But it is true that by replacing the stock BOV you will run into full/air mixture. It can lead to the car running rich. If you are looking to do a BOV I would also look into getting some sort of Air/Fuel control system so you can correct the problem an aftermarket BOV can create.
  4. #5463
    Jun 2005
    What BOV is this?
    What BOV is this in the video?
    Click Here
  6. #5464
    Registered User rickyh's Avatar
    Apr 2004
    Metairie, Louisiana
    I believe that is a txs rfl. That is the world one sti.
  7. #5465
    Jan 2005
    Puyallup WA
    yeah i believe it is the RFL-H BOV. that is the one they used in their RFL-Ti exhaust clip
  8. #5466
    Jan 2005
    Puyallup WA
    Quote Originally Posted by Lancenig
    wouldnt a UTEC do the corrections?
  9. #5467
    Registered User thedoc092's Avatar
    Jun 2005
    Buffalo, NY
    It sounds pretty good...does anyone know about the Worx BOV...i heard its one of the best, and i heard a clip once, and it sounded sweet. Im gonna need a new one when i upgrade my turbo next spring, im trying to plan out what im gonna get now...any recommendations?
  10. #5468
    Registered User BlueCamel's Avatar
    May 2005
    Smithfield,RI
    Quote Originally Posted by IronMedic
    or anyother EM in that matter? would be intresting to know
  11. #5469
    Registered User RHONE's Avatar
    Jun 2005
    whittier
    Quote Originally Posted by Mars
    Is this "shimming" for most bov's?? this thing is coming in the mail this week anyways. I'll give it a shot. Not like I'm throwing the stock one away. I'll keep you guys posted.
    Also, which pipe should I get first? Up or down? does it make an immediate difference??
    Thanks again.
    well from what i've read if you are going to run a bov your most major concern is that your up-pipe cat is going to start breaking up and sending parts of it into your turbo, so a catless up-pipe would be smart, you should probally do up/dwn at the same time.
  12. #5470
    Jul 2005
    Indianapolis
    need help with my BOV! its weiiirrdd
    ya well everytime my BOV goes off it sounds like a horse, is it on too tight? cuz its definatly not too loose, its a Blitz BOV. it should be loud and normal
    it sounds like " brrr-rrrr" like a horse.......
    any suggestions?
    thanks
    -cam
    p.s. i know about how BOV's hurt WRX's so thanks anyway. lol
  13. #5471
    Jul 2005
    Indianapolis
    BOV making wierd noises
    any suggestions?
    thanks
    -cam
  14. #5472
    Registered User Blue EJ20 WRX's Avatar
    Dec 2003
    Orange, California
    Actaully, that's Ivan's old WRX in the RFL-Ti video, and it was the HKS blow off valve.
  15. #5473
    Jul 2005
    Indianapolis
    goddamn someone help me
  16. #5474
    Registered User le wagon's Avatar
    Jul 2005
    SoCal
    well i dont know, but the best thing you could try doing is loosening/ tightening it until it sounds right.
    i tried.
    EVO III 16g'd wagon
    stock tranny goin strong
    .. already ready for a bigger turbo
    Quote Originally Posted by chanwahyaoh
    Sometimes after I go poo, I just blank out and mindlessly continue my upward wipe all the way up the small of my back and end up smearing brown all over myself. Just kidding. That sucks about your laundry though...
  17. #5475
    Registered User deegan42's Avatar
    Sep 2004
    Miami
    it sure didnt sound like my HKS SSQV. but it sounds like this guy knows what he is talking about.
