"The BIG BOV thread" (Where all bov question threads get merged) - Page 364
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Sell it or return it if you can once it gets to you....
  1. #5446
    Registered User makalu's Avatar
    Jul 2005
    Minnesota/Colorado
  3. #5447
    Registered User IHRTWRX's Avatar
    Mar 2005
    NOR CAL
    Yep Id send it back too. I would dump that intake too. Save it till you are more modded. Stock isnt too good.
  4. #5448
    Mar 2005
    I don't actually understand what a blow off valve does and/or why it is useless or even bad. I know that it makes excess noise, but how and why is this bad for power delivery overall?
  6. #5449
    Registered User KoreanBeefcake's Avatar
    Jul 2003
    Huntsville, Alabama (formerly WA)
    Quote Originally Posted by wrxamateur01
    its your car, do what you want. if you beleive your car runs fine with it, then just use it. and if for some reason it doesnt work right, recheck your work.
    a few things off of ebay have been some great buy parts. id like a review.
  7. #5450
    Registered User IronMedic's Avatar
    Jan 2005
    Puyallup WA
    the intake wont do anything bad to your car so dont worry about it. i am running a perrin short ram and it is not causing a single problem with my car.
    as for the BOV, give it a try.. you might like it or get lucky with it! life is too short to not try things
    2005 Nissan 350z roadster
    Originally Posted by BrianH
    I can hit 10K more posts before a neon R/T will hit 60mph.
  8. #5451
    Registered User Blue EJ20 WRX's Avatar
    Dec 2003
    Orange, California
    The atmospheric Blow Off Valves are the ones known to have problems. Why?
    With stock BPV: Air gets metered by MAF, certain amount of fuel is added, BPV recircualtes air into intake, everything is fine.
    With an atmospheric blow off valve: Everything happens the same, except the air gets vented into the atmosphere, and there is too much fuel and not enough air. This means you run rich into shifts and when the throttle is quickly let off under boost. I hear it also takes longer to build boost after you shift since the air doesn't keep the turbo spooling. I'm not sure about that, and some people disagree with it.
  9. #5452
    Registered User BlueCamel's Avatar
    May 2005
    Smithfield,RI
    Quote Originally Posted by Blue EJ20 WRX
    i was thinking of the HKS BV is it atmospheric or not?
  10. #5453
    Registered User RHONE's Avatar
    Jun 2005
    whittier
    i ran a bov on my car for a few months, the major difference was i would loose boost very fast and never really hit peak boost, i also noticed a small backfire between shifts, and no power past 5000rpm. i got rid of the bov and aem intake and everything is normal car runs better than ever. you can run these parts if you want you probally won't do any damage to your car but it might not run to full it's potiential. if you are going to use them, make sure you have a boost gauge and learn how to read it, thats how i found out the parts wern't helping any. good luck!!!
  11. #5454
    Dec 2003
    Orange, California
    Quote Originally Posted by BlueCamel
    The HKS blow off valve is 100% atmospheric. But you can get a recirculation kit. The HKS is one of the blow off valves that usually causes less problems.
  12. #5455
    Registered User crazycam31's Avatar
    Jul 2003
    Colorado
    I have a GFB and out of the 3 BOVs i've run it is the best.
  13. #5456
    Jul 2005
    Arrow WTB: Greddy Type S BOV
    hey guys, im lookn for a greddy type s bov kit for my 04 rex. lemme know.
    also i need the recir. hose with the kit. unless it uses the stock one.
  14. #5457
    Jul 2005
    Quote Originally Posted by IHRTWRX
    Why do you think I should remove that intake? I noticed that it holds boost a lot better than stock. My car came with the boost gauge and before the intake it would reach full boost and the needle on the guage would bounce back a little. Now it stays once I reach full boost. Maybe it's my imagination but I think it helped. I also had the cat back installed the same day....... Gotta love the sound of that boxer at work....... Anyways, what should my next mod be?? I joined this forum cause I know you guys have tried and researched parts as well as compared notes.
  15. #5458
    Jun 2005
    whittier
    you will loose a little boost i think all cars hit peak boost then drop off alittle, the better performance you are seeing is probally coming from the exhaust not the intake, i ran a aem for a while and saw no noticiable ill effects but i took it off just to be safe, because i thought the same thing about the bov, it seemed to run fine but it wasn't. it's up to you, you can run the bov just make sure it is not hindering your performance, you might want to complete you exhaust for your next mods maybe go with a up/dwn pipe then some kind of engine management before using an intake and bov, try putting the stock air box back on and removing the silencer maybe a k&n drop in.
  16. #5459
    Jan 2005
    Puyallup WA
    i was told that u can add washers to the BOV to help it out so u dont have such problems like most people say. a guy i bought my turboXS stage 2 kit from said that to me and he never ever had an issue with his BOV after shimming the spring
  17. #5460
    Jul 2005
    Quote Originally Posted by IronMedic
    Is this "shimming" for most bov's?? this thing is coming in the mail this week anyways. I'll give it a shot. Not like I'm throwing the stock one away. I'll keep you guys posted.
    Also, which pipe should I get first? Up or down? does it make an immediate difference??
    Thanks again.
