"The BIG BOV thread" (Where all bov question threads get merged) - Page 362
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; O thanks but i didnt make it my friend gave it to me...
  1. #5416
    Registered User Fox05's Avatar
    Jun 2005
    Valdosta G.a.
    |^^^^^^^^^^^^^^| ||_____
    |.........Beer................| ||.....'|";\,___.
    |_...__...______...__..._|_||_|__|__..._|
  3. #5417
    Administrator
    May 2003
    Quote Originally Posted by rickyh
    Yeah, there is a small bit of surge, but it is the only way to stop the idle from dropping. I modded the stock bov to hold more boost, and it surges like a mofo. That's the main reason I'm currently using the rfl. I have an apexi twin chamber on order for the fmic thats going in.
    What turbo are you running?
  4. #5418
    Registered User rickyh's Avatar
    Apr 2004
    Metairie, Louisiana
    vf39. My stock bov wouldn't hold any more than 17 psi or so. It would struggle to hold 18. I modded the stocker, and now it holds allthe boost I want, but the compressor surge is kinda bad. I picked up an rfl pretty cheap, put a bunch of washers in it, and now it holds 19 psi just fine. It surges a tiny bit but it isn't bad.
  6. #5419
    Administrator
    May 2003
    That's odd. My stocker holds perfect at 18psi with my VF34. You should just pick up another stocker for $20.
  7. #5420
    Registered User CruzWRX's Avatar
    May 2005
    Baldwin Park, CA
    Did you ever get your bov from them??? I have to say Worx Tunning has the worst service.
  8. #5421
    May 2005
    Baldwin Park, CA
  9. #5422
    Registered User wrxaddicted's Avatar
    Mar 2005
    Southern Cali
    BPV / BOV question
    BPV / BOV Question: Is the IC mounting flange the same for the WRX and STi? I tried searching with no luck.
    thanks for the help,
    Steve
  10. #5423
    Feb 2004
    Evansville, IN
    yes, identical...
    1988 Celica Alltrac
    Hallman Pro, 15x7.5 +20mm Rota Slipstreams
    2005 LGT 315whp/340wtq@21psi - Sold
    VF52, Crucial P&P&C Manifolds, UP, DP, RP, Magnaflow CBE, Hallman PRO, ROMRaider
    2003 WRX 371whp/355wtq@24psi - Sold
    TD05H-20G-38mm Tial, Meth Injection, Hyperflow TMIC, ROMRaider
    Dyno Chart METH vs 93 oct
  11. #5424
    Mar 2005
    Southern Cali
    Quote Originally Posted by testes1010
    yes, identical...
    thank you kind sir.
  12. #5425
    May 2004
    Greeley
    BOV + Not Plugging the Recirc Hose
    Hey, curious here, what would happen if you installed a 100% atmospheric BOV, but failed to plug the Recirc Hose? Would you run lean?
  13. #5426
    Mar 2002
    Calmer than you are
    Quote Originally Posted by caz5511
    yes. you'd also be sucking unfiltered air into your motor.
    and your car would run even WORSE because not only would you be losing metered air when the BOV opens, but you'd be getting EXTRA, unmetered air under vaccum.
    go f*** yourself
  14. #5427
    May 2004
    Greeley
    So if i had mine installed that way, and then i got dynoed and was running very lean, thats most likely the problem?
  15. #5428
    Mar 2002
    Calmer than you are
    probably. depends on what other mods you have. I would definately either plug the return hose or just quit screwing around with ricemods and put the stock BOV back on. You could do some serious damage by both running lean and sucking some kind of crap into your motor through that open hose.
    go f*** yourself
  16. #5429
    May 2004
    Greeley
    yeah.... i already have it back to 100% recirc. running catless up and down pipes, removed silencer w/ a K and N
  17. #5430
    Mar 2002
    Calmer than you are
    EM coming next?
    go f*** yourself
