"The BIG BOV thread" (Where all bov question threads get merged) - Page 355
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; The recirculation hose isn't the one on the top, right? Isn't it under the Bypass Valve?...
  1. #5311
    Registered User Blue EJ20 WRX's Avatar
    Dec 2003
    Orange, California
  3. #5312
    Registered User rickyh's Avatar
    Apr 2004
    Metairie, Louisiana
    the stock bpv isn't sprung hard enough to be used as a bov.
  4. #5313
    Registered User PolarisSnT's Avatar
    Aug 2002
    Staten Island, NY
    Quote Originally Posted by rickyh
    They make pills for that
    The recirculating hose is the thick one that runs across the engine into the turbo inlet pipe, not that little vacuum hose.
    Dan- 2004 PSM 5spd
    "Days get shorter, nights get longer, snow gets deeper, life gets better."
  6. #5314
    Jan 2005
    The stock BPV sounds very good actually as a BOV. I have the AEM standalone EMS and running a map based system I just plug the hose and it goes psht loud!
  7. #5315
    Registered User crazycam31's Avatar
    Jul 2003
    Colorado
    The stock BPV is designed to leak a little, so you are making your car run rich.... Thats why it stalls and runs ****ty.
  8. #5316
    Jan 2005
    Quote Originally Posted by crazycam31
    ummm I find this hard to belive since I was holding 16lbs of boost fairly well with the stock BPV. I dont see why it would be "DESIGNED" to leak, that doesnt make sense.
  9. #5317
    Mar 2004
    North East, Wisconsin
    You can dent the top in with a hammer if you want it to hold a higher psi, but it would be a PIA to get back out if you dent it too much. You are better off getting a 100% atmo bov or a variable recirc valve (ie 50% recirc 50% atmo). I have the Forge 100% atmo and I have no idle problems and no lag in between shifts.
    edit: btw, you are by far best off with the stock unit in stock configuation, unless you are running higher psi and the stocker can't hold it.
    Evan
    MY12 WRX Limited hatch - stock, still in break-in
    MY10 Forester Limited
    SOLD - MY03 WRX - PSM; AP Stage 2+up-pipe
  10. #5318
    Registered User airsofter69's Avatar
    Mar 2005
    new jersey
    Forge bov adjustment....
    alright so i got a forge bov...i got it used so i dunno wht spring was in originally but wht spring should i be running....i believe there is red yellow and blue...and there are three shims....im at stock boost levels with an intake. Thanks guys any help would be awesome...
    Pete
    2002 black wrx BuGeYe
    Smokey the bear "Protect our friends damn it"
  11. #5319
    Registered User roo21's Avatar
    Mar 2004
    Ohio
    take off your bov and intake
  12. #5320
    Mar 2005
    new jersey
    Quote Originally Posted by roo21
    yea i know i dont need the lecture...some people have problems some dont....well see...does anyone have any answer i asked for... i just needa no wht spring comes stock.
    pete
  13. #5321
    Registered User Family Guy's Avatar
    Jul 2003
    Memphis TN
    I would contact Forge Motorsposrts, I have one of their BOV's (which works great and I have no problems BTW) they have awsome customer support and will help you.
    Now: 04 WRB STi (stock)
  14. #5322
    Feb 2005
    HKS BOV Help
    Im running cobb stage 1 right now and threw the hks bov on last night. Car ran fine for about 20 minutes, then upgraded to 93 oct stage 1, yes I use 93 octane, and it started missing and I was getting CELs. Tried everything putting it back to stock mode, didn't work. Put the stock bypass valve on and it worked fine. The thing I don't get was I was goin at it for 20 minutes with no problem at all. Why did it all of a sudden do this? Also when I took it off, I heard clicking inside like something was loose? Anyway to fix this.
    BTW - Don't lecture me on BOVs. Thank you.
  15. #5323
    Administrator
    May 2003
    Did you scan the codes that popped up?
  16. #5324
    Feb 2005
    They just flashed on and off when it was misfiring and when I used the accessport to scan them nothing came up.
  17. #5325
    Aug 2003
    Worx BOV or Intake?
    I would like to get more sound out of my STi and am debating on a short ram intake or a type of both rec/atm bov like the worx. What would you suggest? How loud are the worx bov's? Has anyone had any experience with the turbosmart dual port? Which one sounds better/louder? Would I get more sound by getting the bov or the intake, let me know.
