This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; like i said, never had the time to get a dyno nor location. as far as the BOVs, i have ...
  1. #5281
    Banned 05WRX0704's Avatar
    May 2005
    Defense Language Institute, Monterey, CA
    as far as the BOVs, i have the Greddy Type-S and the HKS. iw ould say the HKS with the purple fin is the better of the two.
  2. #5282
    Jun 2005
    Springfield MO
    ok so where would i go to look at some that are for sale wow you guys sure do know your stuff thanks
  3. #5283
    May 2005
    ebay, or maybe in the vendor for sale section here on the board. also ive seen a lot of used BOV posts int he personal section, check there too.
  4. #5284
    Registered User kessler89's Avatar
    May 2004
    NW Ohio
    04sti bov and 03 wrx bov the same?
    just as the title says will they inerchange?
    thanks
    Aspen white/gold 03 sedan *SOLD*
    Aspen white/gold 06 STi STG2 Bailey ProTuned
  5. #5285
    May 2004
    NW Ohio
    bump
    no one knows if the stockers interchange!?
  6. #5286
    Registered User hellafastWRX's Avatar
    Sep 2003
    Huntington, Long Island..... NY
    i believe they are the same, they will swap no problem and hold up tp 19psi reliably
    --Chris
    04 WRX wagon - 304whp Mods - SOLD
    2008 DGM Impreza 2.5i sedan - STi Grille, GTspec cf lip, CTspec cf trunk chrome cover, Perrin shorty antennae
    LISC #3
    www.longislandsubaruclub.com
  7. #5287
    Jul 2001
    Plains of Eastern Montana
    different part #'s but will fit interchangably. I remember reading way back sometime that there was an advantage to the STi bpv- holds more boost? Can't remember.
  8. #5288
    Jun 2005
    Manhattan, Kansas
    Question BOV Recirculation or No recirculation?
    Are there any ill effects from running a BOV with no recirculation?
  9. #5289
    Registered User cavallino333's Avatar
    Feb 2005
    Campbell CA
    ya you'll run rich and sputter between shifts. Don't buy one it's a waste of money.
    FORZA FERRARI
    BLOBEYE SYNDICATE (retired) #13
    Quote Originally Posted by Integra96 View Post
    One day I hope to buy a car that is lubricated exclusively by pure manatee oil.
  10. #5290
    Registered User WMAWRX's Avatar
    May 2005
    Greenwich, CT
    If you crank the boost past 19psi on that Stage IV, then just go get an aftermarket recirculating valve and make it fit. I use an TXS H34 recirculating valve; you can use it up to 25psi and no idle problems. No excuse to run atmospheric except for being obsessed w/the noise.
    New England F4
    FOR SALE!!!
    VF22/FMIC/UTEC/Pinks/ACT/STi RA's/Apex'i N1 Type-V's - Tuned at XXTuning, 270 WHP/ 270 TQ @ 18.5psi. 12.697@ 108.95
  11. #5291
    The Kind Administrator. Watch out for the others Trainrex's Avatar
    May 2003
    I just plumbed my back into the cabin and mounted it on my dashboard so I can really hear teh PPPPSSSSSSHHHHHTTTT!!!! It drives teh wimminz wild
  12. #5292
    May 2005
    Greenwich, CT
    You can actually plug the recirc hose right into a secret slot in the back of the stock headunit, and it will actually play through your speakers. I have mine hooked up to a 15 inch subwoofer; everytime I shift the car actually jumps from the thump. I dropped 2/10's of a second in the 1/4 from the jump (no friction w/the ground = unlimited speed)
    New England F4
    FOR SALE!!!
  13. #5293
    Registered User rickyh's Avatar
    Apr 2004
    Metairie, Louisiana
    I've been using an rfl for a while. It doesn't sputter between shifts. If you are using an atmospheric bov and it sputters between shifts you don't have it sprung hard enough. I run 19-20 psi daily on an alky injected vf39 setup.
  14. #5294
    Registered User RHONE's Avatar
    Jun 2005
    whittier
    i use a PIT atmospheric on my 04 wrx i've noticed no ill effects during idle or between shifts it was my first mod mainly for the sound (my first turbo car) since Ive added a 5zigen mircale fireball exhaust, aem cold air intake, kartboy ss, cusco stb, 18,000 hard miles later still all good. but future plans for APS recirculating and all the mods my money can buy.
  15. #5295
    Registered User Blue EJ20 WRX's Avatar
    Dec 2003
    Orange, California
    Quote Originally Posted by WMAWRX
    Is it really quiet? How loud is it compared to a stock BPV?
