This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; http://www.935motorsports.com/bovmedias.htm I dug out the proper links for the sounds/videos you were trying to check out. It looks like the ...
  1. #5161
    May 2005
    OC, CA
    Hope its not too late...
    I dug out the proper links for the sounds/videos you were trying to check out. It looks like the other one posted earlier is an outdated domain name or something.
    tc.Romulus
    I've got your ultimate driving machine right here BMW... No, I want my ransom first!!!
  2. #5162
    Registered User slowmo's Avatar
    Mar 2004
    Oregon
    My first post was about a downpipe I think.. A downpipe question is just a 'noob' of a post as a BOV question...
    Don't expect the guy to be an expert if he is just purchasing his first scooby...
    We should welcome his ignorance with open arms; and embrace his questions with the knowledge that he will some day possess.
    DON'T BE A JERK!!!
    so what if he is a noob.
    I can't remember what it is.......
    We try to forget
  3. #5163
    Registered User Hot_Dog's Avatar
    Jan 2003
    Albuquerque, NM
    Quote Originally Posted by slowmo
    DON'T BE A JERK!!!
    Then post it in the noob forum, that's all I'm saying. Search, read stickies...then post in the technical forums.
    2003 WRB Sedan. Mods & Pics
    Quote Originally Posted by scooby-x
    OMG!!! Do you want me on my knees or bent over? I love you
  4. #5164
    Registered User BrandonWRX's Avatar
    Feb 2003
    Sharon, PA
    I second the Typhoon, it leans out the car and there is actual evidence it gives around 12whp. On wrxs intake are indeed worthless. The BOV will only be for sound, and in some cases will actually cause a decrease in power.
    MY MODS
    *GET YOUR CLUBWRX KEYRING*
    http://clubwrx.net/forums/showthread.php?s=&threadid=54791&highlight=keychai n
  5. #5165
    Mar 2004
    Oregon
    Quote Originally Posted by BrandonWRX
    The typhoon does raise HP/TQ at some rpm's, at others it causes a decrease in HP/TQ.
    My Perrin Short Ram did allow for a SMALL increase in power. However I did notice it to be more 'sluggish' at times; evidence that the dyno plots are correct.
    I had an HKS SSQV BOV. It sounded really cool, and turned a lot of heads. Downside was that the BOV caused the car to run rich after a shift; because the air that was normally re-plumbed into the turbo, was released into the atmosphere. This meant the turbo had to spool up again. After putting the stock BOV back on, I really noticed it pull much harder after a shift..
    Get a silencer delete, and a drop in K&N. You will here the turbo, and the BOV a lot more. Save the $$ for a BOV and spend it on a catless downpipe, as mentioned earlier..
    Catless downpipe will actually make your car go faster, where a BOV is going to make it a bit slower...
    After maket BOV is only necessary when you are running so much boost that the stocker fails... It does sound cool though
    We try to forget
  6. #5166
    Feb 2003
    Sharon, PA
    The dyno charts Ive seen showed an increase at all rpms and a 12whp increase in the upper rpms? The increase was only 1-2 whp down low and it gradually increased as the rpms did. *shrugs*
    MY MODS
  7. #5167
    Mar 2004
    Oregon
    I have already had enough of the intake debate...
    However if you MUST hear my arguement..... The DYNO chart you probably saw was K&N's. I have seen many dyno charts of STi's running just an intake, and most show HP/TQ drops at midrange RPMs.
    K&N's dyno chart is most likely obviously biased.. Ambient conditions can be tweaked to deliver the results they want, so people will buy more intakes.
    We try to forget
  8. #5168
    Feb 2003
    Sharon, PA
    Im sure you have I remember bits and pieces of the thread on imprezawrxsti.com.
    I didnt plan on ever getting an intake, maybe just a panel filter.
    MY MODS
  9. #5169
    May 2005
    Thanks for the info. Whats a silencer delete? And where do I get it?
  10. #5170
    Banned 05WRX0704's Avatar
    May 2005
    Defense Language Institute, Monterey, CA
    search
  11. #5171
    Registered User hellafastWRX's Avatar
    Sep 2003
    Huntington, Long Island..... NY
    no
    --Chris
    04 WRX wagon - 304whp Mods - SOLD
    2008 DGM Impreza 2.5i sedan - STi Grille, GTspec cf lip, CTspec cf trunk chrome cover, Perrin shorty antennae
    LISC #3
    www.longislandsubaruclub.com
  12. #5172
    Registered User speeddr2000's Avatar
    Mar 2005
    jacksonville
    go here and look under engine http://www.visionaryracing.com/
  13. #5173
    Registered User erockWRX's Avatar
    May 2005
    NW Chicago Subs
    which forge bov do I have?
    I'm pretty sure that it is the 100% atmo but i'm not possitive and I don't want to buy a recirculating one if it's what I have already. Under the bov there is a line coming to it but it has been capped off, which makes me think that it's not recirculating. The tubing coming off the left looks like every other pic of this bov that I've seen. This is my first turbo, so I'm still learning how to tell some of this stuff. Thanks everyone.
  14. #5174
    Registered User wrxaddicted's Avatar
    Mar 2005
    Southern Cali
    Quote Originally Posted by erockWRX
    if there is a plug in the re-circ hose on the bottom left of the BOV, then its 100% atmoshpere release.
  15. #5175
    May 2005
    NW Chicago Subs
    thanks, thats what I thought that hose was but I just wanted to verify it.
