This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; take a minute and look at teh stickies on the parts fo teh forum....
  1. #4996
    Registered User br3ez's Avatar
    Apr 2004
    Bergen County, NJ / NEU, Boston
    2005 WRX
    UTEC Stage 2 (Catless)
    250.02 WHP
    249.27 WTQ
    Junior Tuned
  2. #4997
    Registered User scooby-x's Avatar
    Oct 2004
    State of depression
    Dyno tune my man, dyno tune, it fixes all!!!
    04 Java Black Pearl - Sleek Eye
    All you see is my license plate... SCOOBY-X
    Quote Originally Posted by GOD The Almighty
    Patrick, you are a complete accident
  3. #4998
    The Kind Administrator. Watch out for the others Trainrex's Avatar
    May 2003
    This subject has been touched on a few times. An intake will make your car run lean at higher rpms. A BOV makes it run rich between shifts. The points that they occur are different, thus they will not cancel each other out.
  4. #4999
    Jan 2004
    MI
    nope, it couldn't be if the problem was not recreateable. sounds electrical to me. i have had a few "unexplainable" moments that i can only point to ecu mistakes. i find that aftermarket bov's run perfect when run hard, its everything in between that dosent live up to stock.
  5. #5000
    Aug 2002
    Virginia Beach, VA
    Like andrew said...they don't act at the same time. Please search in the future...this is like asking a jew "don't you guys have a holiday with a big candle holder in december?" It's like....basic WRX knowledge.
  6. #5001
    Registered User STiguy's Avatar
    Jan 2004
    Long Island, New York
    If you really really want a blow-off valve, get a recirculating one. I have had 4 blow-off vavles and the Worx adjustable one is the best.
    LISC #1
    05 STi - 300whp 331wtq 1/4 - 12.7 @107.4 (SOLD)
    06 Evo IX 370whp 386wtq (Under Construction)
  7. #5002
    Aug 2002
    Virginia Beach, VA
    If you think the problem is your blow off valve, spend 20 minutes of your time working on your car to diagnose it. Put the stock one back on, drive around the block, see if the problem still happens. Owning a car with modifications that many people have proven to cause problems involves more than just asking others on the internet. If you notice something, do some self diagnosis so you have an idea of how things work. At the very least you'll either realize your aftermarket BOV is crap or you'll get really good at swapping in the stocker. either way....don't let me hurt your feelings when I say this, but figure it out yourself.
    ~Tim
  8. #5003
    Mar 2003
    lincoln, ri
    exactly WHEN did the jerk occur? right before throttle lift/clutch? during the rowing of the gears? during throttle tip-in and reapplication of power after the gear change? any CEL?
  9. #5004
    Registered User zapman's Avatar
    Jul 2003
    MN
    Quote Originally Posted by ride5000
    it occured when i let off the gas/put the clutch in. I decreased the spring pressure in the bov, it is a turboxs rfl, and haven't had any problems since. When it happened the cel flashed but went back off once i got it under control again. I went and had my codes checked today to see if it recorded anything but it didn't.
    i did do a self diagnosis, figured it was my bov, but i was just checking to see if anyone had ever had this problem before and to see if there was anything else simple i might have overlooked to check. sry, my first post wasn't very specific that i had already done a quick diagnostic myself.
    Former member of bugeye mafia
    <=====my old baby
  10. #5005
    Aug 2002
    Virginia Beach, VA
    Yeah, that pretty much sounds like the BOV needs more spring pressure. Didn't mean to sound snippy....but it's very common/infuriated to get the "omg I modded my car and now it doesn't feel perfect anymore" threads and lose it on them
  11. #5006
    Registered User hellafastWRX's Avatar
    Sep 2003
    Huntington, Long Island..... NY
    I had the same problems with the RFL. Its now sitting on my desk right next to me. No problems anymore
    --Chris
    04 WRX wagon - 304whp Mods - SOLD
    2008 DGM Impreza 2.5i sedan - STi Grille, GTspec cf lip, CTspec cf trunk chrome cover, Perrin shorty antennae
    LISC #3
    www.longislandsubaruclub.com
  12. #5007
    Jul 2003
    MN
    Quote Originally Posted by hellafastWRX
    did you try adjusting the spring pressure? i have a feeling i will be swapping mine off when i get home too.
    <=====my old baby
  13. #5008
    Registered User HiCkS's Avatar
    Sep 2004
    Cary NC/Fort Bragg
    here is my experience with my car running lean with an intake
    before TXS shorty intake 322 miles on 1 tank of gas 93 octane (gas light on) / 15.9 gal tank (carsdirect.com)
    equals = 20.3 miles per gallon
    After TXS shorty intake 326 miles on 1 tank of gas 93 octane with gas light on / 15.9 gal tank
    equals = 20.5 miles per gallon
    0.2 miles per gallon X 15.9 gallons = 3.18 miles difference
    of course i am only speculating on when the car will run out of gas with the gas light on, but im pretty sure the manual says there is like 2.3 gallons or something like that left in the tank when the light comes on. either way the numbers to me are too small and too close to say that the car is running lean. Technically is it? yes, but its not anywhere near the danger zone.
    just my 2cents
    btw i dont have a blow off valve, and dont want one
    www.kiowapilots.com
  14. #5009
    Oct 2004
    State of depression
    I love my HKS SSQV
  15. #5010
    Sep 2003
    Quote Originally Posted by zapman
    The day before Itook the bov off I took the spring and stretched it and put it back in. It seemed to solve the problem. My tuner said that the turboxs spring weakens after a while. I just took it off so I wouldent get any more idle problems this winter. I think ill put it back on in about a month when it warms up.
    --Chris
    LISC #3
