"The BIG BOV thread" (Where all bov question threads get merged) - Page 332
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; most likely VF22 or 34 are these bad choises?...
  1. #4966
    Feb 2005
    Parker,CO
  3. #4967
    Administrator
    May 2003
    Quote Originally Posted by JuggaloRacing
    There are few bad choices. It all depends on what you plan on doing with the car. Read through the engine performance stickys to get a better grasp on what you want.
  4. #4968
    Feb 2005
    Parker,CO
    also with that turbo i need to up grade the injectors and fuel rail correct?
  6. #4969
    Administrator
    May 2003
    You definately need to do some reading. A VF22 or a VF34 will be fine with the stock rail, and STI pink injectors.
  7. #4970
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    18-20 psi is pushing it with the stock BOV. some say they experience some leaking, some don't. at the level of upgraded turbo, i'd say swap it to be safe.
    the Forge seemed to work well for some, and i've driven a VF30 stage 4 with it, and it seemed to work fine. sounded great too. i've also heard good things about the HKS
    dR
  8. #4971
    Feb 2005
    Parker,CO
    ok so jus to make sure have u ever heard about the sotck fuel rail leaning on the 3rd cyl?
    if not then ive been mis informed
  9. #4972
    Feb 2005
    Parker,CO
    ok so i got the BOV by GFB the stealth so if i want full Blow off i can if not then i can make full return what u think got it for 270 brand new buddy hooked me up
  10. #4973
    Administrator
    May 2003
    Of heard of it, but it seams to be more rumor than fact. Some people say that you are fine up to 300whp on the stock rails, and some people such as Dan from Godspeed believe the lean #3 cylinder has nothing to do with the rails, and doesn't believe in changing them.
    Quote Originally Posted by God
    Actually I find fueling is much more consistent with the stock rails. It takes me twice as long to dial in a car with rails because the fuel curve is all over the place. As for evening out fuel, you can if you want. Pity the reason #3 and 4 run leaner is not fuel though. Bottom line? I run 400-500 whp with stock rails. I have never changed them here. I will not sell them despite there being profit in them. Other notable engine builders believe the same including Turbo XS. Take it as you will. If you still want to waste your money on them it is up to you.
    Yes I always run stock regulator and rails. NO matter what. Changing fuel pressure can cause drastic changes in the harmonics inside that rail. They are designed as a standard 3 bar system and should be left as such. I certainly don't have the million dollar+ machines to properly measure internal harmonics and pressure waves inside a fuel rail. Neither do these companies making so called fuel rails which is exactly my point. As for #3 and 4 the lean condition is not caused by the rails in my opinion, although you'll find argument to this.
  11. #4974
    Registered User nvmywrx's Avatar
    May 2004
    chitown
    if you dont have it already i would suggest some EM.
    Nah, it was Colonel Mustard, using teh shockAr in teh bedroom.
  12. #4975
    Registered User WRXcelration's Avatar
    Apr 2004
    Allentown PA
    hks, greddy, turbosmart
    05 STI
    Speed Comes At A Price...How Fast Can You Afford To Go?
  13. #4976
    Mar 2002
    Calmer than you are
    obviously, someone's trying to sell you something. The stock BOV is good to 20 PSI, and the stock fuel rails will handle any turbo that you find on ANY stock WRX (pretty much any VF series). I also went through several BOV's. They worked "ok" on a stock setup, but even with a stage 1 accessport, ALL the aftermarket BOV made my car run like crap...ok maybe not like crap, but I could definately feel the hesitation they cause. Also, you develop a nasty black spot on your tailpipe (and even the bumper) from all the unburned fuel every time you shift.
    Also, as someone who actually dates, I can tell you that not ONE woman that I drove was impressed by the BOV. In fact they found it annoying. I'd recommend using the money for something that will actually boost your performance. Heck get some SS brake and clutch lines, even THAT's better than a BOV.
    After almost 4 years of debate and practical real-life testing I think the BOV debate has been beaten to death. Bottom line: it will hurt performance. don't get one unless you're planning on more than 19 PSI of boost (which will require a specially built motor anyway), and chicks don't dig it.
    PS I've heard that the lean/hot #3 cylinder is caused by a badly designed water jacket rather than fuel rails. Besically, there's a "dead end" for coolant near the #3 cylinder and it gets less cooling than the others. At stock temps this isn't a problem, but when you start pushing 19-20 pounds of boost, the water jacket just can't handle the extra heat.
    go f*** yourself
  14. #4977
    Registered User spacemanspiff's Avatar
    Apr 2003
    Austin it is
    Fairly comprehensive I'd say.
    A lot of power is good, more is better, and too much is perfect. I mean, if less is more, think how much more more is...
  15. #4978
    Feb 2005
    Parker,CO
    so stock BOV is perfect what about BOVs that are 100% return?
  16. #4979
    Nov 2004
    im looking for the exact part...any word on where a flange can be found yet??
  17. #4980
    Mar 2005
    Arizona
    BOV question
    I have heard a rumor that a after market BOV can cause engine damage. Is this rumor true?
