"The BIG BOV thread" (Where all bov question threads get merged) - Page 322
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; instead of a show off valve I got a paintball gun, now instead of revving up and blowing off to ...
  1. #4816
    Boba Fett BrianH's Avatar
    Oct 2003
    Way up high.
    instead of a show off valve I got a paintball gun, now instead of revving up and blowing off to get peoples attention I just shoot at them with my paintball gun. It works every time.
  3. #4817
    Registered User UURX02's Avatar
    Jul 2004
    Canadian in DFW
    Quote Originally Posted by BrianH
    02 WRX - MODS
    Bugeye Mafia > *
  4. #4818
    Registered User ashumo's Avatar
    Mar 2003
    Ilwaco, WA
    fog horn
    wagon...thats right
  6. #4819
    Oct 2003
    Way up high.
    Quote Originally Posted by ashumo
    fog horn
    oooh never thought of that.
  7. #4820
    Registered User AwdTurboWrx's Avatar
    Mar 2004
    Sun Valley,CA
    Quote Originally Posted by hybrid gti 2
    I like my turbo xs rfl. It's loud yes but it seems to work well. my only thing is that I get a fludder sound in 5th gear with my foot down. yet all other gears have a good short sound. I found that the screws at the base can back out. I think ther 8/32 and I used a screw instead of there setup. I currently have 4 washers in it. with my vf39 I boost 18.5 and it loud and fast. I have heard many say hks ssqv but overall it's real quiet. I read some where in a mag. it said the sock bov is good til 15psi. If you want to here the stock one pretty well then get a short ram filter setup.
    lmao
    The Ghosts of Zooph and Sarcasmo Will haunt CLUBWRX forever!!!
  8. #4821
    Registered User jbruno's Avatar
    Jan 2004
    NJ
    Quote Originally Posted by AjIsDope
    This one: HERE
    Awesome...
    2004 Red WRX Wagon
    18G (Protuned)
    293 whp
    285 wtq
    Many, many other mods.........
  9. #4822
    Dec 2004
    new greddy bov
    i just saw the new greddy bov.. looks kinda cool but i was wondering if any one has
    put it on, or heard it yet? what u guys think?
  10. #4823
    Registered User DjChopstix's Avatar
    May 2004
    Broomfield
    BOV question #100001
    Is it true that every 10k miles you have to clean and lube a blow off valve. I am about to buy a used WORX BOV with 1.5k miles on it and i dunno if i should if i end up having to send it in to clean and lube. Is this true? If so which bov out there does not require maintenence?
    04 JBP WRX sedan
    -it gets me from A to B
  11. #4824
    Registered User hellafastWRX's Avatar
    Sep 2003
    Huntington, Long Island..... NY
    I havent heard anything like that. Mine is still working flawlessly after about 13k
    edit: i'm running the TurboXS RFL-H
    --Chris
    2011 DGM WRX hatch - Kartboy SS
    04 WRX wagon - 304whp Mods - SOLD
    LISC #3
    www.longislandsubaruclub.com
  12. #4825
    Registered User KoreanBeefcake's Avatar
    Jul 2003
    Huntsville, Alabama (formerly WA)
    i think the only time you need to clean it (if ever) is if it is sticking, but all blow off valves are different and im no genious...
  13. #4826
    Registered User Airborne Guy's Avatar
    Jul 2004
    Ft. Lewis, WA
    I clean my TXS RFL, just because I am a maintenance type person. I figure if its clean and lubricated properly then it'll do what it need to for many days to come......
    P.S. Im also in the army where this is a big deal!!!
    PICTURES
    OBP Impreza WRX STi Stage 2 @22psi. MasterTuned on 94 octane. PIA Dyno'd at 301 AWHP & 330 AWTQ only could boost at 19psi on the dyno so not sure what it would be at 22psi.
    (Cenex Gas http://www.chsinc.com/auburn/Tacoma.htm )
    Quote Originally Posted by dewmudgeon View Post
    ok, so if i wanted a bov and got a cai as well,
    would they equal eachother out? creating minimal problems?
  14. #4827
    Moderator MidKnight's Avatar
    Oct 2002
    Bergen, NJ
    Generally speaking, any moving mechanical device needs maintenance at some point. I've bought 3 used bov's and I cleaned and lubed each one before I put it on. The worx unit is VERY easy to open (couple of hex screws on the top). Once you open it up, wipe everything down and maybe use some compressed air, smear on some lube (worx recommends lithium based lube if I remember correctly), and put it back together. It literally takes 10 minutes to do and it gives a little piece of mind. Good luck!
    '03 WRX
    '01 2.5RS
    MODS | PICS | Dyno
    "Stuff sold by the gram is always going to be more exciting than stuff sold by the pound." - Jeremy Clarkson
  15. #4828
    Registered User cheeseybacon's Avatar
    Jul 2004
    Chambersburg, PA
    Check out the sticky at the top of this forum. Unless you're running 20 PSI or more, an aftermarket BOV, any brand really, is unnecessary and may even be detrimental to performance.
    ΜOΛΩΝ ΛΑΒΕ
  16. #4829
    Jul 2004
    Chambersburg, PA
    What do you mean by lithium based? Would that be something like WD-40?
    ΜOΛΩΝ ΛΑΒΕ
  17. #4830
    Registered User 5spdfrk's Avatar
    Dec 2003
    Southside o' ATL
    That's not what he asked.
    I noticed this bov a couple of months ago and asked greddy if they were going to make it in a wrx flange and they said no. So you would have to make your own flange for it. Also, me and some guys on the evo forums were talking about it. One guy installed one on his evo and he has a sound clip. Check this thread out.
    http://forums.evolutionm.net/showthread.php?t=112539
    Here is a direct link to the video.
    http://www.gscdownloads.com/greddyrsbov.wmv RCSA
    '02 WRB WRX
    '92 Civic Si
