"The BIG BOV thread" (Where all bov question threads get merged) - Page 32
Page 32 of 798 FirstFirst ... 22232425262728293031323334353637383940414282132532 ... LastLast
Results 466 to 480 of 11961
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; How the hell can you SMELL LEAN!?! "Hmm... smells like ya gotta buncha air in there... that ain't no gud" ...
  1. #466
    Registered User gryphon's Avatar
    DFW, Texas
    WTF?!
    Maybe they meant "rich" and used the wrong word. either way, scratch that place off your list.
    2002 Subaru Impreza WRX
    Midnight Black Pearl
  3. #467
    Registered User O-wood's Avatar
    May 2002
    Whittier, CA
    That is a real mystery. I have the same BOV and I have never seen the CEL light go off. My BOV is set at 50/50 though. Try putting the BOV in and set it at 50/50 and see what happens.
  4. #468
    Registered User Valien's Avatar
    Jul 2001
    Greenville, SC
    yeah..bov was on properly, etc. etc. etc. Kinda wacked.
    i'm going to run it stock for a while and see what happens. Then put it back on and set it for 50/50 instead of 100 and see what happens.
    strange strange i tell ya!
    http://www.chumpmonkeygames.com
  6. #469
    Leesburg, Fl
    Sounds like the moral here is don't boost higher if you aren't willing to pay for more gas!!
    Shane
    Aim Higher Go Navy!
    Platinum Silver 2002 WRX Sedan
  7. #470
    Moderator Penguinking's Avatar
    Nov 2001
    Houston, TX / Athens, GA -at the same time!
    No comment...
    Silver 911
    WRX's older brother
  8. #471
    Registered wrxinthehouse's Avatar
    Nov 2001
    awdpirates.net
    Two biggest killers of gas mileage on the Rex:
    1. ECU reset
    2. Air conditioning.
  9. #472
    Registered User PlatinumWRX's Avatar
    Jul 2001
    PA
    Thumbs up
    1. ECU reset
    I couldn't possibly agree more!
  10. #473
    California
    Does anyone have HKS SSQV BOV?
    Hi, does anyone have this blow off valve? how does it sound and whats the quality comparing to the TXS rfl bov? i'm thinkin about order this hks bov.. its $280 compare to the txs RFL for $175
    Nothing happens until something moves
  11. #474
    Mar 2002
    i have one..
    hey.... I have a HKS sequnetial bov.
    It sounds great!!
    I got it for 200 shipped from someone...I love it.
    I think it's the best BOV. It sounds TIGHT!
    It will turn heads for sure.
    I heard that RFL is really freaking loud. If you want HIGH pitch WOOSH...then go with HKS..if you want low pitch LOUD A$$ woooosh get RFL...That's all I gotta say.
  12. #475
    Registered User Prince Ali's Avatar
    May 2002
    Southern California
    1. ECU reset
    This doesn't really apply to mileage, but the A/C also sucks up power like crazy. I have to rev up to 2 to 3k before engaging the clutch to avoid hesitation.
    Thanks,
    Ali
  13. #476
    Mar 2002
    Austin, TX
    I agree.... AC is a killer on power. But seriously.... less gas mileage than your old Dak R/T? I got 12mpg on a good day in mine...
    -Rob W
    02 WRX Sedan 5spd Midnight Black
    --- Mods: Godspeed Uppipe, Blitz SBC-id
    01 LS1 Firebird Formula
  14. #477
    Registered User gifty74's Avatar
    Mar 2002
    Lancaster, PA
    stock BOV as boost source
    i'm a little confused here...
    the larger tube (1" OD or so) coming into the stock BOV is from the Y before the intercooler, right? so the BOV is seeing pressure from that line coming into it, so when the butterfly is suddenly closed in the throttle body it can vent the pressure in the system, right? where does the smaller hose coming out of the top of the BOV end up, back to the intake? i was under the impression that the stock BOV was 100% recirc, so everything would be vented back upstream. i don't understand then why that line is always seeing pressure. i thought that line would only see pressure when the BOV vents (between shifts). why is there always pressure there? is there another inlet for the BOV line, under the mounting bracket? i thought it was on the front of the intercooler just for hte mounting. maybe there is something under there that i can't see. could someone just quickly explain how the BOV system all works together, and why that line coming off the top of the BOV always has pressure in it, especially if it dumps back in where i thought it did...back upstream in the intake somewhere. i tried searching, but just found little bits and pieces. thanks.
  15. #478
    Registered User TB RACING's Avatar
    Jun 2002
    yes it recirculates it back to the intake, you wouldnt see pressure when it vents, you'd see a release of pressure,
    or a vacuum after the release. Theres pressure in that line when it builds boost because it IS 100% recirculating. Otherwise you wouldnt be able to put a boost gauge tap there, and is also why that isnt a really good place to put one.
  16. #479
    Mar 2002
    Lancaster, PA
    so where is the pressure relief valve in the whole scheme? if that is just one solid circuit, where is it holding pressure in? you said the boost gauge wouldn't see the pressure relief, why not? what is the stock BOV set to release at, or is it not a pressure relief valve? i'm not being smart here, just confused as to how it works.
  17. #480
    Jun 2002
    It's not one solid circuit,
    and it does see the pressure relief,
    It just sees the back end of the pressure in the system.
    Picture it without the BOV and turbo first,
    take one solid exhaust piece,
    now add a T to it but off the T is a dead end.
    This dead end is where your gauge would be reading from if you put a gauge right off the BOV in closed position
    you read pressure because it is connected to the system but kinda on a back alley of it
    once the BOV opens, it now becomes a circuit as you put it
