"The BIG BOV thread" (Where all bov question threads get merged) - Page 316
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; you have a broken BOV. get a new one HKS SSQV will cause turbo lag between shifts; there is no ...
  1. #4726
    Registered User slowmo's Avatar
    Mar 2004
    Oregon
    HKS SSQV will cause turbo lag between shifts; there is no recirculation. I had the BOV and it was cool for the sound, but definitely made the car more sluggish after a shift. I sold it and put the stock one back on. With the silencer removed I could hear the turbo more and also the BOV, which was satisfactory for me.
    The only time you really need to replace the BOV is when you are pushing so much boost and the stock BOV can't hang anymore.
    Save the money and spend it on a downpipe
  3. #4727
    Dec 2003
    04 Bov
    Will a 04 BOV fit on a 03?
  4. #4728
    Boba Fett BrianH's Avatar
    Oct 2003
    Way up high.
    yeah, but get an airhorn. They're louder and more pimp.
  6. #4729
    Mar 2002
    Tokyo, Japan
    Yes, it will fit. BOV's are universal on the different model year WRXs. The only difference is that some front mount intercoolers use specific blow off valves that will only fit those FMIC's.
    "I don't think he knows how to give up. His mind and machine are racing as one." -Takahashi Ryosuke
  7. #4730
    Dec 2003
    Thanks
  8. #4731
    Registered User scooby24's Avatar
    Mar 2004
    Kansas City
    Did you hook up the line to the back of the BOV? Did you adjust the bolt on the back to loosen the spring tension?
    05 Crystal Gray STi
    304 hp 353 lbs on 92 octane ------> Mustang Dyno
    12.6 @ 109.2 > new numbers coming soon.
  9. #4732
    Mar 2003
    lincoln, ri
    fwiw, i often run 20 psi on the oem turbo, spools at about 3k. it holds it rather well through the midrange, starts dropping off at and tapers itself down to ~15 psi at redline. mods on www page. in the colder weather i generally dial it back a pound or two.
    jm2c
    ken
  10. #4733
    Mar 2002
    Tokyo, Japan
    ummm its listed in his signature he's running a VF22
    edit: maybe I should read the rest of the posts in the thread before I make a comment that was already addressed 5 posts above mine
  11. #4734
    Aug 2003
    bov installation for 05 STi
    this isnt for me, but my friend got a 05 STi like a week ago and got a p.i.t bov. he's about to install it but wanted to know what you do w/ the big hose (im guessing the hose that recirculates the air into the intake?) because there isnt any place to slip it into on the bov. do you just plug it and leave it?
  12. #4735
    Oct 2004
    Austin, TX
    im thinkin of....
    what do you guys think...a TubroXS BOV? keep in mind im stuff running the stock turbo, but the BOV is for psi ranges of 10 - 25psi
  13. #4736
    Oct 2004
    Austin, TX
    i actually want a BOV thats got a sweeter sound to it instead of just air purging(spelling?) one like this http://www.hksusa.com/content/misc1759.wmv anyone have any suggestions that wont fry my turbo by not being able to recirculate air like it needs to
  14. #4737
    Registered User cheeseybacon's Avatar
    Jul 2004
    Chambersburg, PA
    Quote Originally Posted by EJpiston power
    Actually it's not your turbo that could potentially be damaged, it's your engine. BOVs starve your engine for air and cause you to run rich in between shifts. Most of the time this isn't an issue, but it can cause some slight turbo lag and occasional engine stumbling between shifts. Most people don't find it annoying enough to take off the BOV. There are some 50/50 valves out there that recirculate and make a noise too, but I couldn't tell you how well they work. Do a search, there are 9 zillion threads on this subject.
    ΜOΛΩΝ ΛΑΒΕ
  15. #4738
    Registered User RWU00313's Avatar
    Nov 2004
    TXS Bov Type H for Sale
    EJ piston if your looking for a Good sounding TXS Bov I am selling mine for a good price everything included for setup with the stock turbo, and again it is basically Brand new. There are pics and clips of this bov in this thread.......http://www.clubwrx.net/forums/showthread.php?t=87575
  16. #4739
    Oct 2004
    Austin, TX
    Quote Originally Posted by cheeseybacon
    so you're saying its not 100% for sure my car will be screwed if i get one. i keep thinking that if i get one, there goes scoob just because of a BOV and i fear that even if i take it off and put the stock pressure-relieving system back on subaru still wouldnt fix my car cause they'd know
  17. #4740
    Nov 2004
    I am pretty sure that the STI bov setup is exactly the same as my 05 Wrx. If it is a recirculating Bov then it should be plumbed back into the intake, but if not then yes you should plug the opening. I know there are other threads talking about plugging the tube with a shower plug etc. Once it is plugged if its possible to put the hose clamp back on it would be a good idea, however when I had my Bov installed I didnt do this and it was perfectly fine. It should be a very simple install and I hope that I answered your question.
