"The BIG BOV thread" (Where all bov question threads get merged) - Page 311
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; what do you do about the tube that normally runs from the BOV back to the intake?...
  1. #4651
    Aug 2003
    Manchester, NH
    For those of you with aftermarket BOV
    It is better to have others think that you are a fool than to open your mouth and remove all doubt
    02 WRX 44k - sold 2/28/5
    96 Corolla 128k
    92 Corolla 160k
    88 Accord 208k
    90 Voyager 242k
  3. #4652
    Registered User Wrinkleboi's Avatar
    Jan 2002
    Langhorne, PA
    if the bov doesnt recirculate, then you need to plug the recirc tube. you're car will run like crap if you dont seal off the tube.
    all blow off valves should come with a plug for this, but if they dont you can go to home depot and get a 1 3/8" white rubber sink drain plug for $1.39 plus tax and it works like a charm .
    bryan
    -2003 Blue WRX, complete 2007 STi Engine/Drivetrain transplant - Pic 1 | Pic 2 | Pic 3 | Pic 4 (new!)
    -1994 Black Supra TT 6MT - Pic | Build/Restoration Thread: 67mm, Fuel, Painted Engine Bay, Fuse Box Relocation, Wire Tuck, etc.
    www.TriStateTuners.com
  4. #4653
    Aug 2003
    Manchester, NH
    is there any truth to the rumor that a fully vented BOV on a stock car can actually hurt performance or in some way damage the engine?
    96 Corolla 128k
    92 Corolla 160k
    88 Accord 208k
    90 Voyager 242k
  6. #4654
    Registered User hellafastWRX's Avatar
    Sep 2003
    Huntington, Long Island..... NY
    Quote Originally Posted by Wrinkleboi
    bryan
    Good improv idea. Do you have the chain attached to it to?
    --Chris
    2011 DGM WRX hatch - Kartboy SS
    04 WRX wagon - 304whp Mods - SOLD
    LISC #3
    www.longislandsubaruclub.com
  7. #4655
    Sep 2003
    Quote Originally Posted by JeremyL
    Over time the rich conditions will break down the cat in the uppipe. This will send pieces of metal into your turbo. = very very bad. Get a catless uppipe just to be safe but you dont have to worry about that for a while .
    Enjoy the bov. I like to scare people jogging with mine.
    --Chris
    LISC #3
  8. #4656
    Aug 2003
    Manchester, NH
    is that the only thing to really worry about? why would a BOV make the car run rich?
    96 Corolla 128k
    92 Corolla 160k
    88 Accord 208k
    90 Voyager 242k
  9. #4657
    Jan 2002
    Langhorne, PA
    well it just makes the car rich in between shifts, because thats the time it is releasing air into the atmosphere that would normally be recirculated into the intake and then into the engine. basically every time the bov is releasing, your engine is getting a little less air than it expects, so it throws the AFR off a bit. the only difference i notice is a little afterfire now and then. if you have a straight through exhaust without any restrictions you may find that you're shooting flames too because of this
    bryan
  10. #4658
    Aug 2003
    Manchester, NH
    could any type of reflash or tuning cure that? so what kind of effect could that have on the longevity of the motor?
    96 Corolla 128k
    92 Corolla 160k
    88 Accord 208k
    90 Voyager 242k
  11. #4659
    Jan 2002
    Langhorne, PA
    well i'm certainly not the final word when it comes to technical engine questions, but in my understanding it wont really have a negative affect on your engine's well-being, but it may slow you down .1 in the 1/4 mile.
    bryan
  12. #4660
    Dec 2004
    Eugene, OR
    Hey Jeremy,
    I'm pretty sure it's just like the situation on our MR2's. (I'm archiemr2 on mr2oc)
    Because the WRX has an AFM, let's say that "A" amount of fuel goes into the car. The AFM puts "F" amount of fuel in the mixture because the ECU has looked in its electronic tables how much fuel to put into the mixture when you have "A" amount of air.
    Well, when you vent your BOV to atmosphere instead of back into the system, you lose "x" amount of air to the outside world. You no longer have "A" amount of air in your motor...you have "A" - "x" air in your motor. Yet...the ECU doesn't know that you lost some air and still thinks you have "A" amount of air in your motor, so it's putting in enough fuel for "A" amount of air...not "A" - "x" amount of air. So you've got too much fuel, and it runs rich.
    It's only doing this abnormally when the BOV is open...ie between shifts if you're revving the car hard. There aren't really too many adverse affects on our MR2's for this...the biggest things are less smoothness betweeen shifts and with a downpipe and open exhaust you might make fire. Apparently on the WRX there is a cat in the up pipe. I'm not sure if the rich condition like hellafastWRX said will actually break down the cat faster or not. Seems more like a theory to me. Please feel free to give more info on that one.
    But overall, that's why you run rich with a BOV vented to atmosphere and in general the effect is just slightly less smooth transition between shifts. Does running rich damage the motor? Not at all. But if there are side effects like pieces of the cat going into the turbo...then that's not good. I'm still not sure whether that idea has any merit to it yet or not though.
    HTH
  13. #4661
    Dec 2004
    Eugene, OR
    Oh, and I'm not sure about a reflash, but..
    You can supposably tune to compensate for it with devices like the S-AFC. I could never seem to figure it out with mine when I had it.
    If you run a standalone EMS, you can remove the AFM altogether since the EMS will measure the air volume with a temperature sensor and a MAP sensor instead. These sensors monitor the air after the intercooler so it doesn't matter if you're throwing air out before it gets there. So with an EMS, you also won't have the rich condition problem when shifting with a BOV vented to atmosphere.
  14. #4662
    Nov 2004
    tampa, fl
    Quote Originally Posted by MiStiC NiNja
    worx says 50% for daily driving should workout fine (at least for my WRX) might be different for the STi, but def. don't DD w/ 100% you'll fry your cats.
    it says 50/50 in the directions. thats what i currently have it set on. drives fine.
    05 Black STi
  15. #4663
    Registered User MiStiC NiNja's Avatar
    Oct 2004
    Quote Originally Posted by 5spdfrk
    Unless you dont have any cats!
    hahaha! do you ever shoot off an occasional fireball?
  16. #4664
    Aug 2003
    Manchester, NH
    what about a 50/50 BOV ? would you just cut the rich between shifts condition in half? if its only in between shifts when youre boosting hard i mean that doesnt make up very much of your driving time. we had a used STi on our lot that had an aftermarket BOV and while it was kinda annoying (and i know im gonna get flamed for it) but it sounded really cool
    96 Corolla 128k
    92 Corolla 160k
    88 Accord 208k
    90 Voyager 242k
  17. #4665
    Registered User 5spdfrk's Avatar
    Dec 2003
    Southside o' ATL
    I hope so! I dont know for sure because no one I know has ever been behind me. I do get afterfire a lot and when it happens the people behind me back off, so I dont know if it is because of the sound, the fireball, or both!
    '02 WRB WRX
    '92 Civic Si
