"The BIG BOV thread" (Where all bov question threads get merged) - Page 29
Page 29 of 798 FirstFirst ... 19202122232425262728293031323334353637383979129529 ... LastLast
Results 421 to 435 of 11961
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; you're probably on the throttle a little more than you used to. if you like the power of the mbc, ...
  1. #421
    Registered User gifty74's Avatar
    Mar 2002
    Lancaster, PA
    you're probably on the throttle a little more than you used to. if you like the power of the mbc, but would like better mileage too, i'd look into a solenoid system so you can switch back and forth between the stock bc system and the mbc. you pretty much get the best of both worlds. actually, i don't really switch the mbc on unless i want to play around racing or on the back roads. i think the stock system does a much better job of mixing boost control with throttle position, which relates to better gas mileage. my mbc is off probably 90% of the time. my gas mileage is getting better as the car builds more miles, as i've read its supposed to.
  3. #422
    May 2002
    http://www.flashlightflux.com
    Oh, that reminds me i just reset the ECU the other day. Maybe that has somthing to do with it.
  4. #423
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    More power and better gas mileage generally don't go together. Sure, you can make an engine more efficient and get both, but that's not what you're doing here. Turning up the boost simply rams more air into the motor. To make the best power, you need to stay with a certain air/fuel ratio. So when you ram more air in, you have to put more fuel in too. Sorry.
    Yeah, the motor loosens up a little with mileage, resulting in less internal friction. That way less power is getting wasted just turning the motor, so you're not on the gas as much to get the same result. You get a little more power too. This IS a case of the motor becoming more efficient.
    Chris
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
  6. #424
    Moderator Penguinking's Avatar
    Nov 2001
    Houston, TX / Athens, GA -at the same time!
    Originally posted by kaizenfighter
    Actually, the air that is vented back into the intake is vented after the maf sensor so that will have no effect on anything. In response to the above post, I think there is a kit that allows for the 50/50 setup
    on the contrary, that is exactly WHY it will have an effect. you see, if your BOV vents 50/50, the MAF already thinks there is more air in the system, but in all actuality there isn't since you vented air to the atmosphere. since the recirculated air is after the sensor, it doens't get recounted and the same amound of fuel is added - but since there is less air the mixture is richer.
    Silver 911
    WRX's older brother
  7. #425
    Registered User WRXin''s Avatar
    Jun 2002
    Houston, TX
    Alright...I REALLY want this HKS BOV. Is the mixture going to be significantly richer to where you guys would completely advise against it, or is it just a minor thing.
    Fahd
  8. #426
    Registered User GarySheehan's Avatar
    Jun 2002
    It's not bad for the car. You just may notice some hesitation. A 50/50 would cause less hesitation.
    I didn't want to take it off the race car because it sounded so good. But, everything must be sacrificed for all out speed, so off it came and we went back to stock.
    Gary
    Sheehan Motor Racing
    www.teamSMR.com
  9. #427
    Registered User pace's Avatar
    Sep 2001
    Brook Forest, Colorado
    Fahd
    I would think it will be primarily noticeable immediately after an upshift when you are 'on it'. The car may bog slightly as the ECU effectively dumps too much fuel. If you drag race at the strip and are concerned about your quarter, this is probably a big deal. Otherwise, it's probably of little consequence in daily driving.
    -Pace
  10. #428
    Registered User PlatinumWRX's Avatar
    Jul 2001
    PA
    This has A LOT to do with it, an ECU reset kills fuel mileage. If you stay out of the boost, fuel mileage should be comparable to before.
    -Jim
  11. #429
    Nov 2001
    my take on it is that at worst, with normal driving, you'll just get worse gas milage.
    Silver 911
    WRX's older brother
  12. #430
    Jun 2002
    Houston, TX
    I see...so could the richness of the mixture be adjusted by remapping the ECU?
  13. #431
    Jun 2002
    No, the ecu won't know when the MAF is telling it the truth or when the MAF doesn't know that it lost all the air in the system.
    The only way to run an atmospheric venting BOV properly is to install an engine management system that uses a MAP sensor to calculate fuel.
    Gary
    www.teamSMR.com
  14. #432
    Nov 2001
    what kind of engine management system are we talkin' about here? ...like, how much would a *reliable* system cost?
    Silver 911
    WRX's older brother
  15. #433
    Registered User Prince Ali's Avatar
    May 2002
    Southern California
    What kind of mileage are we talking about? I used to get 22 to 23 mpg driving mixed on the stock 5 spd. But the last time I got gas, my mileage was down to 16. I have been running the A/C more than before. Could this be the problem?
    Thanks,
    Ali
  16. #434
    Mar 2002
    question..
    I have a question.
    It might be a dumb question....excuse my lack of knowledge.
    I just ordered a HKS super sequential........
    my question is....... do I close the hose that orginally vents back into the intake? And how?
  17. #435
    Mar 2002
    HKS super sequential BOV
    Hey guys.
    I'm still a newbie at this wrx world. I don't even have 1000 miles on my car yet. But I bought a HKS SSQBOV..........does anyone else have this? Can you tell me if the kit includes a cap(or some sort of cap) that closes the hose/hole that is originally vents back into the intake?
    Or do I have to go get it my self?
    Does anyone have HKS SSQBOV installed in their car? Do you have a pic of it? Anything will HELP!
    Thank you very much. And I appreciate the help.
