"The BIG BOV thread" (Where all bov question threads get merged) - Page 289
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; they will be here this thursday, ill let yall know, anyone that says you will lose hp and torque with ...
  1. #4321
    Oct 2004
    i just ordered them
    they will be here this thursday, ill let yall know, anyone that says you will lose hp and torque with this style header is ****ing retarded. reason being have any body defending the stock parts see them. jesus they are built like ****, the manifolds come together right after the ports, that causes so much turbulence, its insane. im personally kinda worried about a flex pipe, cause you know it could break and go up in the turbo. btw no flex pipe it will most likely crack like a *****, cause its not iron. so whatever, umm people these cars arent magic. there simply air pumps, and work off the same physics as any other motor. this post is directed to a few people on the board, from which some posts ive seen. i like to look at this site to learn new things but sometimes i just gotta wonder why people post the things they do, with no validity. maybe im just bored and feel like venting. but just take it for what its worth and nothing else, i like this site, and this is my first post, but i feel that there is so much misinformation on all these websites, and its so hard to try and find help and good knowledge. thanks to anyone who reads and takes anything positive from this.
  3. #4322
    Jan 2004
    MI
    Quote Originally Posted by scoobaru
    i admit, i share similar sentiments. just remember, if something dosent make sense from a logical perspective and no one can offer objective data or detailed explaination; then, it must be taken as an oppinion.
    do you really think that bov and CAI are really as bad as many on this site make them out to be? (they might not be worth the money, but they dont destroy your car) do you think that the most vocal members on thoes issues are the most informed?
    i guess the point is, its the internet and dont forget that
  4. #4323
    Jan 2004
    MI
    Quote Originally Posted by wrx&998rduck
    ok im gonna order them, and dyno before and after so we can put the argument to rest.
    i will put the $ together within the week and go from there, i will make a trip to easy street and have them do a dyno run to show current power, and go back again and do after mod power......stay tuned, and i will keep you all informed as it gets done.
    05 wrx dont let me down....lol
    pm me with input if you guys think of any.
    rock!
    if you have any questions about the install post them here or pm me, i might be able to help.
  6. #4324
    Registered User wrx&998rduck's Avatar
    Aug 2004
    Granada Hills Ca, north of los angele
    thanks bigclunk, i am going to have one of the guys on the board here do the install, i believe his screen name is subiestyle, he does not live too far from me so he has got the job, and he comes highly reccomended by other members cause he has done their work.
    i plan to do this in 7 phases.
    1. get initial dyno results in semi stock form (bov, catback, silencer delete)
    2. have subie style install up/down pipe
    3. got get dyno results
    4. have headers installed
    5. get dyno results
    6.add stage 2 access port
    7. do last and final dyno run
    all i have to say is my girl is great because she said lets do it, with no questions asked, and didnt care how much it costs. so its on guys, i will get the initial results on here soon.
    let me know if any of you have some input.
  7. #4325
    Jan 2004
    MI
    some reading material....
    this is the post on nasioc where the headders were dynoed.
    you can come to a variety of conclusions because the data isnt totally perfect but, keep in mind there is alot of questionable opinions. make sure to read the factual and logical post more carefully than the stupid ones (come on, its nasioc, there is definatly alot more nonsense)
    the results dont get posted until pg 22 (s3 link broken but a graph is provided later on) some of the info between the first post and pg22 is worthwhile but most of it is heresay.
    http://forums.nasioc.com/forums/show...&page=22&pp=25
    this is a slightly more negative post about headders. its important to try to be objective and view both sides but he definatly has alot of objective data.
    http://forums.nasioc.com/forums/show...hlight=headers
  8. #4326
    Jan 2004
    MI
    Quote Originally Posted by BigClunke
    this is a slightly more negative post about headders. its important to try to be objective and view both sides but he definatly has alot of objective data (as well as a different engine)
  9. #4327
    Aug 2004
    yeah im reading it all right now, but the graph is hard to read
  10. #4328
    Jan 2004
    MI
    I was trying to edit in that the last link's results are with a different engine. it might not be relevant, but worth considering.
  11. #4329
    Jan 2004
    MI
    it also leaves some out (including the ssautochrome, which i thought would be similar to the megan's).
    what i gained from it is; headders benefit in a few areas...
    they help create more boost
    they do add hp
    they will add more if they are wrapped or ceramic coated (preferaby both) ie. borla
    they seem to lower egt's too (the second link might make that point debateable)
    i think that the biggest benefit is the lower egt because it should help our #4 cylinder problem and generally make things run a bit smoother. it seems that people are conserned about loosing that "chunky" mean boxter sound but a well tuned porsche dosent sound bad. why would our wrx?
  12. #4330
    Aug 2004
    id rather loose the sound of the engine, and loose 150 degrees by adding a header, the sound will come back some way sometime, loosing 150 degrees imo is more desireable in the long run
  13. #4331
    Registered User DTR rex's Avatar
    Jun 2003
    Chi-town, IL
    well, for $250 I am pretty interested in this. I just want to see some results on how it may, or may not perform.
    Just call me Clark Kent
    Offical Body Guard for the Bugeye Mafia.
  14. #4332
    Registered User Durbin's Avatar
    Nov 2004
    ohio
    Blow of valves
    i whant a new BOV but i dont have the money for an hks ssq is there any out there that are cheaper but sound the same i really like the way the hks sounds thanks
  15. #4333
    Registered User XxScoobYxX's Avatar
    Apr 2003
    chicago
    Why....
  16. #4334
    Registered User Redline927's Avatar
    Jun 2004
    New Jersey
    i suggest you get on that flame suit ASAP, youll need it.
    lol jk i suggest you take out the intake silencer aka snorkus as there have been many threads on how to do it. it allows u to here the bpv better and turbo spool up and bets of all its FREE go to scoobymods.com to find out how to do it about 30 min to do it or less
  17. #4335
    Registered User EtherealWRX's Avatar
    Oct 2004
    Downey
    Oh man. I can feel the flaming coming. I hope you're running 20+ Psi. I have a spare HKS SSQV BOV for sale, if you want it make an offer, but I'm telling you, you should run stock.
