"The BIG BOV thread" (Where all bov question threads get merged) - Page 276
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; if you run to the atmos you're gonna run rich if you recirc you will be fine...
  1. #4126
    Registered User astricii's Avatar
    May 2004
    Denver
    Adam
    Quote Originally Posted by svc
    Fvk the elves, it's bling season
    Sponsored by: BoostBuddy.com
  3. #4127
    May 2004
    Denver
    duh!!!!!
    misfiring systems are tEh CrAzYIeS but yeah if you have like 30 spare turbos lyin around a great way to keep your car in boost
    Adam
  4. #4128
    Banned truWRXtacy's Avatar
    Sep 2004
    Colorado
    whats the difference between the two?
  6. #4129
    Registered User sexyrex's Avatar
    Feb 2003
    OCJ
    how many washers do you have right now for your bov? thanks
    Quote Originally Posted by djrez4
    Adding washers changes the spring tension. The more spring tension, the more boost you'll have to run to vent it.
    Eli....it's better than he bumped this old thread than started a new one. Ideally, we'd only have one Type-h thread with everything you'd ever want to know.
    [SLEEPER]
    [noun] A high performance street car with an inconspicuous, stock outward appearance.
  7. #4130
    Registered User SteelCity_WRX's Avatar
    Jun 2004
    Pittsburgh PA
    I did not get any washers with mine. I will go look again though. Maybe I missed them.
  8. #4131
    Sep 2004
    yea they shoudl be in a small plastic baggie
  9. #4132
    Registered User DRatedA.W.D's Avatar
    Sep 2004
    Portland, Oregon
    I have 3 washers in mine and its doing alright now. I had 2 in there and when i would put the clutch in coming up to a light, it would die down to 100 rpm and almost die. With 3 in there it doesn't do that much anymore.
    Andrew
  10. #4133
    Registered User RyaNT's Avatar
    Sep 2004
    Somers, CT
    i didnt by a BOV but it runs poorly with one on? SUS isnt a BOV is it? bypass valve i can never hear loud enough
    2004 WRB WRX
    -Turbo guage
    -Short Shifter
    -Premium Package
    -RS-Limited Ricochet 18" Gunmetal w/ Polished Lip
    -TeiN S Techs
    -Turbo XS RFL Exhaust
    -Alpine IVA-D300 MMS
    -Alpine 2005 Type-R's (2 12's)
    -MA Audio 3600 watt digital Amp (Mono)
    "My lugnuts Require more Torque than your Honda Creates"
  11. #4134
    Apr 2003
    In Ray's house while he's jacking it in his car.
    The Blitz SUS is a short ram intake, and one of the few intakes that has been dyno proven to give the WRX increased horsepower. If you get one, you will definitely be able to hear your stock bypass valve. You will also hear increase turbo noise. I'd definitely recommend this over a BOV.
    EDIT: The installation is very simple and straight forward, as well. If I remember correctly, you have to undo one clamp, take out one bolt and undo two screws. Then you reassemble in opposite order.
  12. #4135
    Sep 2004
    Somers, CT
    so tell me why not a BOV? it releases un wanted pressure no?
    2004 WRB WRX
    -Turbo guage
    -Short Shifter
    -Premium Package
    -TeiN S Techs
  13. #4136
    Registered User KoreanBeefcake's Avatar
    Jul 2003
    Huntsville, Alabama (formerly WA)
    the air that was suppose to back into the intake is let out. when it goes back into the intake feul is added to it. so when you shift you run a little rich. i guess it causes stumbling problems with most people or something. search and you will understand alot better than my explanation.
  14. #4137
    Registered User outferno's Avatar
    Jan 2003
    San Jose, CA
    Quote Originally Posted by faSt4
    I installed a Turbosmart Dual Port blow-off valve on my car the other day. I had zero install problems, except that when I lower the hood, the top of the valve is semi-covered by the rubber that creates a seal around the intercooler. It already put a chip in the blow-off valve and is extremely aggrivating to know that it is rubbing. Should I buy another valve or...? Any suggestions would be appreciated.
    If you're able to move it from the flange and twist it to a different angle, then it would be awesome. However, I don't have one to play around with. I've played around with other BOV's where you can take off the top portion that is connected to the horn and you can twist it.
    Don't know if this will help.
    Signed,
    Charlie
  15. #4138
    Sep 2004
    San Mateo
    Blow off valves
    Does anyone know the blow off valve that alot of supras have. It sounds "springy" im not sure if its blitz but if anyone knows what im talking about please help!. What i mean by springy its like....a cricket pitched springy sound...please help!
  16. #4139
    Registered User ebr0t's Avatar
    Aug 2002
    U of Central Florida (Orlando)
    probably hks super sequential.
    Quote Originally Posted by DTR rex
    Peter North > *
  17. #4140
    Registered User GotRice7169's Avatar
    Jun 2003
    Tampa Florida
    or Greddy Type S
