"The BIG BOV thread" (Where all bov question threads get merged) - Page 275
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I don't know what your mods are or what your plans for mods are. But if you are running some ...
  1. #4111
    Registered User Judah's Avatar
    Mar 2002
    arvada, coloRADo
    I don't know what your mods are or what your plans for mods are. But if you are running some type of EM you could tune around it. I do like the sound and a lot of people have been running bovs without and ill affects. I guess that it completely up to you.
  3. #4112
    Registered User 5spdfrk's Avatar
    Dec 2003
    Southside o' ATL
    I got the worx tuning BOV and it is great. Fully adjustable.
    Only time I have hesitation is when I have it on 100% ATM, which is always right now. Not enough problems for me to switch it back to 50/50. I am going to try 75/25 here soon and see how I like that.
    '02 WRB WRX
    '92 Civic Si
  4. #4113
    Registered User KoreanBeefcake's Avatar
    Jul 2003
    Huntsville, Alabama (formerly WA)
    ive never heard of backfirring with a bov.
  6. #4114
    Zem
    Zem is offline
    Registered User Zem's Avatar
    Jul 2003
    Stalking Jay
    Let justice be done though the heavens should fall.
    -John Adams
  7. #4115
    Aug 2003
    Norway, Europe
    I'm getting one soon.. can't stay away... It's just to damn sexy
    Silver -02 Impreza WRX
  8. #4116
    Registered User sexyrex's Avatar
    Feb 2003
    OCJ
    yeah, well i figured id bring it back to life. haha. anyways. by adding washers does it change the sound or how fast it reacts or some sort? thanks
    [SLEEPER]
    [noun] A high performance street car with an inconspicuous, stock outward appearance.
  9. #4117
    Sep 2004
    Largo, FL (Pinellas County)
    Quote Originally Posted by KoreanBeefcake
    I think he means afterfire.
  10. #4118
    Registered User scooby24's Avatar
    Mar 2004
    Kansas City
    How is this even a thread? Aren't there a billion other threads on BOVs?
    No running rich is not bad for the engine, just performance.
    Yes the stock BPV is junk. Zem take yours and take off the recirc pipe to make it amtospheric and that will give you and idea as to why it's junk. And no it really doesn't hold that much boost. I could hear my stocker leaking boost at anything over 14 lbs. The only reason you don't notice is because it's recirc and goes back into the intake.
    You can get an aftermarket BOV without having to seem like a ricer. There are some very good recirculating ones. I have the Greddy Type-S and have been nothing but pleased with it. The car runs much better with it than it did with the stocker.
    I would not recomment an atmospheric is you want good performance. I took my greddy and made it atmospheric, ran it at the track, then put it recirc and ran again. I shaved off .2 seconds from my 1/4 mile time.
    05 Crystal Gray STi
    304 hp 353 lbs on 92 octane ------> Mustang Dyno
    12.6 @ 109.2 > new numbers coming soon.
  11. #4119
    Registered User racerWRX's Avatar
    Jun 2002
    steeltown
    im running the txs rfl with straight (almost) exhaust....just the oem mid pipe is left and no muffler just a straight pipe there too...and i get a back fire about 1 out of every 4 shifts at low rpm ranges. anything above 4500 rpms i dont believe i ever had a backfire occur.
    mike
    have you ever been 4 bagged ???
  12. #4120
    Mar 2002
    arvada, coloRADo
    Quote Originally Posted by racerWRX
    mike
    I'm pretty sure that you are experiencing AFTER fire. Which is unburned gas, igniting in your exhaust, making a popping sound. A back-fire is when a flame front moves back through the induction system, which can be a dangerous situation.
  13. #4121
    Mar 2002
    Calmer than you are
    article for those of you looking for that WRC noise (not BOV)
    http://www.rallycars.com/Cars/bangbang.html
    I know that the really cool noise you associate with WRC cars is not made by the BOV (although a lot of people still try it) but I have never been able to find exactly HOW the noise is made. Most people will just say "its the anti-lag system" but offer no explanation. Well I found one and guess what? Not only is it expensive, but unless you've got a garage full of spare motors, its NOT gonna happen.
    go f*** yourself
  14. #4122
    Registered User djrez4's Avatar
    Colorado
    Adding washers changes the spring tension. The more spring tension, the more boost you'll have to run to vent it.
    Eli....it's better than he bumped this old thread than started a new one. Ideally, we'd only have one Type-h thread with everything you'd ever want to know.
    Deliberating enclaves of like-minded people are often a breeding ground for extreme movements - Cass Sunstein
  15. #4123
    Banned truWRXtacy's Avatar
    Sep 2004
    Colorado
    Quote Originally Posted by scooby24
    my car is completely stock and i live way the hell up in colorado high altitude, so you would recommend the greddy type-s?
  16. #4124
    Mar 2004
    Kansas City
    Quote Originally Posted by truWRXtacy
    The thinner air would create a little less pressure but the greddy has two internal springs for adjustablility. Mine currently has both in and works fine so if you remove one there should be no problems.
    05 Crystal Gray STi
  17. #4125
    Sep 2004
    Colorado
    so run the Greddy Type-S BOV with only 1 spring and i should be set to go, and wouldn't get rich?
