"The BIG BOV thread" (Where all bov question threads get merged) - Page 269
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I looked around and didn't find a install readily available for the Forge BOV so here is mine. 1. The ...
  1. #4021
    Sep 2004
    Langhorne PA
    Forge BOV Install :)
    1. The Forge BOV comes pre-loaded with a spring. You'll also get 3 more springs. If your stock or close to it use the spring that comes in it. You'll also get three little washer type deals. One washer for each seperate spring. Last but not least you'll get this little metal cap.
    2. There are two bolts holding the stock BOV. They are both 12mm and should be taken completly out.
    3. Using a flat head screw driver and bit of pulling remove the vaccum hose on the right side of the bov. (Right side if your looking from the front towards the back)
    3. Now pull the stock BOV out past the intercooler. There will be a big vaccum hose attached to the bottom left hand side and you will use a pair of pilers to crimp the connector together. At the same time pull the bov completly out.
    4. The metal cap peice that come with the Forge BOV get put into the big vaccum hose. Using the pliers crimp the connector together and push the cap until it sits flush. Release the connector.
    5. Bolt the Forge BOV into place using the stock 12mm bolts.
    6. Reconnect the vaccum (smaller one) hose on the top right of the BOV
    7. Get in your car and enjoy
    To finish first, you must first finish
  3. #4022
  4. #4023
    Registered User Imprezive's Avatar
    Aug 2004
    Medina, OH
    where can i get a gfb stealth from?
  6. #4024
    Mar 2003
    lincoln, ri
    2 washers is not enough for a txs rfl bov.
  7. #4025
    Registered User kessler89's Avatar
    May 2004
    NW Ohio
    Quote Originally Posted by ride5000
    what do you suggest i run then? my mods are TBE, up, txs rfl, and the mbc
  8. #4026
    Registered User KoreanBeefcake's Avatar
    Jul 2003
    Huntsville, Alabama (formerly WA)
    i heard most people using 4
  9. #4027
    Registered User Airborne Guy's Avatar
    Jul 2004
    Ft. Lewis, WA
    txs rfl bov
    i run 2, it is just fine... stock boost
    i have experimented with more washers. in my opinion 4 is too hard for stock boost. i ran as much as 5.. I DO NOT RECOMMEND THAT!! anyway with 3 or more a lot of the time it felt as if i was running the cruise control when i let off the gas. so i am running 2 washers and am very happy. oh and by the way make sure you take it apart every now and then and clean it too.
    PICTURES
    OBP Impreza WRX STi Stage 2 @22psi. MasterTuned on 94 octane. PIA Dyno'd at 301 AWHP & 330 AWTQ only could boost at 19psi on the dyno so not sure what it would be at 22psi.
    (Cenex Gas http://www.chsinc.com/auburn/Tacoma.htm )
    Quote Originally Posted by dewmudgeon View Post
    ok, so if i wanted a bov and got a cai as well,
    would they equal eachother out? creating minimal problems?
  10. #4028
    Moderating U! KurleeDaddeeWRX's Avatar
    Mar 2002
    San Jose, CA
    PTFB is an engine killer no matter how you look at it. If you want your $25k car to last, get some type of engine management and run the boost control from it. The boost control from the UTEC and the EcuTek are almost as fast as a MBC, but much more safe to run. I understand a lot of people can't afford the money for a UTEC or a EcuTek. But if you want your motor to last, do it right. Believe me. I have run almost every type of boost control there is on my WRX. I have had a bleeder type TurboXS bleeder valve, a Joe P. ball and spring type MBC, a Blitz SBC-id, a UTEC and an EcuTek. I never really felt safe with the MBC or the EBC. But the UTEC and EcuTek boost control was very reliable and didn't spike too much on cold days, as would an MBC.
  11. #4029
    Jun 2003
    Canada
    I agree, better off to get some engine management to control your boost. You forgot to mention COBB Acessport.
  12. #4030
    Registered User zoinks's Avatar
    Dec 2003
    Portland, OR
    Engine management is definitely the best way to go, but you can put a solenoid on the mbc so that you can flip a switch and go from stock boost control to mbc. I'm still holding out for EM though...anyone want some morettes
  13. #4031
    Aug 2003
    Norway, Europe
    No problem with my MBC, but I have the same "problem" with PTFB. But that comes with the mod.. No problem you just have to change your driving style and adapt.
    ECU mod is ofcource the best and safest, but also more expensive.. Everyone has to make up their own mind about whats best for them.
    Silver -02 Impreza WRX
  14. #4032
    May 2004
    NW Ohio
    Quote Originally Posted by zoinks
    was wondering about this... anyone know where i might be able to get some DIY instructions, or talk me thro it??
  15. #4033
    Registered User scooby24's Avatar
    Mar 2004
    Kansas City
    Quote Originally Posted by AIRBORNEGUYWRX
    I was running 3 washers when the car was stock. Then I bumped up to 4 after I was catless and tightened the wastegate and was running 14.5 psi. Then I wisened up and bought the Greddy Type-S
    05 Crystal Gray STi
    304 hp 353 lbs on 92 octane ------> Mustang Dyno
    12.6 @ 109.2 > new numbers coming soon.
  16. #4034
    Registered User ebr0t's Avatar
    Aug 2002
    U of Central Florida (Orlando)
    Best BOV confusion yet...
    So I'm drivin home, and its typical 6 oclock traffic. Some guy, id say mid 50s pulls up next to me in a convertable sebring. His son motions for me to roll down my window. When I do the dad yells "you have like a really loud metal/metal noise when you shift" I pop it into neutral and pull the ebrake (on a hill) and rev it up and let the rfl go off. "is that it?"
    "yeah"
    "oh ok"
    then i drive off.
    Quote Originally Posted by DTR rex
    Peter North > *
  17. #4035
    Registered User Steve-o's Avatar
    Aug 2002
    WRBTURBOWRX: When I grow up I hope I can be 1/16 as cool as you.
    Steve (WRBTURBOWRX )
    WRB WRX: Super 16g Equipped
    www.BrotSpec.com
