"The BIG BOV thread" (Where all bov question threads get merged) - Page 265
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Sounds like your BOV is too loose and its leaking at idle. Adding washers should help. My greddy BOV vta's ...
  1. #3961
    Registered User WRXskier's Avatar
    Apr 2004
    Allentown Pennsylvania
    Sounds like your BOV is too loose and its leaking at idle. Adding washers should help. My greddy BOV vta's and i have no idling problems because it is tight enough to not leak.
  3. #3962
    Registered User hellafastWRX's Avatar
    Sep 2003
    Huntington, Long Island..... NY
    AP and BOV
    My only mod is an AP, but i am considering getting a blow off valve. Has anyone had any problems with engine performance/ low idle / stalling with the two?
    --Chris
    2011 DGM WRX hatch - Kartboy SS
    04 WRX wagon - 304whp Mods - SOLD
    LISC #3
    www.longislandsubaruclub.com
  4. #3963
    Boba Fett BrianH's Avatar
    Oct 2003
    Way up high.
    are you running higher boost levels? Considerably higher?
    No, take the BOV throw it in the trash and put your stocker back on.
    5 minute solution.
  6. #3964
    Oct 2003
    Way up high.
    Why would the stock be one of the worst? Because it just doesn't cut it as a noise mod? The stock bpv's are good for some pretty high-boost applications.
    Originally posted by scooby24
    Have you tried any other BOV other than the turboXS? I've tried stock as atmospheric, TurboXS RFL, HKS, and now Greddy. Greddy wins hands down. HKS is in second. TurboXS and stock are tied for worst BOVs evAr
  7. #3965
    Registered User Quack's Avatar
    Mar 2004
    Lakewood, OH
    you do know that the BOV just makes a PSSSSSHHHHH sound and may cause you idle go to crap. depends on which BOV.
    fourstardrift has been running a HKS SSVQ on Cobb stg2 w/o any problems.
    for the cost of the BOV's i'd suggest a DP to get you into Stg2.
  8. #3966
    Registered User IDAFC21's Avatar
    May 2004
    Avondale, AZ
    im running a GFB hybrid on AP stage 1, no problems that i can tell. Holds boost well still, no idle problems, but this one recirculates as well as vents. its not as loud as id like it to be, but it can definently be heard when you wind it up to 5 or 6k
    I wanna try it on 100% atmosphere and see if i have any problems, but its such a pain to switch
  9. #3967
    Registered User TheBoostCreep's Avatar
    Apr 2004
    Merritt Island
    Gonna slap a Forge BOV on my Cobb stg 2 probably tomorrow. Getting it free from a friend to use for now, so I figured "what the hell". If it hinders performance, or just annoys me too much, I'll take it off.
    I'll give my impressions once I get it on.
    FWIW, the guy giving it to me has a WORX dual-stage BOV on his simliar Cobb Stg 2 setup and has no problems. He vents 100% atmosphere.
    I'm TheBoostCreep, and I approved this message.
  10. #3968
    Registered User VSGTS14's Avatar
    Apr 2004
    Milford, NJ
    i had stage 1 AP...then got my Forge BOV on and it was completely fine
    love it
    FP Green STi
  11. #3969
    Registered User ST_eye's Avatar
    Sep 2004
    What BOV to get?
    I got a 05 STi and just wanted to know if i can just buy the BOV
    to work with my stock intake or do i have to buy them both to work?(Intake and BOV) Another thing is should i buy the Turbo Timer to go with it too and is it worth it buying? I'm a newbe here
    and to boost so take it easy...on me. Thanks!
    '90 CRX Si (rip)
    '00 civic Si (rip)
    '02 EP3 Si
    '05 WRX Sti (Stocker)
    Dam I love 'S' 'i' and now the "T" is in the middle I even love it more!
  12. #3970
    Registered User power091999's Avatar
    Jul 2003
    Well before the bad guys get you. If you use the search function at the top right. TRUST ME you will find TONS of this same exact question.
    Welcome to the club btw.
    As far as I am aware. You only need a BOV if your looking for the sound. It does not have any kind of performance gain, just sound.
    As for your TT question. I can't really help there.
  13. #3971
    Apr 2004
    Milford, NJ
    buy the Forge Atmospheric BOV...i have it and it works perfectly, no problems...
    and for intake, i got the perrin shortram and once again...no problems
    FP Green STi
  14. #3972
    Apr 2003
    In Ray's house while he's jacking it in his car.
    Both a blow off valve and a turbo timer are completely useless mods. If the BOV is 100% atmospheric, it can hurt performance.
    The turbo timer is completely unnecessary, and you should only get one if want a digital boost gauge, or if you want the novelty of having your car cntinue to run after you get out of it.
    Save the money and buy a better mod (downpipe).
  15. #3973
    Registered User KoreanBeefcake's Avatar
    Jul 2003
    Huntsville, Alabama (formerly WA)
    if you really like the intake sound search on removing the silencer in the fender. i bought a K&N short ram no probs.
    if you like the noise get the bov but it may or may not hurt your car.
  16. #3974
    Sep 2004
    Will i get any CEL if i get the DP and UP? What about smog test?
    Will i past?
    '90 CRX Si (rip)
    '00 civic Si (rip)
    '02 EP3 Si
  17. #3975
    Apr 2003
    Will i past?
    You don't need an uppipe in an STi. Yours is catless. There are ways to pass smog catless,a dnthere are ways to avoid CELs. Seacrh for them.
