This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; you should also search and read about putting a BOV on a stock wrx.....
  1. #3796
    Registered User XxScoobYxX's Avatar
    Apr 2003
    chicago
  2. #3797
    Registered User Snowvert's Avatar
    Mar 2003
    sound based, just like a muffler. I have the blitz and am happy with it. lots use the worx, which is also a good choice.
    there was a link with some sound clips floating around. run a search on here and i'll try to dig the link up myself.
    03 wrx - 300whp/270wtq
    Originally posted by zoophagy
    The people that work there are, for the most part, retards. I used to work there.
  3. #3798
    Mar 2002
    Tokyo, Japan
    BOV's on stock WRXs aren't usually the best idea. You'll run pretty rich and get sh*tty gas mileage.
    "I don't think he knows how to give up. His mind and machine are racing as one." -Takahashi Ryosuke
  4. #3799
    Jul 2004
    West Covina
    wat should my first mod be n what exhaust should i get
  5. #3800
    Apr 2003
    chicago
    try doing a search for First Mods...you'll find a ton of info, usually first mods are turboback exhaust and up pipe and maybe a MBC
  6. #3801
    Jul 2004
    West Covina
    cool thanks ill look into that first. i guess ill just buy thE BOV without installing because im getting a pretty good price for it. also jw, why are people so against bov? does it harm your car?
  7. #3802
    Jul 2004
    West Covina
    are the greddy evo2 exhaust pretty good?
  8. #3803
    Registered User STIdrmz's Avatar
    May 2004
    Cherry Hill, NJ
    Got it a www.Boostkits.com. The order took forever but it wasnt their fault and ANthony did whatever he could to let me know the status. I belive the crinkle reds are on backorder forever so check before you buy.
    I have it set to 50/75 because I still like hearin the sound. WHen i get less wowed by it i'll take it down a notch. I haven't set to to full recirculation yet but i'll try it tonight and let ya know.
    ____________________________
    2005 STi Aspen White/Gold
    http://www.cardomain.com/memberpage/625405
  9. #3804
    May 2004
    Cherry Hill, NJ
    oops "25/75" - i'm a dumbass
  10. #3805
    Apr 2003
    chicago
    a BOV just isnt necessary, the stock bypass valve can handle up to around 18-20 PSI, and a aftermarket BOV which people usually run 100% atmo, makes the car run rich in between shifts, some people have problems with it and some seem to be fine. Its up to you but its not gonna gain you any HP or anything just a sound.
  11. #3806
    Registered User SweetTurboWhine's Avatar
    Jan 2004
    Reading, PA
    the stock bypass valve helps the turbo continue to spin even after the throttle is closed, thats why theres a hose leading from the bypass valve to right before the turbo. what a 100% atm bov does is surge all that air straight outside the egine. now i dont want to say that the turbo comes to a screaming halt but it slows down quickly and significantly. so once you get back on the gas after shifting the engine has to work to get the turbo to spool back up. shift and the process repeats.
    woooo
  12. #3807
    Jan 2004
    Reading, PA
    when we say that it'll run rich for a few seconds heres what we mean.
    the stock ecu wasnt programed for a atm blowoff valve, it was programed for the bypass valve. so what the ecu is doing is its assuming that theres going to be all that blown off air that you created by shifting, back in the intake tract ready to go, so it gives the engine a good deal of fuel to start you again after you shift. a bypass valve will maintain that a/f ratio. however, a bov throws the air into the engine bay leaving your a/f rich when accelerate.
    woooo
  13. #3808
    Dec 2003
    Texas
    bov problem and need help
    I got a turbo xs rfl bov, and recently i just went on vacation from san antonio to colorado. But right when the altitude started to change in santa fe, the bov stopped working and would not open. I was wondering if this may be caused by the altitude because i have no leaks and my stocker works just fine. I miss my bov but im thinking of just selling it if anyones interested in a used rfl with return plug and the adapter plate
    05 silver sti
  14. #3809
    Jul 2004
    West Covina
    bump
  15. #3810
    Dec 2003
    socal
    i have the hks ssqv....i like it especially with some sort of exhaust to back up the sound.....i would recommend it...of course if ur just looking to make your car sound a little bit better
