"The BIG BOV thread" (Where all bov question threads get merged) - Page 245
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Have not heard good things about the turbosmart products....
  1. #3661
    Registered User silversti's Avatar
    Jun 2003
    Owings Mills, MD
    04 STI
    FPGreen
  3. #3662
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Ditto. Might want to consider going back to stock, or getting a better product such as an RFL (if you are into the noise) or a Worxtuning (for the beuaty and functionality).
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
  4. #3663
    Registered User slowmo's Avatar
    Mar 2004
    Oregon
    The HKS SSQV was my first mod.... Best price i could find it for was 225..
    Try using the search button.
    I didn't really like the 100% atmosphere BOV. The only thing cool is the sound, and it caused the turbo to lag between shifts (no recirculation) Ran really rich between shifts too. Stalled in reverse.
    Stock BOV is good for upto 19 PSI or so. If you want sound get a blitz SUS intake and remove the silencer. You can hear the turbo and the BOV a lot better.
  6. #3664
    Registered User 13secwrx's Avatar
    Apr 2003
    Its a pretty straight forward install. Pull the old one off and pop the new one on.
    I run the turbosmart plumb back bov and I love it....def. recommend it. I had the rfl from turbo xs and I loved the sound but hated that I ran a little richer ...
    L.I.S.C #00 (Treasurer)
    02 Wrx...465whp and 472 whtq. 100 Octane
    387whp and 371 whtq. 93 Octane
  7. #3665
    Registered User wagontrained's Avatar
    Jun 2004
    Va
    dual-port bov
    whats up guys? I have a question about my bov, I have a turbosmart dual-port and when im runnin' the s#*t out of it, it sounds fine but when I drive it normal and I let off of the gas it sounds like a flutter in the intake. Can anybody tell me if this is normal since its a dual port? Any info would be appreciated.
  8. #3666
    Registered User GotRice7169's Avatar
    Jun 2003
    Tampa Florida
    mine does the flutter too but not in the intake. My friends 1.8t had that and someone said it was bad but that was because he had it on backwards and it was going back to the wrong place. That might be your problem or its just the atmospheric port is fluttering cuz theres not enough pressure to fully open the piston, thats what mine is i think
  9. #3667
    Registered User NOTimprezed's Avatar
    Apr 2004
    huntington beach
    that "flutter" is your turbo... its not blowing at the low boost enough, and the air is reverting to the turbo... that is why the factory BPV is routed to send air to the low pressure side... before the turbo. this helps to spin the turbo and make spool for next gear faster.
    this is all IF, that flutter is the same flutter i'm thinking of....
    Definition of “rice”; to install or want items which makes the vehicle “cheesy” in appearance or in ist function. The term is more often than not used by non-Asian races. Also, the products or style used and defined as “rice” is more often than not manufactured and sported by non-Asians.
  10. #3668
    Registered User travgwrx's Avatar
    Jan 2004
    NC/IN
    Blitz FMIC and txs bov???
    I'm having the Blitz FMIC installed and was wondering if the piping comes with a place for my txs bov? is it usually just drilled/welded on? or is there a place in the piping to direct fit it?
    thanks
    TRAV
  11. #3669
    Jul 2004
    NJ
    i know where
    http://www.lancershop.com/blow_off_valve.htm
    i am pretty sure the trumpetis a universal piece of the stealth bov.... its on that web page its like 25 bucks...
  12. #3670
    Registered User Snowvert's Avatar
    Mar 2003
    this thread is a year old.
    03 wrx - 300whp/270wtq
    Originally posted by zoophagy
    The people that work there are, for the most part, retards. I used to work there.
  13. #3671
    Registered User AdamRmr's Avatar
    Jun 2001
    santa fe ,,NM
    more photo's of the girl!
    03 Ducati 749s
    APS Improved 04 STI Photos/specs
    www.MinosAuto.com/Adam.html
  14. #3672
    Registered User MJU1983's Avatar
    Dec 2001
    Saint Louis, MO
    This describes what i thought when i read/saw your post.
  15. #3673
    Dec 2003
    Southern California
    Called cobb the other day about this and they told me that adding a BOV would affect the car the same as adding it with the stock setup.
    R.I.P. 04 Java Black Pearl WRX Sedan
    Wanted - 99 - 01 2.5 RS Coupe Any Color
  16. #3674
    Jun 2004
    NY
    alright thanks for all responses guys i think im gonna go with the gfb 50/50 thanks alot
    jimmy
  17. #3675
    Jun 2004
    Va
    dual-port BOV
    I have another question, is the noise that its making gonna hurt anything, and if so what can I do to fix it? I called the place that I got it from and they told me to keep adjusting it and it would stop doing it, but the only adjustment is the cap on it turns left or right (left-soft and right-hard) and ive beed doing that and it hasn't stopped. Anyway if you guys could help me out wit this I would really appreciate it.
