"The BIG BOV thread" (Where all bov question threads get merged) - Page 244
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Thats odd. They responded to all of my orders. Even overnighted the valve for me when they found out I ...
  1. #3646
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Thats odd. They responded to all of my orders. Even overnighted the valve for me when they found out I needed it quicker for a show. Ate the cost of it even. Hmmmmm....maybe they are getting backed up?? It did take almost a month to ship my exhaust and that pretty much sucked, but I've been able to get Mike on the phone usually when I call. Go figure...
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
  3. #3647
    Oct 2003
    Chino Hills, CA
    no but that sig is .................................................. ..........................
    .................................................. ..................................COOL?
  4. #3648
    May 2004
    worx still has not responded to my emails.......
  6. #3649
    Jul 2004
    Texas
    TURBOSMART dual port bov
    I just bought the turbosmart dual port. I was wondering if anyone could give me any tips on setting it up. it comes preset for the regular wrx. The sti makes more boost so it leaks like hell. I already tightened it quite a bit. How do i kno when it is set just right. Should it blow off everytime i shift??? Even at low rpm's. Or should it just blow off when i get the rpms high. Right now i can rev it up in neutral say about 5k and let off and it will open up. any help is appreciated.
  7. #3650
    Jun 2004
    NY
    Accessport BOV Question
    Hey whats up I ordered my accessport 5/03/04 and i am greatly anticipating its arrival. I have a question tho i plan on running stage 2 which puts out anywheres around 16-17 psi of boost. I was wondering if people were running an aftermarket bov or the stock one? and if it were ok to frun an aftermarket setup most likely the GFB 50/50 one and not mess anything up with the programs.
    thanks alot
    jimmy
  8. #3651
    Jun 2004
    no real need to run a bov, but if you do...a hybrid is better than a fully atmospheric.
    Vanitas vanitatum...et omnia vanitas
  9. #3652
    Registered User Rippa's Avatar
    May 2003
    Greddy BOV Help!!!!
    I'm not sure what the problem may be but I don't get that signature whistle the Greddy Type-S usually gives. I have the return hose plugged. Instead of hearing the whistle after I let off, I hear nothing!! It sounds like a boost leak while boosting cause I can hear the turbo spooling like if it was a supercharger. I see on my boost gauge that it holds boost fine, But I don't have the sound. I checked for leaks and even tweaked the adjuster screw but still nothing. Anyone know what the deal is?? Any info would be greatly appreciated!!
    Thanks in advance,
    Will
    310whp / 309trq @ 19psi
    Now with 6 Flavors of JDM Goodness!!
    MODS
  10. #3653
    Registered User sd-wrx04's Avatar
    Jul 2003
    San Diego, CA
    Does your BOV looks like this? I would check to make sure that black hose on the bov is on there securely, check to make sure that the bolts are tighten from the flange to the the intercooler then the bov to the flange. Did you replace the gasket that connects the flange and intercooler?
  11. #3654
    May 2003
    My BOV looks exactly like that, but the venting hole for the bov is facing the other way. Could that possibly be the problem?? What if I just turned the hole to vent out the way you have it? I made sure everything is on nice and tight. The only thing I left out was the long hose with the tee. I made the BOV fit without replacing the metal lines running parallel to the intercooler. Could that be the problem???
    MODS
  12. #3655
    Jul 2003
    San Diego, CA
    That could be the problem...why didn't you just use the replace hose and "T" connector? Did you get the instruction that came with the BOV? I know its in Japanese and all but there are pictures of how it's suppose to look.
    I would suggest you face the GReddy BOV like the way I had it. And see if that fixes your problem.
  13. #3656
    Registered User WRX-Z's Avatar
    Feb 2004
    Houston
    I'm stage 2 right now and have the GFB Hybrid set at 50/50 and runs fine. I havent had any problems.
    <<My car
    COBB Stage II --- 8.52 @ 81mph in the 1/8 mile
    Mods
  14. #3657
    Registered User wake2snow5's Avatar
    Jan 2004
    Ellensburg, WA
    I also have a GFB set at 50/50 with Cobb's VF34 map and I am running fine. I wouldn't go for a full atmospheric bov.
  15. #3658
    Jan 2004
    Colorado
    another GFB 50/50 user here, I first put the BOV on 100% atm and the car didnt really run too good, I wasnt planning on keeping it that way I just wanted to see how the sound was etc.. but I have since had it set to 50/50 with no problems.
    2004 WRX completely stock! And becoming even more stock daily.
  16. #3659
    Jul 2004
    Texas
    thankyou for all the replies i really appreciate it.
  17. #3660
    Sep 2001
    Edmonds, Washington
    What's wrong with the stock BOV? Your BOV should pop whenever your throttle plate closes yet not leak while on boost. You pretty much want it to pop whenever you start making positive manifold pressure to avoid compressor surge. Just so you know, stock BOVs are good in to the 18-20 psi range and aftermarket ones do NOTHING for performance if you aren't running a turbo that runs more than 18 psi.
    http://homepage.mac.com/supermarkus/PhotoAlbum1.html
    Mullet haiku:
    Daughter's BMX
    Takes me to welfare office
    Trans Am is on blocks
