Cool, one more ?Originally posted by WRXrumble
I use hose same size as the FBC to connect to the MBC output side. Same size hose goes from dwaes to wastegate. No fitment problems. From Bootvalve to BOV I used the hose that came from Bootvalve
I also added the 1/8 restrictor mod to the scheme and it works well.
FBC = 14.5 psi most gears
MBC = 16.0 psi most gears.
When I reuse the factory restrictor the car feels so sloooow it is unreal.
Did you run the negative wire from dawes to ground or did you run it from the switch. I aint too good on the electrical side![]()
LinkBack URL
About LinkBacks
