"The BIG BOV thread" (Where all bov question threads get merged) - Page 212
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; i did i search fellas but i would like some personal input with people who have experiences .... .. . ...
  1. #3166
    Registered User ibobby di's Avatar
    Feb 2004
    New Jersey
    please help me out with a BOV question .
    i did i search fellas but i would like some personal input with people who have experiences .... .. . i ordered the ACCESSport , HELIX uppipe & turboback , sti injectors , V34 turbo , and walbro fuel pump . could i get a blow off valve even though for just the purpose of the sound ? the only thing i dont want is a decrease in performance or hurting any of my other mods . and wat blow off valve would you guys recommend ? thanks alot
  3. #3167
    Registered User BoostedBoxer's Avatar
    Mar 2003
    NOR*Cal
    yes. You will be fine with a bov. I am against BOV's however, but someone else can recomend you one.
    My Car is 100% STOCK!
    Pics
    Originally posted by platano
    At 14???
    shoot , I'd hit it at current age, on roof of the car, with cousin driving , neighbor and town priest in the back seat, and that kid from "N.Korea" riding shotgun.
  4. #3168
    Registered User Matt Monson's Avatar
    Apr 2004
    Colorado
    I too am against replacing the BOV because the factory one is fully functional. Just make sure you get a Subaru specific one that is hybrid to reciculate and vent to air. If you don't you will confuse your MAF and have erratic performance at various rpms...
  6. #3169
    Registered User Snowvert's Avatar
    Mar 2003
    if you aren't running 20psi+ (give or take) there is no point.
    if you have $200+ to spend on a bov, just for sound - put that towards something more useful.
    I have the blitz and recommend it, but only when there is a point to having one.
    03 wrx - 300whp/270wtq
    Originally posted by zoophagy
    The people that work there are, for the most part, retards. I used to work there.
  7. #3170
    Mar 2002
    Calmer than you are
    any WRX-specific BOV will work fine as long as you put it on right and there's no leaks.
    go f*** yourself
  8. #3171
    Feb 2004
    New Jersey
    i was doing some searches . . how about turboxs rfl bov and turboxs short ram intake ?
  9. #3172
    Registered User slowmo's Avatar
    Mar 2004
    Oregon
    I'm thinking of going with the GFB hybrid, or APS. Both use recirc. I had HKS SSQV and had NO problems w/stalling. Only time it did stall was in reverse. Never while driving. The difference between atmospheric and stock valve is amazing. Pulls so much harder after shift. All around seems to drive MUCH MUCH better. In high boost applications an aftermarket BOV would be necessary. If I read correctly, the APS uses Recirc unless you are running really high boost, then it passes recirc and goes to second vent. Even w/tuning, between shifts w/o recirculation the turbo looses spool. Can you run recirc on high boost? Like 20+ lb?
  10. #3173
    Mar 2004
    Harrisburg, PA
    Is BOV leaking?
    I got a stupid GFB blow off valve put on a month ago and ever since it was installed, my car began to run progressively worse. It used to blow off just fine, then it started to make a putt putt putt noise and rarely blew off, and now it doesn't make any noise. The car now feels extremely bogged in between upshifts. Obviously something isnt right, but is the BOV leaking, or is it something else???
  11. #3174
    Registered User Wrinkleboi's Avatar
    Jan 2002
    Langhorne, PA
    did you buy it new? are you sure you installed it correctly? check all your hoses and lines to see if there is a leak. if you bought it used maybe there was something wrong with it, or it might just be due for a cleaning and some graphite lubrication.
    o-|-<) bryan
    edit: if that bov doesnt recirculate at all, did you plug the recirc hose?
    -2003 Blue WRX, complete 2007 STi Engine/Drivetrain transplant - Pic 1 | Pic 2 | Pic 3 | Pic 4 (new!)
    -1994 Black Supra TT 6MT - Pic | Build/Restoration Thread: 67mm, Fuel, Painted Engine Bay, Fuse Box Relocation, Wire Tuck, etc.
    www.TriStateTuners.com
  12. #3175
    Mar 2004
    Harrisburg, PA
    oh its brand new, i bought it from mastrowrx.com. i had it installed at a japanese performance shop. i wrote a note for them to do the 50/50 setup, but they didn't and plugged the recirc hose. i am going to take it back soon anyways. i just didnt know if the actual BOV can leak, because i heard that happens. And since it gradually seemed to die, it makes me wonder
  13. #3176
    Aug 2003
    Norway, Europe
    A friend of mine put that bov on a evo 6 and lost almost 100hp@crank ! I can tell you he was suprised when he saw the dyno numbers
    Silver -02 Impreza WRX
  14. #3177
    Registered User ***biGRed***'s Avatar
    Oct 2002
    Forge BOV spring question
    Which spring should be used on basically a stock car? (perrin intake & cat-back exhaust) The blue spring was originally inside already and since this is the 2nd stiffest I was wondering if I should be using the yellow or green spring instead? Also, Forge did not include the yellow and green springs with my BOV only an extra blue and red spring. Do you think they will ship the other 2 springs if I ask? I know they sell all 4 sprnigs for like $15 but also, $12 shipping. ouch.!!
  15. #3178
    Registered User NJwrbT-WRX's Avatar
    Apr 2002
    One Square Mile, NJ
    I will help you only if you PM a link to the pic in you avatar!!!!!
    OK, I will help you anyway, but you better PM me that link!!!!
    I had the forge for a while. I had the blue, red, and yellow springs. I personally never found one of them to work perfectly. I would say, just try all three for about a week a piece, and see which one works the best. I had MBC, uppipe, IC hoses, and crank pulley at the time, and I think my car ran best on the medium spring (I forget the color, but you can definately feel the difference). I got the springs with the BOV, did not have to pay extra for them. That sucks if you do have to pay for them now, I thought Forge just hooked people up.
    With a basically stock setup you are going to want a weaker spring IIRC.
    -joe
    '02 WRB Sedan
    Removed silencer w/ Akimoto Velocity Stack, Blitz Dual TT, Autospeed Prototype Up-pipe w/ Flex-joint, Autospeed Crank Pulley, Autospeed OEM Dead Pedal, Samco IC Hoses, Axxis Pads, Goodridge Lines, Neo Synth Brake Fluid, Speedbleeders, Eibach Pro-Kit, Perrin Endlinks and Rear Sway, 17" Sub Zeros w/ 225/45 ES100s, Crucial Racing Thermostat and 1.4bar Radiator Cap, Autometer Sport-Comp Oil Pressure, EGT, and Voltmeter on the A-Pillar, STI Hoodscoop.
  16. #3179
    Registered User happasaiyan's Avatar
    Nov 2002
    Rolling Meadows, IL
    umm....uh.....what were we talking about, again?
    '04 PSM STi - modded (sr50+the works)
    '05 JGM RSX Type-S - stock
  17. #3180
    Re: Forge BOV spring question
    Im running stock boost on my 04 and Im using the green spring with 2 spacers. I tried out they yellow spring, but it flutters sometimes. With just the green in, it blows off a little too much, so I threw 2 spacers in there and it seems to be good now. No flutter, and it blows off when I want it to.
