"The BIG BOV thread" (Where all bov question threads get merged) - Page 209
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; no 20psi here , but the SSQV is working pretty well. Robert~...
  1. #3121
    Registered User StaticX313's Avatar
    Jul 2003
    Huntsville, AL 2004 Blue\Silver WRX STI
    Robert~
    Static X Motorsports, INC.
    A ChriSTIan Corporation
  3. #3122
    Jan 2004
    california
    thanx for that schaf cleared things up for me really well =)
    you'll have my license plate memorized by the time were done racing =)
  4. #3123
    Registered User renichms's Avatar
    Jun 2003
    Birmingham, AL
    HKS SSQV for at least 17,500 miles without a problem.
    RN
    2004 Subaru Impreza WRX STi - WR Blue/Gold wheels
    60': 1.768
    1/4: 13.155 @ 102.02 MPH
  6. #3124
    Feb 2004
    Buffalo, NY
    I got the RFL with 4 washers in it; works good.
  7. #3125
    May 2002
    No problem, glad I could help
    -Michael
  8. #3126
    Registered User silversti's Avatar
    Jun 2003
    Owings Mills, MD
    Dave,
    I ran the Blitz DD for about 1,000 miles. My idle was horrible. I took it off and went with the Worxtuning set to 75% recirculate. We will have to see if it will work once the motor is reassembled and running higher PSI.
    04 STI
    FPGreen
  9. #3127
    Registered User ryland's Avatar
    Apr 2002
    NY
    After using a Forge 100% Atmos BOV for about a year I have concluded that you do want at least some of the air to be recirculated. I noticed a few things with my Forge valve that I don't notice with my stock valve. Specifically, shifting is MUCH smoother with the stock valve. Also, picture in your head a series of S-turns, where you will be transitioning on and off of the throttle, maybe from 30% to 50% to 10% to 0% to 75% etc. In that situation, with the Forge valve, the car would hesitate pretty badly, shaking the car a bit. With the stock valve you can move the throttle around as much as you want and it remains incredibly smooth.
    I also have a Perrin short ram intake. With this setup, at WOT, the stock BOV is very audible. I am selling my Forge valve and will probably get a WorxTuning valve because they have infinite adjustability between recirc and atmospheric release.
    2004 Black WRX Sedan
    Mods = yes
  10. #3128
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    he's getting hosed by the dealer.
    did he even pull the code? what's the "damage?"
    you are right, those are not the right mods to start w/ but wtf is wrong w/ the car?
    dR
  11. #3129
    Registered User platano's Avatar
    Feb 2003
    Miami
    Sounds like BS.. my car has been running without a problem, and I have the Injen CAI, BOV, and aftermarket exhaust.
    Like said above, it would make sense that he's getting codes if the TXS exhaust is in place and the cats are out. But doesn't neccesarily mean that the sensors are bad. Is just that the sensors aren't reading what they're supposed to, because the ECU assumes everything is still the same (stock).
    Quote Originally Posted by zoophagy
    Happy Birthday. May all your birthday dreams come true except for the one were I come over to your house, and you timidly ask me if I have ever kissed another guy before, and it ends up some weird poo porn movie.
  12. #3130
    Registered User supercompact's Avatar
    Aug 2003
    Knoxville, TN
    I have the Greddy Type S and it will occationally make the car stall when I pull up to a stop sign or red light. It makes my exhaust pop and shoot flames sometimes betweens shifts too. It very seldom stalls, but it does happen. I probably have the valve set too loose or something though.
  13. #3131
    Sep 2003
    Chicago, IL
    I was runing a Turbo XS type H and had some small idle problems. little sumble here and there nothing major. The thing that i didnt like the most was the twitchy shifts.
    I just switched to a Turbo Smart 50/50 valve. The cool thing about it is under light shifts its 100% recirc. Then under high PSI shifts its 50 /50. By far the best quality BOV ive ever seen.
  14. #3132
    Oct 2003
    Chino Hills, CA
    GFB stealth fx full atmo no problems
  15. #3133
    Feb 2003
    Miami
    GFB 20K miles... I've noticed that I have to release the gas first wait for like a second, then press the clutch and shift, otherwise seems to spike a bit.. the idle is not dead on, but unless you listen for it, you can't really tell. the OEM tack is always dead on. The needle seems to move but is always within 1/16 of an inch...
  16. #3134
    Registered User LukeWRX's Avatar
    Jan 2003
    Stafford, VA
    Forge 100% on the STi for the second time.
    Put it on when I bought it for about 6k miles and NO problems, then for some reason yearned for the stock again, so I put it on....Dont know if the car felt any different, besides the obvious sound....but yesterday I put it back on, guess I missed the sound.
    Anyway, no problems what-so-ever with the forge. But this is on stock turbo, I dont know about its ability to hold over 20psi.
    2004 STi
    Blitz DTT-DCII
    COBB Stage 2
    Invidia Catless DP
    HKS Hiper Cat-back
    Greddy: EGT, Boost, Oil Press Gauges
    Perrin Oil Catch Can
  17. #3135
    Nov 2003
    Irvine, CA
    the B-Spec one is 100% atmospheric!!! It's on "WKD WGN"'s car...it sound real nice too
    http://www.heeltoeauto.com/marketpla...spec/index.htm
    Myspace
    2007 WRX TR - "stock for now"
