"The BIG BOV thread" (Where all bov question threads get merged) - Page 205
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; oh dude the GFB is a lot louder and a lot cleaner sounding then the stock bypass with the hose ...
  1. #3061
    Jul 2001
    www.vividracing.com
    oh dude the GFB is a lot louder and a lot cleaner sounding then the stock bypass with the hose takin off. Like i said I had one and i loved it. It is a really fast BOV . I loved the sounds.. not annoyingly loud.. and not soft.. you can deffinately hear it.
    Team VR - Vivid Racing
    www.vividracing.com
    gabe@vividracing.com
    480-966-3040 x 290
    CLICK ME HERE
  3. #3062
    Registered User fastwrx135's Avatar
    Dec 2002
    gurnee, IL
    Auto's keep boost between shifts therefore nothing has to be blown off! If you want the sound, build some boost then let off the gas. You should be able to hear it then. I have the HKS BOV and its sounds great
    '03 PSM WRX Stg 4 <---SOLD
    '04 G35 coupe<-----MY NEW CAR
  4. #3063
    Registered User §tī's Avatar
    Feb 2004
    CT
    Thanks for the few good posts there were. I don't plan on just sticking a BOV on I never did say that I dont think. I do want a bigger turbo but nothing too big. Part of the point of this was see what engine performance would be like with it. Notice i said i thinking of what I want to do ... I also intend to get a uppipe and and cat back exhaust.
  6. #3064
    Oct 2002
    VA
    Just cut the crap and get a Forge dump valve...end of story
  7. #3065
    Aug 2003
    NH
    Two more questions. Who makes the GFB and how much do they usually run?
    2004 WRB Cobb Stage II WRX
    220whp 210wtq
  8. #3066
    Registered User Hipswnger2's Avatar
    Dec 2003
    Ohio University / Akron, OH
    Haha... sorry.
    GFB makes the GFB. The company is called Go Fast Bits, and the BOV is called the hybrid BOV i believe.
    I think GFB is a part of Subaru as well... so they make a good product that fits nicely.
    All show and no go . . .
    Your car looks fast, but why's it so slo.
    2002 WR blue WRX (RIP)
    2001 Imola Red BMW M Coupe (sold... )
  9. #3067
    Registered User jungdragon's Avatar
    Jul 2003
    socal
    I went on a canyon run a few days ago and got some good opportunities to safely capture some clips.
    video
    hope you like it
    03 wrx
    karboy ss/bushings, blitz dtt, catless, prodrive axleback
  10. #3068
    Registered User ryland's Avatar
    Apr 2002
    NY
    Did you use the yellow spring? If not, you should, still sounds like the spring is a bit too tight.
    2004 Black WRX Sedan
    Mods = yes
  11. #3069
    Jul 2003
    socal
    first video had the yellow spring in it. Second has the green one. Green seems to work well but vents pretty easily under partial throttle
    03 wrx
  12. #3070
    Registered User SubaruPL's Avatar
    Feb 2004
    Fort Fun
    STI Blow Off Valve
    So is it really worth to install it? I know it sounds awesome but I heard it might be bad for the engine. What is the truth about that? Would I loose the warranty if I installed it?
  13. #3071
    Feb 2004
    Buffalo, NY
    It would take you 5 minutes to take it off; so you can just take if off before bringing it into Subaru.
    It is not bad for the engine; you just wont see any performance gains.
  14. #3072
    afpdl's Avatar
    Sugar Land(houston), TX
    Depending on the bov and your luck it could cause stumbling at idle.
    Alex
  15. #3073
    Registered User wake2snow5's Avatar
    Jan 2004
    Ellensburg, WA
    GFB BOV 50/50 to 100% Problems
    Well I have been running my GFB Hybrid Blow Off Valve for almost a year and a half. I have always ran it 50/50 with great results. My friend and I decided to give 100% a try for the heck of it. We installed everything properly for 100% operation. Put the plug in the return hose, capped the BOV and connected the vacuum line. For some reason it would not vent what so ever. It didn't even feel like there was any boost building. We checked our installation a bunch of times and even took everything off and put it back together. Is there something wrong with my blow off valve? I put it back to the 50/50 setting and it worked like a charm.
  16. #3074
    Jan 2004
    MI
    i thing im having the same problem with my HKS bov. i also notice it when i let off of the gas kinda slowly (abit hard to explain) it souns like the spring is causing the valve to flutter. with more spirited shifting its alot more accurate, no complaints.
    what kind of adjustment helped? (i bought my rex used, i really know nothing about this bov)
  17. #3075
    Jul 2003
    Delaware
    I just installed a TXS Type H BOV just for sh-ts and giggles on my car and I'm also getting a flutter at low to medium boost, sometimes even at higher boost The more boost there is the better it sounds but I have yet to get a healthy sounding woosh. I've taken all of the washers out, and it still does it. I put two washers in and it sound like it wasn't opening at low to medium boost. If I have the car in nuetral and rev it up to like 4k RPM's (no washers or maybe 1 installed), I get a nice woosh. With the tranny in gear, I get a nasty flutter when letting off. WTF. Anybody know why? Will this hurt my car?
    Oh yes, the BOV is 100% atmospheric and I have the stock TMIC.
    --Jay--
    OH, yeah, Welcome back, Fahd Good to hear from you!
