"The BIG BOV thread" (Where all bov question threads get merged) - Page 200
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; who need cats anyway? 2000$ is much unless you have fu**ed the car. It does run right? clear the cell, ...
  1. #2986
    Aug 2003
    Norway, Europe
    who need cats anyway? 2000$ is much unless you have fu**ed the car. It does run right? clear the cell, loose the cats and get a cellfix and tell us what happend..
    Silver -02 Impreza WRX
  3. #2987
    Registered User KanosWRX's Avatar
    Dec 2001
    Northern VA
    Ok this is just stupid, a dealership saying something is wrong with his CAT's, hell yeah their is, its because they are not there, he has a TurboXS Stealth back. Their is nothing wrong with his CAT's he just doesnt want as many so run as fast as possible from that dealership and never go back. Most likely the CEL is because of the P0420 (cat inefficiency), simple Pony Express mil eliminator will fix that, 20 bucks.
    What really bothers me about this post is, you have not said anything actually running bad about the car, just what the dealer has said? First find out what the CEL's are and report back, second if the car is actually having problems running tell us whats going on so we can help. If the car is running bad have you tried replacing the CAI with the stock parts. And last most likely unless the BOV is broken its not causing any problems, the car only runs rich during shifts, but its not because its telling the ECU to add more fuel, its just not venting the air back into the intake like the stock BOV does.
    And no unless the product actually failed you can't go after TurboXS or AEM. And my guess is they have not failed, the CAI was probably not tunned for the car, and the BOV unless it stays open or shut all the time didn't cause any problems you may or may not be having.
    My Mods
    "The most important mod is the one behind the steering wheel" - Koyokid RIP
  4. #2988
    Apr 2003
    Put stock airbox and BOV back on, reset the ECU and your fine.
    Modding a car without a clue as to what you are doing is not recommended.
  6. #2989
    Feb 2004
    Question blow off valves good or bad?
    hi everyone well i bought my wrx sunday...and i wanted to get a bov...i was talking to this one guy and he said other bovs are bad for wrx's because they have a maf sensor and the stock bov recirculate or do something like that...i just wanted to know if this is true and why it does this...and which bov is the best...thanks for the help
  7. #2990
    Registered User DUBA_Rob's Avatar
    Dec 2003
    Cincinnati Ohio
    It can cause lots of problems, most notably running very rich in between shifts. This and rough idle/driveability will come with a blow off valve.
    For future questions, use the search function, and check all FAQ threads first. ( i would be hypocritical if i didnt say it usualy takes a post or two to learn this. )
    =+- 02' Midnight Black Scooby Rex-+=
  8. #2991
    Feb 2004
    if i crushed my bov would i get more sound....i know this is maybe ricer but i want more sound damnit...but i dont want to do anymods that would damage my precious rex
  9. #2992
    Registered User BoostedBoxer's Avatar
    Mar 2003
    NOR*Cal
    NO.
    My Car is 100% STOCK!
    Pics
    Originally posted by platano
    At 14???
    shoot , I'd hit it at current age, on roof of the car, with cousin driving , neighbor and town priest in the back seat, and that kid from "N.Korea" riding shotgun.
  10. #2993
    Registered User jungdragon's Avatar
    Jul 2003
    socal
    help adjusting forge bov
    I've been using my forge for a few weeks now, it works pretty well but doesn't seem to always blow off when it should. When boost is under 6psi, the bov will vent fine in any gear. But in fourth and fifth gear it won't vent at all if boost is above 6psi. This seems a little counterintuitive to me so I'm not sure what to think of it. I'm using the yellow spring
    03 wrx
    karboy ss/bushings, blitz dtt, catless, prodrive axleback
  11. #2994
    Registered User AjIsDope's Avatar
    Aug 2002
    SoCal
    Mine does the same. I had the yellow spring but switched to the green after I heard some sort of spring "rattle" type sound in 4th and 5th gears. Works just fine now.
    03 Cobra
    566whp/515wtq
    Pics
    & Dyno
    Pics
  12. #2995
    Jul 2003
    socal
    yeah i guess i should try that. I've used all the springs cept the green one. But wouldn't it be expected to blowoff in 4th and 5th at higher boost if its doing it in lower boost, regardless of the spring?
    ill put in the green one. I like how the yellow spring made a higher pitched noise, coool
    03 wrx
  13. #2996
    Aug 2002
    SoCal
    It blows off at strange times. I think the yellow spring is a bit too stiff for my current setup. Still stock turbo, with MBC. The green one blows off alot. I think you will like it.
  14. #2997
    Jul 2003
    socal
    adding a bov will have a potential for more problems with idling and running rich as previously mentioned but I use one anyway! I like the sound and haven't had any of these problems yet
    03 wrx
  15. #2998
    Registered User Snowvert's Avatar
    Mar 2003
    good or bad? i'd word it as needed or not needed. but that's just me.
    03 wrx - 300whp/270wtq
    Originally posted by zoophagy
    The people that work there are, for the most part, retards. I used to work there.
  16. #2999
    Registered User ebr0t's Avatar
    Aug 2002
    U of Central Florida (Orlando)
    Re: blow off valves good or bad?
    Quote Originally Posted by DTR rex
    Peter North > *
  17. #3000
    Registered User ONeBadREx's Avatar
    May 2003
    OrlANDo, FL
    i had paid 245xx for my blitz
    frederick
    Hks up/dp/ebc/ti exh; TeIN springs:
    kartboy ss; blitz bov; volk gt-c
    ...n we're just getting started
    13.4@99mph
