This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally posted by WRX,WIHO whas a BOV I will spare you the flame BOV = Blow off Valve....
  1. #2881
    fre
    fre is offline
    Registered User fre's Avatar
    Nov 2003
    Idaho
    Re: ?
    whas a BOV
  2. #2882
    Registered User XxScoobYxX's Avatar
    Apr 2003
    chicago
    if u can search for some supra videos...like i said most supra guys use that BOV and to me it sounds like a really loud sneeze lol
  3. #2883
    Apr 2003
    chicago
  4. #2884
    Registered User AjIsDope's Avatar
    Aug 2002
    SoCal
    Post Forge BOV Adjustments
    I recently purchased a Forge 100% BOV and I am curious as to what spring some of you use in your setups. I received a red, green, two blues (?). I think I was supposed to get a yellow and black one. Also, what did you lubricate the inside with. My mods right now are uppipe, downpipe (catless), catback, and MBC @ 15-15.5psi.
    Any help is appreciated.
    03 Cobra
    566whp/515wtq
    Pics
    & Dyno
    Pics
  5. #2885
    Feb 2004
    Hickory, NC
    it might be an up-pipe leak. I have the same problem.
    Mods
    Armed with a rotated Precision 6265 turbo at 35psi and a built 2.5 liter.
  6. #2886
    fre
    fre is offline
    Nov 2003
    Idaho
    I thought uppipe leaks were louder, but I suppose it could be a very slight one even with my flex uppipe.
  7. #2887
    Feb 2004
    Hickory, NC
    i have a flex pipe too
    Mods
  8. #2888
    fre
    fre is offline
    Nov 2003
    Idaho
    I just hope it isn't that one by the manifold argg. The mechanic didn't touch that one, but maybe retightening the top bolts caused the lower ones to change position. I did switch from gruppe-s gaskets to stock ones on the turbo inlet/outlet too, so that could have something to do with it. Who knows, I will try to look at my intake and readjust hoses and if that doesn't work then it is probably an uppipe or BOV leak.
  9. #2889
    Feb 2004
    Hickory, NC
    I doubt your intake has anything to do with it.
    Mods
  10. #2890
    Registered User GotRice7169's Avatar
    Jun 2003
    Tampa Florida
    another bov yu can look at the gets a nice sound is the greddy type-s. it requires a high amount of boost to get that sound but when yu get it, it just makes life beautiful
    My Mods w/ Pics
    13.57 @ 100.9 mph
    UCF Car Club
  11. #2891
    Registered User WRC_Obsessed's Avatar
    Jan 2002
    Boston/NNJ
    I am currently using the stiffest spring. Sorry I forget what color but you should be able to figure out which one is the stiff.
    I was told to use motor oil to lube it up.
    EDIT: With your set up I would say the soft or medium spring would be the best.
    -Brian
    Twisty Monster - 335 ft/lb of torque @ 3600 rpm on a stock turbo. Is that possible? Yes it is.
  12. #2892
    Sep 2003
    ****ty virginia
    I hear the greddy type s every day thats what i got on my miata and i love it. but i've heard the hks and like the high pitched sound a lil more
  13. #2893
    Registered User Cameron's Avatar
    Jun 2003
    Traverse City
    Let me know how your like your forge bov. I've been thinking about getting one.
    03' WRB WRX, 5spd
    AccessPort w/ VF34 (PDX Tuning map)
    Cobbtuning Intake
    TXS Catless StealthBack /w Stromung XA
    Nino's Uppipe
    Samco I/C Hoses
  14. #2894
    Registered User ryland's Avatar
    Apr 2002
    NY
    I have one, it rocks. For under 18-19 psi put in the softest spring, though. Otherwise it flutters a lot and you get compressor stall.
    2004 Black WRX Sedan
    Mods = yes
  15. #2895
    Jun 2003
    Tampa Florida
    how much boost are yu running on the greddy? if yu have a lot of boost (20+) yull get the chh and the high pitched in the same sound. Sounds sick.
    My Mods w/ Pics
    13.57 @ 100.9 mph
    UCF Car Club
