"The BIG BOV thread" (Where all bov question threads get merged) - Page 192
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; *closed* this topic has been covered too many times. do some searching, and read the technical reference thread at the ...
  1. #2866
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    *closed*
    this topic has been covered too many times. do some searching, and read the technical reference thread at the top of this forum, and the links the guys were kind enough to post for you.
    also be sure to read the rules and regulations in the welcome to the club thread. this place is a great resource if used properly.
    dR
  3. #2867
    Feb 2004
    Milwaukee
    Hi...
    I need to ask question too... if u guys don't mind.... i have hks bov too... is that normal if the bov only make sound at high rpm only but it didn't make any sound at low rpm eventhough boost is already above 0 psi.......
    I am asking this is because when i compare to my friend's one... his bov make sound at any rpm as long the boost is higher than 0 psi....he has hks bov aswell
    if it normal than it's ok... but if it's not normal then ... can somebody help me fix this problem.... i tried to loose it before and tied it before... but it didn't make any different....
    Thanks
  4. #2868
    fre
    fre is offline
    Registered User fre's Avatar
    Nov 2003
    Idaho
    Interesting sound with new VF34 turbo
    Ok. I have had my new turbo for about a week now and whenever boost spikes to about 1.2 bar or even 1.15 ish I get this higher pitched whistling noise, but only for that small time when the boost peaks. When it levels off the noise subsides. Is this a normal noise for the VF34 or would it be something else like a possible BOV leak at the higher boost? Keep in mind this isn't very loud but it is definitely a higher than normal pitched whistle. Another bit of info: When I had my other boost restrictor and it was overboosting like mad the noise became more prevailant with higher boost level (1.3-1.4 bar).
  6. #2869
    Registered User Shawn's Avatar
    Apr 2003
    Regina, Sask, Canada
    I'm guessing that is the normal sound of the turbo spooling and reaching very high RPMs. Find some videos of serious turbo charged cars and listen to them. They have super high pitched whistling sounds!
    If what you are hearing sounds similar, then I would not worry about it at all.
    '02 Silver WRX
    - PDX Tuned Stage 2.5 w/ APS FMIC, ACT Street clutch & flywheel
  7. #2870
    fre
    fre is offline
    Nov 2003
    Idaho
    I hope your right. If it were something wrong with the turbo it would have probably blown up by now, because I have about 400-500 miles on it already. I just wish I could ride in another car with a VF34 to see if they get the same pitch change at that level.
  8. #2871
    Registered User qoncept's Avatar
    Oct 2003
    Montgomery, AL
    It could be a small leak.. if it is it'll probably go away on it's own as carbon builds up. But it's probably just a normal sound from the turbo.
  9. #2872
    Mar 2002
    Chicago
    Bov
    If it sounds like a supercharger wine its probably ur blow off valve thats loose. When i installed my mbc my car sounded louder than an 04 cobra, thought it was normal. Went to the track like that and still managed to get a 13.4 @98. Checked the motor and what do u know, my blow off valve was loose. so its either that or just ur turbo. peace out gabe
  10. #2873
    Registered User CKxx's Avatar
    Feb 2003
    Pennsylvania
    Def a leak. A VF34 wont make any crazy high pitch sound that is out of the ordinary in comparision to the rest of its lower boost spool up sounds.
    Check all youre hoseclamps, and the plate between the BOV and the I/C. Once they have been ruled out, check the bov itself.
    I created my avatar.
  11. #2874
    Sep 2003
    ****ty virginia
    hks racing bov type 2
    just being bored at school today i decided to look a the different bov's for the wrx. i came upon this one an never seen it before. does anybody have this on their car. is there a big difference in this and the hks ssqv. where can i find a sound clip of this bov if there is any difference in sound. is this only for hight boost or can you put it on stock turbo.
  12. #2875
    Feb 2004
    Milwaukee
    BOV sound
    Hi...
    I need to ask question.. if u guys don't mind.... i have hks bov too... is that normal if the bov only make sound at high rpm only but it didn't make any sound at low rpm eventhough boost is already above 0 psi.......
    Thanks
    PS.... i did search and i couldn't find the answer
  13. #2876
    Registered User racerWRX's Avatar
    Jun 2002
    steeltown
    i have a txs rfl and if its similar, there is a internal spring with washers to set the tension on the spring and thus set to release at a certain psi. more washers the higher the boost has to be to vent. if it is still venting there is nothing wrong with it, it just has to be set to your desired level.
    have you ever been 4 bagged ???
  14. #2877
    Registered User XxScoobYxX's Avatar
    Apr 2003
    chicago
    that BOV sound wicked, alot of supra users use that BOV i was wondering also if they made it for the WRX
  15. #2878
    Registered User FACTION's Avatar
    Jun 2002
    over your shoulder
    I have a friend who has the 'race' version of the HKS BOV on his EJ25 hybrid and it sounds MEAN. Its welded on to his MRT FMIC.
  16. #2879
    Sep 2003
    ****ty virginia
    i know they have it for the wrx i just didn't know much about it. thanks for the info. now lets hear some sound clips
  17. #2880
    Jan 2004
    Chicago
    whas a BOV
