This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; did you take the purple insert out?...
  1. #2821
    Dec 2002
    CA
  2. #2822
    Jan 2004
    california
    u took the screw out?
    you'll have my license plate memorized by the time were done racing =)
  3. #2823
    TheWRXstore's Avatar
    May 2003
    Chicago
    Make sure your vacuum lines are connected properly. The blow off valve wont open, if there's no vacuum to tell it to.
    www.thewrxstore.com
    T3/T4 Kits starting @ $2500.
    630.510.8981- Voice
    630.510.9978- Fax
  4. #2824
    Registered User BiGBlacK97006's Avatar
    Oct 2003
    Beaverton, OR
    everything is hooked up fine. I put the screw back in. the purple insert is in....but still no sound
    02' BlacKDuB
  5. #2825
    ocean county nj
    hks bov
    it could just be from the flash from his camerabut if you look at the first picture the adjustment screw looks like it has had tools on it in the past.in the second picture the cap nuts around the circumference of the bov also look like they have had tools on them also. you said it was bought new on ebay. was it in the factory sealed hks box or was it just sent to you in another box and said to be new because to me the valve looks like someone has messed with it in the past (like i said earlier could be the flashfrom you camera) if it wasn't i would guestion the ebay seller
    on a wrx high
    mods: borla cat back,quantum racing intercooler spray kit and splitter,k&n filter,removed intake silencer
  6. #2826
    Oct 2003
    Beaverton, OR
    yeah the bov was in a different box ill email the seller....thnx
    02' BlacKDuB
  7. #2827
    Dec 2003
    socal
    Originally posted by Trailboss
    BOV's are going to run anywhere from around $180-240.
    I used to have a 100% Atomspheric BOV, the TurboXS RFL, and although I didn't really mind the sound, it went off ALL THE TIME...like...lift off throttle at 2200rpms, and it would go off.
    Also, the 100% atmospheric BOV doesn't recirculate, meaning no air back through the intake. You'll run rich and get worse gas mileage.
    If I were ever to pick up another one, I'd go with one that recirculated -- something around a 50/50 set up.
    ive looked around at about 2 or 3 places and they are going to sell the HKS bov for $285!!! are they ripping me off?
  8. #2828
    Registered User ebr0t's Avatar
    Aug 2002
    U of Central Florida (Orlando)
    www.worldoneperformance.com
    theres a vendors forum on here also.... try searching it for the product you desire.
    Quote Originally Posted by DTR rex
    Peter North > *
  9. #2829
    Registered User KanosWRX's Avatar
    Dec 2001
    Northern VA
    Hey josh, wouldn't it be the same gas mileage, I mean its not like the car will throw in more gas just because there isn't that extra air in the intake from the recirculating valve. All it does is make you run rich for a second.
    My Mods
    "The most important mod is the one behind the steering wheel" - Koyokid RIP
  10. #2830
    Dec 2003
    try removing your intake silencer first, see if you like that, nice "middle of the road" kinda sound
  11. #2831
    Registered User IntercoolerOnTo's Avatar
    Jan 2004
    Arizona
    Question forge blow off valve
    I just bought a forge blow-off valve and wanted to know what spring to put in for my stock 04 wrx.
    It has a REDLINE for a reason!!!
  12. #2832
    Registered User BoostedBoxer's Avatar
    Mar 2003
    NOR*Cal
    Please explain to me what the differnce in the springs is. Do they do it by amt of boost?
    My Car is 100% STOCK!
    Pics
    Originally posted by platano
    At 14???
    shoot , I'd hit it at current age, on roof of the car, with cousin driving , neighbor and town priest in the back seat, and that kid from "N.Korea" riding shotgun.
  13. #2833
    Jan 2004
    Arizona
    they just gave me a blow off valve with 3 springs a red, yellow and green it doesnt say which color to use for stock boost.
  14. #2834
    Mar 2003
    NOR*Cal
    is there an instruction manual?
    Pics
    At 14???
  15. #2835
    Registered User jungdragon's Avatar
    Jul 2003
    socal
    use the blue first, if it does not blow off enough for your liking use the yellow one.
    red
    blue
    yellow
    green
    in order of stiffest to softest
    hope this helps
    03 wrx
    karboy ss/bushings, blitz dtt, catless, prodrive axleback
