"The BIG BOV thread" (Where all bov question threads get merged) - Page 183
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I did this the first time I had to remove my intercooler (downpipe installation) except it was the bolt that ...
  1. #2731
    Apr 2003
    I did this the first time I had to remove my intercooler (downpipe installation) except it was the bolt that goes on the bottom of the IC from the turbo. I just got a metric tap and die set, worked like a charm.
    gotta be careful using steel bolts on soft aluminum threads.
  3. #2732
    Moderator schischwein's Avatar
    Jul 2001
    Originally posted by NJwrbT-WRX
    The fluttering and chirping sound on the WRC cars in the ALS -- Anti-lag system. I am not going to go into ALS in detail, but it uses the ECU (exhaust valve timing IIRC) to keep the turbo spooled. Generally a turbo will not last very long with an ALS system running -- therefore it is not so good to run on the street.
    -joe
    Actually, it's ignition timing and/or additional injection plumbing into the actual exhaust. It generally sounds more like a crackling bang than chirping. Due to the turbo constantly being on boost, antilag is usually only switched on when needed(in tight cornering sections).
  4. #2733
    Registered User Shard's Avatar
    Jan 2003
    Houston TX
    Aluminum sucks in this aspect one of my motor mount threads is crossthreaded (but holding!).
    Buy a new IC and sell yours on ebay
    skidpad kid: you're the BOMB
    Shard of me: i know
    Joshiscookin: Hey fragment.
  6. #2734
    Jul 2003
    Valencia, CA
    WORX BOV Lube help
    Can I use lithium grease?
  7. #2735
    Moderator smorris's Avatar
    Mar 2002
    Avon, Ohio
    Worx BOV works with both the STi and the 2002 and up WRX.
    Moving to Engine Performance...
    Steve - Avon, Ohio, USA - Moderator - Fun Drives and North Central States
    Explore the USA
    2016 Toyota 4Runner__2008 Outback 2.5XT Ltd (sold) __2002 WRX Wagon (sold) __ 1958 MGA Roadster __ and a few scooters...
  8. #2736
    afpdl's Avatar
    Sugar Land(houston), TX
    Maybe here?
    Sorry I was typing that as smorris moved it.
    Alex
  9. #2737
    Oct 2003
    Buffalo, NY
    Originally posted by Invisiguard
    Im using the APS BOV too, absolutly no problems, the only difference in driving is the sound, and yes, it still is plenty loud, I acctually wouldnt want it any louder, they seem a bit pricey though, guess I was lucky, got it off Ebay for $100 as soon as the guy posted it
    I just installed this bov on my wrx... and i cant even hear it...
  10. #2738
    Moderator MidKnight's Avatar
    Oct 2002
    Bergen, NJ
    I swapped my forge 100% atmo BOV for this valve and haven't looked back since. The first time I heard it, I thought it sounded weird, but it has grown on me. I like the volume of it and I have no problems with it in terms of smoothness. I would definitely recommend this BOV!
    '03 WRX
    '01 2.5RS
    MODS | PICS | Dyno
    "Stuff sold by the gram is always going to be more exciting than stuff sold by the pound." - Jeremy Clarkson
  11. #2739
    Banned CakePanMan's Avatar
    Jan 2004
    Je|2sey
    BOV or INTAKE???
    just got my rex a few days ago...its purrty..
    anyway (being just a kid) i got about 300 bucks to burn...what do i get...??? intake or blow off whats more worth the bucks?????
  12. #2740
    Jan 2004
    Je|2sey
    im buying it online in a couple hours...if u guys can just tell me what u think is the beter choice thatll be greeeaaat
  13. #2741
    Registered User DrewToTheC's Avatar
    Sep 2003
    Southern Cali
    depends on what you want i am 18 and i have a job i got my rex like 6 months ago you are going to love it
    anyway i was in the boat as you but decided to save up and got stage 2 personally i would go with the bov because of teh sound since most people with rex's dont think intakes help, infact they may take power away. the general concenses is that intakes are for higher modded wrx's.
    just my 2 cents
    have fun with the rex
    Stage 4 plus 2004 WRX
  14. #2742
    Registered User MidnightFLAT4's Avatar
    Sep 2003
    Dayton Ohio, Chicago IL
    go preorder the accessport from cobb tuning... that is if you have around 500 to spend. If not, no worries... about 280 will be charged at first, then another 270 when it ships...
    the accessport overwrites the stock ecu with more aggressive software that is still reliable. 25 wheel horsepower. Downpipe aftwerwards, and youll get another 25... have fun
    03 MBP WRX Sedan
    STi RA gearset October 4th,STi Trans Mount
    Cobb AccessECU STG II 16.4psi. Bosal DP, Catless OEM UP, 205/55 ZR16 Futura Ultra Z's.
  15. #2743
    Jul 2003
    KC, MO
    I never understood why someone would get a cobb stage 1 ecu upgrade.
    I recommend you save a bit longer and get downpipe + catback from gruppe-s or something. You'll definitely enjoy that a lot more than a bov or intake
    04 WRX Black no options!
    Helix up/downpipe, HKS catback & Bov, autometer gauges and MRT shortshifter, Bronze Rota SDRs, UTEC, tein SS coilovers, HKS type1 turbo timer, 6000K HIDs, JDM spec C front/rear lips, 20% tint
    to be installed: Mines Spoiler
  16. #2744
    Banned hippy78's Avatar
    Jun 2003
    a little newb info
    It might be a good idea to research things you are going to get and how they might effect your car b4 you actually get them. Here are some links(some links are to info on this site)about your car. Some links will be very useful for you now(imo), and some will never be... I put a few things in bold that you might wanna check out first.
    General Upgrade Info +
    GREAT GENERAL TUNING AND UPGRADING INFO
    ^good place to start.......
    Engine tuning
    Boost Conversions
    Engine Basics: Detonation and Pre-Ignition
    ECU Comparison & FAQ
    Nine Questions Answered by Nathan at turboxs
    Questions Answered by Gary Sheehan
    OBD2 Codes
    Utec Stuff
    Utec Quick Tune Guide
    Utec Users Manual(has info on installing and removing factory/aftermarket ecu's)
    Part and Background Tuning Info
    Exhaust Info #1
    Exhaust Info #2 - Torque Specs
    Online Parts Manual
    Maintenance Schedule
    NKG Spark Plug Part #'s
    Short Throw Shifter
    Wheel Weights
    Exhaust Design, Turbo and Naturally Aspirated
    by Josh Tenny
    Subaru Intake System Discussion (MAP vs MAF)
    Gear Oil Technical Info
    MRT - How It Works & Why
    HowStuffWorks.com - How Turbochargers Work
    HowStuffWorks.com - The difference between a turbocharger and a supercharger
    HowStuffWorks.com - How Car Engines Work
    HowStuffWorks.com - How Manual Transmissions Work
    HowStuffWorks.com - How Differencials Work
    HowStuffWorks.com - How Anti-Lock Breaks Work
    HowStuffWorks.com - How Gasoline Works
    HowStuffWorks.com - How Car Steering Works
    How To
    How to Change Engine Oil
    How to install a Stock Wrx Boost Gauge
    Turboxs - How to install a Manual Boost Controller
    Speedy - How to install an Egt Gauge(wiring from above might help)
    Vishnu Tuning - How to insall an UPPIPE(a bit down on the page)
    How to install an Intercooler Sprayer
    Turboxs - How to install a Turbo-back Exhaust
    Turboxs - How to Install Their Stage Four Kit(turbo install)
    Turboxs - How to Remove the Factory Intake
    MRT - How to BLOW YOUR ENGINE, How To Reset Your Ecu, and How To Clean A Foam Intake Filter
    Best Part Polls
    BOV Poll #1
    Best ECU Poll
    Most Pupular Intake Poll
    Most Pupular Uppipe Poll
    Forums
    Nasioc
    ClubWrx
    WrxHackers
    WrxForum
    ScoobyMods
    UltimateSubaruMessageBoard
    ScoobyNet
    WrxFanatics
    MachVForums
    WrxTuners
    peace
  17. #2745
    Registered User ebr0t's Avatar
    Aug 2002
    U of Central Florida (Orlando)
    nice hippy.
    to answer original question. neither are worth the money recently.
    SEARCH
    Quote Originally Posted by DTR rex
    Peter North > *
