This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Will installing a rear pipe and muffler off of a STi give any performance increase? How much more would a ...
  1. #2521
    Nov 2003
    CT
    Question What will a STi Exhaust do for a WRX?
    How much more would a STi turbo back system offer?
    Is it worth the time to swap?
    Thanks Bill
  2. #2522
    Registered User Mattr762's Avatar
    Jan 2003
    Tulsa, OK
    There is very little to no advantange to swapping out for the STi turbo-back. It still has 2 cats and is 2.25" in diameter just like the WRX.
    '02 WRX white - Uppipe, MattSpec Turbo-back, Dynorad
  3. #2523
    Registered User tubbytreats's Avatar
    May 2003
    Just a side note:
    The STI uppipe is catless, so if you get your hands on that, you will get a performance increase over your stock WRX.
    The 2.25" pipe isn't really a huge problem power wise (until you are pushing 300 BHP or more), but the 2 remaining cats certainly restrict alot of the power potential for the car.
    Catless downpipe and uppipe are your best bet.
    2002 WRX Mods:
    AP Stage2/93, ScoobySport Up, Dp, & Muffler, SS AutoChrome TMIC, Hawker PC680T Battery, Injen CAI, ACT Stage2 Clutch, Gruppe-S 13.8lb Flywheel, Mobil1 and Redline oil, NGK BKR7EIX plugs, Goodridge SS Lines, Motul RBF600, Hawk HPS pads, 35% 3M tint, Koji Headlight Mod, SilverStar Bulbs, Blaupunkt MP3000 headunit, Infinity BassLink Sub, Kenwood KFC-1689ie speakers (6.5"F / 5.25"R), Rota Downshift (Black), Yokohama AVS ES100 (225/45/17)
  4. #2524
    Moderating U! KurleeDaddeeWRX's Avatar
    Mar 2002
    San Jose, CA
    So did you get it installed or not? I don't just post and try to help out for nothing. Please post how your install turned out, and did you figure out your o-ring problem?
  5. #2525
    Nov 2003
    CT
    Any recomadations on a system that won't make my car too loud, but still offer a performance gain with breaking the bank?
  6. #2526
    Jan 2003
    Tulsa, OK
    Couple of things reduce the volume of high performance exhaust.
    1. Cats (preferably get a 3" high flow cat)
    2. Muffler (Prodrive, Borla Hush and GReddy cat-backs are known for being much quieter than most.
    3. Resonator (either before the muffler or built within the tail-pipe)
    4. Diameter of pipe (3.5" will be much louder than 2.5")
    Of course if you don't want to break the bank then I recommend having a local muffler shop building one for you. I built an entire turbo-back for $400 Seen here.
  7. #2527
    WRX
    WRX is offline
    Registered User WRX's Avatar
    Nov 2002
    Montgomery, IL
    sorry to hijack the thread, but is there a return hose that's supposed to go from the BOV to the turbo inlet? I'm asking for a friend.
    13.12@101mph
    248whp 204lb/ft torque
    mods
  8. #2528
    Registered User Shibby's Avatar
    Jan 2003
    Dayton, OH
    yeah, i installed it just fine. Your advice helped, the O-ring fits around the return piece real snug. It went fine.
    --Jason-- 2004 MT WRB WRX
    Cobb Stage 2 more goodies:
    STi SS | Blitz SUS | Samco IC Hoses | Perrin Rear Sway Bar and Endlinks | Eibach's | Steel Gray Rota Downshifts | Goodyear Eagle F1 GS-D3's | Blitz DTT-DC2 | Phatty-Ass System
    "This is my WRX. There are many others like it, but this one is mine. My WRX is my best friend. It is my life. I must master my WRX as I must master my life. Without me, my WRX is useless. Without my WRX, I am useless."
  9. #2529
    Registered User hatebobbarker's Avatar
    Aug 2003
    Riverside, CA
    just get an exhaust that has a silencer available
  10. #2530
    Mar 2003
    Los Angeles
    FMIC and AVO BOV
    I just bought a blitz FMIC and I was wondering if I could use the AVO BOV that was used on a TMIC? Also where can I buy a flange for the BOV?
    ThanX
  11. #2531
    Jan 2003
    Dayton, OH
    OEM BOV sufficient for Cobb stage 2?
    I plan to use my OEM BOV for Cobb's stage 2. Will the OEM be able to hold the increased boost. Will it still perform well?
  12. #2532
    Apr 2003
    yes, stock bov is adequate for pretty much anything under 20 psi or so.
  13. #2533
    Registered User AjIsDope's Avatar
    Aug 2002
    SoCal
    What he said. ^^^
    03 Cobra
    566whp/515wtq
    Pics
    & Dyno
    Pics
  14. #2534
    Registered User Racenut's Avatar
    Dec 2002
    California
    I have Cobb Stage 2 and stock BOV. Holds boost and works just fine. The boost increase is only a little more than 1psi.. though I do occasionally get up to 17psi if the weather is just right. I'm at sea level though, I guess that helps too.
  15. #2535
    Registered User 0260B4U's Avatar
    Feb 2003
    I rule
    OEM good for up to 23 Ive heard, and the DSM guys just takea punch and dimple the front and get a few more psi out of it
    --Little John--
    Straights are for fast cars...
    Turns are for fast drivers...
    --Colin McRae
    "Power is nothing without control"
    http://static.howstuffworks.com/gif/engine-flat-4.gif
    "Are you OK to drink?"
