"The BIG BOV thread" (Where all bov question threads get merged) - Page 167
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; HKS SSQV is working fine for me... RN...
  1. #2491
    Registered User renichms's Avatar
    Jun 2003
    Birmingham, AL
    RN
    2004 Subaru Impreza WRX STi - WR Blue/Gold wheels
    60': 1.768
    1/4: 13.155 @ 102.02 MPH
  3. #2492
    afpdl's Avatar
    Sugar Land(houston), TX
    Originally posted by UR2 SLO
    Same with my RFL. I do need a new BOV though, one that works. The stock one is on again but it is not performing up to par. The FMIC stopped the boost creep but the stock BOV is surging the turbo, Not smooth any more when you get off throttle and back on again.
    Id go with the aps bov, made to work like the factory one just more efficently.
    Alex
  4. #2493
    Apr 2003
    Seattle
    Blitz Bov wont open
    hello everybody,
    I have Blitz Bov and it seems like the valve wont open. Eveytime I go into boost or let go of the gas it makes a weird sound compared to other blitz bov. Its seems to becoming from the intake. I have tried adjusting but it still dosent open.
    Any help?
    Thanks,
    Silva
  6. #2494
    Oct 2003
    Grand Rapids, MI
    Did my BOV hit the hood when I let off?
    I went from a light, no launch against a buddy's SHO V8 taurus thing, just messin around, bogged @ 1k, he got a car on me, I screamed by before the end of first and I pushed the clutch in @ 7k, when I did I hear a LOUD *POP* from the front, sounded like a boulder struck the hood or windshield!
    So I pulled over to take a closer look, car not running in any sort of ill manor, I have the BOV cocked a little towards the driver's side fender (middle of horn faces about 1 o'clock) and it looks like the TurboXS RFL I have is pretty big, did the engine spring up from the driver's side when I let off and bang into the hood?
    -1991 Audi 80 Quattro beater
    -1993 Ford Escort GT backup beater
    -2002 Subaru Impreza WRX goes nowhere garage \/\/hore
  7. #2495
    Moderating U! KurleeDaddeeWRX's Avatar
    Mar 2002
    San Jose, CA
    I have never had a Blitz BOV, but I know that all BOV's have a piston running down the middle of them. This piston goes up and down inside the main body of the BOV. The piston is lubricated with silicone grease from the factory. After the BOV has been on the car for a while, the grease gets used up, blown out of the horn, and dust/dirt gets onto the grease forming grit. The problem your experiencing is probably because the piston doesn't have enough lubrication to do its job, so it cant travel up and down properly.
    Take the BOV off the car, and take it apart. Do a search for GFB BOV that I wrote A LONG TIME AGO. I put full detailed pictures of a GFB BOV. Fully clean all of the inner parts of the BOV with Isopropyl Alcohol to get all of the grease and grime out. Then put a nice thin layer of silicone grease on the entire outer piston area, as well as all of the parts you cleaned out with alcohol. Put it back together and try it again. It should help.
    Good luck.
  8. #2496
    Registered User BoostedBoxer's Avatar
    Mar 2003
    NOR*Cal
    what he said^^^^^^^^
    My Car is 100% STOCK!
    Pics
    Originally posted by platano
    At 14???
    shoot , I'd hit it at current age, on roof of the car, with cousin driving , neighbor and town priest in the back seat, and that kid from "N.Korea" riding shotgun.
  9. #2497
    Moderating YOU
    before you had your Subaru!
    Verdugo's Avatar
    Jan 2002
    Sea-Town, WA
    Are you getting a fluttering sound dude? Does it make the pssssh at higher RPMs or does it not make a sound at all?
    You might wanna try loosening the spring as well...you just take a size 10 socket to loosen the nut on the top, then use an allen wrench to loosen the spring.
    If you want, gimme a ride in your car so I can see, 'cause I have a Blitz BOV too
    Armin - ClubWRX Admin/Moderator since 2002
    Vice President and Editorial Manager, NWMotiv.com
    Photography Portfolios: ArminAusejo.com | ArminWeddings.com
    President, Project One Car Club
    02 WRX "EVA-00" | 15 Audi S3 "Ella" | 2010 A4 (traded in) | 02 M3 "M-Thrizzle" (traded in) | 08 STI "Blaze" (sold)
    djrez4 is a genius | ScoobyDMC #010
  10. #2498
    Mar 2003
    NOR*Cal
    no. The engine wouldn't move that much.
    Pics
    At 14???
  11. #2499
    Sep 2003
    SoCal
    ^^^ your avatar owns 10x more then before
    I am 14 and my name is David.
  12. #2500
    Moderating YOU
    Verdugo's Avatar
    Jan 2002
    Sea-Town, WA
    LOL thanks
  13. #2501
    Oct 2003
    Grand Rapids, MI
    unburnt fuel that didn't make it to the muffler?
  14. #2502
    Registered User WiCkeDrEx's Avatar
    Aug 2003
    VietNam
    So with HKS BOV, I don't have to worry about this problem?
    13.7 at 98.74 MPH / Stock TD04 & No EM
  15. #2503
    May 2002
    If you are catless, you prob just shot out a nice big flame
    Congrats on your first fire breathing!
    -Michael
  16. #2504
    Moderating YOU
    Verdugo's Avatar
    Jan 2002
    Sea-Town, WA
    I'm not sure if the HKS has an adjustable spring. I would think it'd actually be better to have an adjustable spring simply because you can futz with it to get the best balance between just the bling sound or blowing off when it's really supposed to. That way, it'll be balanced depending upon the amount of boost you're running. With the Blitz, you can even replace the spring with a stiffer one that'll hold up to about 2.5 BAR.
    In any case, all BOVs work essentially the same, so it's possible to run into the same problems with any BOV...it all just matters on how or even if it's adjustable to cure the problems.
  17. #2505
    Oct 2003
    Grand Rapids, MI
    any more input on this topic?
    i'm still worrying about it thusfar today , no loss of any fluids and car runs/drives fine, not sure what the hell happened
