This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Ditto what Mawvin said. I am running a Forge 100% BOV and have not run into any problems. I really ...
  1. #2446
    Registered User WRC_Obsessed's Avatar
    Jan 2002
    Boston/NNJ
    I really don't say this too often but please do a search. This topic has been covered to death. There is also a good sticky on BOVs at the top of the Engine Performance forum.
    -Brian
    Twisty Monster - 335 ft/lb of torque @ 3600 rpm on a stock turbo. Is that possible? Yes it is.
  2. #2447
    Registered User Imprezaboy's Avatar
    May 2002
    Chino Hills, CA
    Re: BOV question
    Originally posted by dj villain
    what are the advantages and disadvantages of getting an aftermarket BOV? and if i get one...do i just put it on and go...or are there other things i need to do? i'm new to subarus...so please help. i need all the info i can get..thanks also..how hard are they to put on?
    Biggest advantage for installing an aftermarket BOV is that typically, aftermarket units have a stiffer spring to hold the valve tightly to prevent leakage at high boost level, secondly some aftermarket BOV are adjustable (via turning of a nob or swapping out the valve springs) so you can dial down the exact pressure when the BOV should vent. Depending on the types and manufacturer of BOV, installation is typically very straight forward.
    Disadvantage - see MawviN comment.
    Stock CBV (compressor bypass valve) is actually a very decent unit and it only experiences minimal leakage at around 16 psi or so. I would not recommand BOV as your first mod since aftermarket BOV does not provide any real hp gain.
    :the quest to be a better driver
    ::the relentless search for untamed twisties
  3. #2448
    Registered User BoostedBoxer's Avatar
    Mar 2003
    NOR*Cal
    RFL type H bov
    who has one of these? i was considering purchasing one and curious to how loud they are and if the cause idling problems and such. I heard they were loud, but just curious if its annoying or not for a daily driver.
    Eli- i know you got one, what do you think?
    My Car is 100% STOCK!
    Pics
    Originally posted by platano
    At 14???
    shoot , I'd hit it at current age, on roof of the car, with cousin driving , neighbor and town priest in the back seat, and that kid from "N.Korea" riding shotgun.
  4. #2449
    Registered User pityr's Avatar
    Oct 2002
    Beaverton OR
    I have one but I took it off because it got too annoying. Its kindof cool for a week or so but then it just gets old.
    It is very very loud.
    No one will truely be free until nerd persecution ends.
  5. #2450
    Registered User ebr0t's Avatar
    Aug 2002
    U of Central Florida (Orlando)
    Corey, you have the RFL exhaust. So the sound shouldnt bother you too much. Shifting is slightly less smooth with it, but no idel problems or loss of power or anything. I absolutely love it. Im not sure how long ive had it on, but im not sick of it at all.
    Quote Originally Posted by DTR rex
    Peter North > *
  6. #2451
    Registered User AjIsDope's Avatar
    Aug 2002
    SoCal
    If you are worried about volume, why would you go for the RFL model? IMO, you should go with Forge or GFB.
    03 Cobra
    566whp/515wtq
    Pics
    & Dyno
    Pics
  7. #2452
    Mar 2003
    NOR*Cal
    i had the gfb and got sick of it. Now im starting to miss the pssssssshhhhhhhh sound. Eli- what is the lowest rpm it blows off at? I normally shift at 2800 when regular driving. Will it blow off at that low of rpm?
    Pics
    At 14???
  8. #2453
    Aug 2002
    SoCal
    Why did you get sick of it? What about Forge?
  9. #2454
    Mar 2003
    NOR*Cal
    i got sick of it blowing off every shift in 100% atmosphere mode. But im starting to miss the sound. Maybe just the type h bov (not rfl) would be better for me...
    Pics
    At 14???
  10. #2455
    Aug 2002
    Originally posted by BoostedBoxer
    i got sick of it blowing off every shift in 100% atmosphere mode. But im starting to miss the sound. Maybe just the RFL bov (not type h) would be better for me...
    You can use washers to control how often it blows off. And a quick clarification on the txs bovs:
    Type H- standard bov
    Type H RFL - loudest
    There isnt a Turboxs Type RFL bov. You probably knew that but figure id point it out for others.
    Peter North > *
  11. #2456
    Mar 2003
    NOR*Cal
    whoops, i got them backwards. Its adjustable like that? I am sold as of now. Now to order my stoptech's, and my TXS intake and BOV.
    How does the adapter work? Does it bolt on, or does it need to be welded?
    Pics
    At 14???
  12. #2457
    Aug 2002
    Its not really adjustable but the washers make the piston harder to move, so if you shift low it really makes no noise, makes less/more noise according to throttle/rpm.
    Its a complete bolt on, like a 5 minute install FOR ME which means it should take like 2 seconds for you. ill see if i have any pics up close for ya.
    Peter North > *
  13. #2458
    Aug 2002
    there, normally they are turned to the side though...
    Peter North > *
  14. #2459
    Mar 2003
    NOR*Cal
    Cool thanks Eli, You are a great guy. I dont care what Fahd says about your Fashion sense......... (j/k)
    Pics
    At 14???
  15. #2460
    Aug 2002
    Fahd has a problem with my fashion because I wear male clothing, as opposed to his infatuation...
    Peter North > *
