"The BIG BOV thread" (Where all bov question threads get merged) - Page 15
Page 15 of 798 FirstFirst ... 567891011121314151617181920212223242565115515 ... LastLast
Results 211 to 225 of 11961
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I think most ppl plan to put quite a lot of mod to the rex, so having an EGT gauge ...
  1. #211
    Oct 2001
    Tristates
    an EGT gauge early is like having insurance.
    I heard if you go over 1650 F it is bad. The uppie is the one that
    reduce EGT since the pre-cat is on longer there to trap the heat.
    Even old school hot rod put EGT on their V8 just to make sure
    everything is COOL
    What mods, dude this baby is stock
    2002 Platinum Silver 5spd sedan.
  3. #212
    Jul 2001
    Plains of Eastern Montana
    An uppipe will certainly reduce egt's, but there is still potential w/ a MBC to have significant egt's. Even w/ the early Tuboxs unichip there was problems w/ high egt's in certain conditions. High egt's are an indicator of something bad happening (like your motor frying), w/o an egt gauge you will not know until too late.
    Obviously a MBC set to a reasonable rate (15ish) and having a catless uppipe will reduce your chances of catastrophic events related to egt's, but probably not completely eliminate it. EGT gauge is just insurance.
    My .02
    Big Sky
  4. #213
    Mar 2002
    Leonard, Michigan
    thanks for the input
    heres my short term plan/setup
    all i am going to do is CAI, MBC (set 15-15.5 4th gear), and a totally catless system
    do you think thats a safe setup without EGT gauge?
    eventually ill take it to God for the $7000/320 HP package
    todd
    Silver 2002 WRX...far from stock
    An error made on your own is safer that ten truths accepted on faith, because the first allows you the means to correct it, but the second destroys ones ability to distinguish truth from error.--Ayn Rand
    That which has been is that which will be, and that which has been done is that wich will be done-so there is nothing new under the sun.-Solomon
  6. #214
    Feb 2002
    New Jersey
    Yea...I am sure its fine...but when I deal with car parts...i like to have something new. I mean say you need to contact someone about it malufunctioning....say you need to get a spring replaced...I doubt that it will fly with them being that its a second party item now. Funny you should ask about the GFB....i just ordered one yesterday from vivid.
  7. #215
    Dec 2001
    McLean, VA
    I just purchased the Turboxs stage 1 unichip, and prior to the purchase I invested in some gauges. I purchased the greddy electrical EGT gauge. My question is where to install the sensor and does anyone have instructions.
    Derrek
  8. #216
    Moderator TypeC's Avatar
    Aug 2001
    Texas
    Re: Jim and other current MBC users
    Originally posted by BamBooI
    How have you solved your part throttle full boost situation causing high egt's?
    yeah, all you have to do is blip the throttle to WOT for a sec and it'll go to full rich (how is runs during WOT) for a good bit. If you have an A/F gauge, you can see this happen. You can also see the car go lean during part throttle full boost situation just as your car starts to studder.
    in addition to that, it's pretty easy to just not make full boost at part throttle. Either give it less gas (to lower the boost), or more gas (To make it add fuel).
    hth, -C
    Street Racer Emeritus
    '02 2.5L WRX - Retired
  9. #217
    Moderator Penguinking's Avatar
    Nov 2001
    Houston, TX / Athens, GA -at the same time!
    wouldn't a unichip solve the problem of the engine running rich at WOT?
  10. #218
    Oct 2001
    Tristates
    Well my dwaes FBC/MBC trigger works like a charm.
    Normal setting is FBC which is normal drivable in everyday highway
    traffics.
    Switched on I get 16 PSI So it is almost like NOS. hahahah
  11. #219
    Registered User michaelwrx's Avatar
    Feb 2002
    Melbourne Australia
    WRXrumble, can you tell me a bit more about your dawes device. Is it a custom design or can we all get it easily?
    MichaelWRX
    01 WRX World Rally Blue
  12. #220
    Oct 2001
    Tristates
    I use boostvalve MBC which is getting the boost off the factory BOV.
    This eliminated the problem of pressure cross feeding if you try to
    run the FBC and MBC off the same source.
    http://www.boostvalve.com wrx kit.
    http://www.dawesdevices.com/solenoid.html
    You install the boostvalve MBC as instructed and set it at 16psi on
    3rd. Now install the solenoid this way
  13. #221
    Oct 2001
    Tristates
    This is the wiring diagram
  14. #222
    Feb 2002
    Melbourne Australia
    Thanks I already have the Boostvalve MBC but I have it hooked slightly differently to the instructions.
    Rather than connecting to BOV and turbo, I have it connected to the BOV and the wastegate. I simply stuck a screw in the hose that used to be connected to wastegate. All works fine but If I bought this switch I can see I would need to hook up properly
  15. #223
    Oct 2001
    Tristates
    So far you have connected correctly. The hose you just plugged
    will go to the normallly open end, add a small hose from the
    solenoid (center outlet) and connect that to the wastegate. The MBC
    connects to the normally closed end ( the one that is air tight when no
    power is applied, test the solenoid and you will see what I mean).
    Now wire the solenoid and you are all set.
    I am now going to add a NOS trigger to the throttle body to switch
    the solenoid on after 3/4 throttle (just like a NOS setup ).
    This way the toggle will be used as a velet switch hehhe
    Btw I found running MBC with half throttle/full boost condition is
    totaly bad in NJ rush horr traffic, so I decided to add the solenoid.
    Now I can drive normal in rush hour traffic and not worry
    Have fun and email me if you need more info.
  16. #224
    Nov 2001
    i know alot of tuners arent messing w/ the bov cause it (loses?) power? i know vishnu wont mess w/ the stock bov cause they say it works well. how much of a loss are u experiencing with...oh say, a turboxs bov or aps bov?
  17. #225
    Tas
    Tas is offline
    Registered User Tas's Avatar
    Aug 2001
    Alexandria, VA
    Question Why lose power?
    I was just wondering how a BOV causes a loss in power. Does anyone know? And I heard a 100% atmosph. BOV is better than a 50/50. Am I correct?
    Thanks,
    Tas
    "Never let school get into the way of your education."
