"The BIG BOV thread" (Where all bov question threads get merged) - Page 146
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Ken, how did the Hallman RX installation go? Any pics? How is it w/ the interior adjustment knob?...
  1. #2176
    Registered User Lt. Boom Stick's Avatar
    Feb 2003
    This Island Earth
  3. #2177
    Mar 2003
    lincoln, ri
    lt, i never got a hallman inside/outside unit... i've got a joe p, with an adjustable needle bleeder to atmosphere. i've got a grainger solenoid to switch between that and wastegate boost.
    my remote control idea is to take the needle bleed to atmosphere inside the cockpit. it SHOULD work without lagging too much and causing oscillations or spiking.
    i haven't had a chance to do it yet though. i just swapped out my midpipe with a gutted oem one yesterday, and last saturday swapped my engine/tranny mounts.
    i promise to keep you up to date though!
    ken
  4. #2178
    Registered User Oo DaRk StAr oO's Avatar
    Apr 2002
    Long Beach, CA
    Cool, anyone else know any other info on this?
    BRS Autodesign | Sportmax Racing | Falken Tyres | Seibon | C2 Power
    http://www.socalspyders.com/gallery/files/1/sig.jpg
    2001 Toyota MR2-S | So Cal Spyders | Car Domain Site
  6. #2179
    Banned Mili727's Avatar
    Jun 2002
    Ga
    RFL is trash when it comes to holding boost.
  7. #2180
    Apr 2002
    Long Beach, CA
    But it sounds so pertty!!!
  8. #2181
    Aug 2001
    Gaithersburg, MD USA
    I run 35psi with mine, and i have NO problems with it holding. In fact, I’ve had customers on the dyno who have had other valves that did leak under WOT. We swap them out for RFLs and they pick up boost pressure and power. In one extreme case we gained 46hp.
    Dark star, what is it doing exactly?
    If you have the adaptor kit and valve installed correctly there is very little chance for it to actually leak a significant amount.
    The valve itself is a 30-micron metal-to-metal seal. It will bleed off a small amount of pressure (just as any metal to metal seal such as your piston rings will bleed off) but in the grand scheme of things this is such a miniscule amount that it's un-noticed.
    By having a metal-to-metal seal, we can have the valve last under high heat and high boost where diaphragm valves tend to fail.
    So describe your symptoms and I’ll try to help you get it right.
    By the way, valve flutter is normal when you are not under high boost pressure. The valve takes 11psi (with no washers installed) of pressure differential across it to actually open. In many situations where you have low pressure in the manifold and let off the throttle you do not create enough pressure differential to fully actuate the valve.
    -Nathan
    12.3@110.4
    When in doubt, add more boost!
  9. #2182
    Jul 2003
    someone just got 0wn3n by turboXS
    '03 white rex
  10. #2183
    Jun 2002
    Ga
    All Nathan said was that he runs 35lbs on his RFL. I would call that owning.
    Hey Nathan, when I had my RFL on it was leaking and was idling bad. I recently got an APS FMIC and got the APS BOV and its a lot better, I guess because it is not %100.
  11. #2184
    Aug 2001
    I didn't own anyone, or rather that wasn’t my intent.
    You need to run 4-5 washers on a Subaru to keep the valve closed enough at idle to have a stable idle.
    Some WRXs don't respond well to a VTA BOV. That's a fact. We've recommended that unless people really want the sound that they skip a BOV. However with larger turbochargers and higher boost you must either crush your stocker so much that it doesn't work well or install an aftermarket valve.
    The stiffer you run the spring, the better the car runs. You just need to balance compressor surge vs. having the valve open too easily.
    -Nathan
    12.3@110.4
  12. #2185
    Jun 2002
    Ga
    Oops I meant to put "I wouldNT call that owning"
  13. #2186
    Mar 2002
    Calmer than you are
    what you're talking about is basically turning your BOV into a 100% ATM valve. To make it run even HALF way decent you'd also have to plug the hose that used to connect to the BOV. As someone else said, it doesn't work too well...you'll probably get bad idle, and be running rich. I have the GFB 50/50 valve. I've had it in my car for over 50K miles with no problems...and as for no performance...that's arguable.
    it does reduce turbo lag a little, and will especially help on that 2nd-3rd gear shift. Is it a HUGE difference? No. Can you get something that will get you a BIGGER difference for the same money? No, but for another $50-$75 more you can.
    But back to your original question - as long as you plug the return hose, you are basically turning your stock BOV into a 100% ATM valve. The only difference is that aftermarket valves usually have some kind of "trumpet" to shape the sound...yours doesn't. It sounds kinda like someone popping the air valve off a tire...it won't have that sharp pop you get with valves designed to make a cool noise. Also - because 50/50 valves DO have a connection back to your intake, if your motor is "sucking" a little, the air from the valve will tend to go back into your intake because of the greater pressure difference, so you're not just returning 50% of the air...when your motor needs more air it returns as much as it needs...so no cels, no roungh idle, and no running rich
    go f*** yourself
  14. #2187
    Mar 2003
    sounds clip plzzz
  15. #2188
    Oct 2002
    SD, CA
  16. #2189
    Registered User WRXin''s Avatar
    Jun 2002
    Houston, TX
    Originally posted by protocol_droid
    http://forums.nasioc.com/forums/sho...sard+sound+clip
    Link is not working.
    Fahd
    Floats like a butterfly and stings like when I pee!
  17. #2190
    Jul 2003
    Recirculating BOV
    I have a BOV that is 100% and I like the sounds good but it does not make the car run right. I want to keep the sound but also recirculate the air. Does anyone have any reccomendations. It does not need to be obnoxiously loud but I definitely want something that is audible.
