"The BIG BOV thread" (Where all bov question threads get merged) - Page 118
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; kool kool...what's a knock?...
  1. #1756
    Registered User Sti_Master's Avatar
    Jun 2003
    Seattle Washington
    kool
    "Those who know nothing, can understand nothing"
    - 2004 Aspen White Subaru Wrx Sti
  3. #1757
    Registered User STi_Andy's Avatar
    Jun 2003
    Montreal, Canada
    okay well i suck at t his **** but imma try.
    knock is the sound cause by detonation?
    detonation is when the spark plugs are fireing either too early or too late?
    usually it is caused by improper (too low) octane or other engine management errors such as u have on the USDM STi ?
    "somehow the car feels faster when u drive it"
  4. #1758
    MisterX's Avatar
    May 2002
    Prague, Czech Republic
    Knock, pre-ignition, pinging and detonation are the same thing. In the WRX it sounds like someone crunching an aluminum soda can. Pre-ignition really isn't detonation, but a lot of people refer to the two phenomena as being the same.
    Actually, detonation is the explosive result of fuel burning in an uncontrolled fashion due to a number of reasons primary of which are heat, pressure, and low octane. Because of the high horse power to cubic inch ratio in the EJ20 (WRX Engine) detonation destroys your engine.
    This is the simplified version and suffers a bit in its accuracy as a result.
    X
  6. #1759
    Registered User MJU1983's Avatar
    Dec 2001
    Saint Louis, MO
    werd to big bird... flick a piece of aluminum foil and that is the horrid sound my motor makes with crappy gas.
    also, i agree with forgetting the BOV. I would assume the timing on an STi should be fairly agressive to begin with... So an exhaust and S-AFC for fuel might do the trick nice.
    -mike
  7. #1760
    Banned TSi AWD's Avatar
    May 2003
    Do Wrx's and Sti's come with BOV from the factory?
  8. #1761
    May 2003
    Orlando, FL
    TurboXS RFL BOV installed (stock car) Problems
    I got my turbo xs rfl blow off valve today and got it put on, but i noticed a few things about my car different. Right when i start the car, the rpms go up slightly just like normal, BUT then when it heads back to idle, it drops way below 500 rpm and almost stalls, then goes back to idle. THen, while im driving it stalled 3 times. One time i was even moving, and it just stalled. Then when i let off the gas between shifts, it does the same thing, rpms drop below idle and almost stalls, everytime i rev it really. The car also shakes like when you let of the gas or push the gas slowly to accelerate while already moving. Ive read in the instructions that if your car runs rough and loses boost then to install washers/spacers. We didnt use any, and im gonna try to put some on tommorow i guess. Remember, my car is stock, so give me some advice on what to do. I have noticed a drop in performance it seems, mainly turbo boost isnt maximized. I also read that you can adjust it by turning it? I have it facing the side right now......what should i do? Thanks so much!
    2003 Sedona Red WRX SOLD THIS WEEK
    Soon getting S10 ZR2 4x4
  9. #1762
    Registered User RLsChMiDt's Avatar
    Dec 2002
    Cleveland, Ohio
    Did you reset the ECU you after you installed it?
    If not, then do a search and type this in the search field: "ecu AND reset"
    -Ryan |Dub-Yuh Our Ex Ess Tee Eye| My Car
  10. #1763
    May 2003
    Orlando, FL
    No i didnt actually, i did not know you were supposed to, and the installer who did it didnt tell me about it. Thanks, ill try that tommorow, but i still think ill need washers/spacers? Anyone else? thanks!
  11. #1764
    May 2003
    Bay Area, ca
    help with gfb stealthfx bov
    just installed the gfb stealth fx bov and i'm having trouble turning the sound adjustment circle. it seems to be connected to the second ring (nipple ring) and it's very difficult to move.
    i also get a fluttering/sputtering sound sometimes when i shift fast at around 3k rpms.
    also, my bov vents pretty loudly at 3k rpms in normal driving. is this okay? or should i adjust it? which adjustment should i make for this problem? )the sound adjustment or spring tension adjustment)
    thanks!
    03 WRB WRX - 5/18/03
  12. #1765
    Nov 2002
    Bedford, IN
    Definitly do the reset and also put a washer or 2 in it. I actually went to 2 washers just cause it makes it blow off less easily.
    2002 Silver WRX with:
    TurboXS MBC @ 15.5, Kartboy Short Shifter, Kartboy Shift Bushings, Godspeed Uppipe, Custom 3" Turboback Exhaust with 4" Bellmouth and Flowmaster Muffler, Eibach Springs, Diablo C9 18" Rims, Wings West body Kit and Wing
  13. #1766
    Registered User Murchie's Avatar
    Mar 2003
    socal
    i dunno if txs rfl is the similar to hks.... but on the hks bov there is a screw in it in which u can tighten or loosen to stiffen or loosen the compression spring... If its too loose than the systems u suggested occur.. dropping below idle and stalling..
    ~Mark
    Mods
  14. #1767
    Jun 2003
    in VA
    they call it a bypass valve i think
  15. #1768
    Registered User WRXSti04's Avatar
    Jun 2003
    North Carolina
    Is called a Diverter Valve and yes it is included.
    2004 World Rally Blue STi
    Email: JDMTEG@nc.rr.com
    AOL IM: Bluedevils80
  16. #1769
    Mar 2003
    hello
    im interested in installing this BOV, i have a stock car tho, and as much as u guys say it wont do **** for me, i still want it cuz i believe this forge one wont do any damage but something that i need to do when i get this is take it off every time i go to the dealer, how is the install? fast..slow..? is it easy to replace the stock BOV? thanks!
  17. #1770
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    Re: hello
    Howzit! It's easy. 10 minutes max...
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
